Question about Canon PIXMA MP810 All-In-One InkJet Printer
Paper is jammed in the transport unit
My printer was working fine until 2 weeks ago when it started to jam with the message " Paper is jammed in the transport unit" I have opened the rear cover to find 2 pieces of A4 paper have fed up to the printer so I removed them , but the problem happens every time I try to print! I have tried peoples suggestions on here like checking for any small pieces of paper that might be jamming the unit but haven't been able to find any. I have also tried blowing out the unit with a compressor and this never made any difference either. I am starting to tear my hair out with this as I need this printer for work and I payed a lot of money for it aproximately 12 months ago.
Has anybody seen this error before and been able to resolve the problem without having to take it to a repair center as I don't really need the extra costs considering it is relatively a new printer with little use?
Any help appreciated :)
  • 34 Answers
This unit does not require the proof of purchase until 3/2009, so if you take it to a service center and tell them that you bought it about 8 months ago, but can not find the receipt, they are suppose to take your word for it and repair it under the warranty. However if you sent in the warranty card with the serial number they may have it on file, however the service center can not access that info unless they go through tech support in Va. Most do not.
I hope this helps you out, and lets you keep your hair in your head. :-)
Posted on Nov 13, 2008
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
Hp cp2025 paper jam message, no paper jammed, even when restarted gives message
try lubricate the paper lefter from down the printer - you must lubricate the two sides
Mar 07, 2012 | HEWLETT-PACKARD HEWLETT PACKARD HP COLOR...
Paper jam
This model has 5 places where you might encounter jammed paper. Since you said you cannot see it, I suspect that it may be one of the following:
1) Inside from the front - (This is a similar to accessing the print cartridges). Raise the scanning unit until it stops (cartridges move to the center). Open the two inner covers. Gently clear the jam. Try not to touch the printer components. Close both inner covers, lower the scanning unit. Press <OK>
2) Inside transport unit - Open the rear cover. Remove the jammed paper or any bits that you may find. Close the rear cover. Press <OK>
Dec 19, 2009 | Canon PIXMA MP760 All-In-One InkJet...
Canon PIXMA MP480 bought 4 months ago jams paper
paper jam problems are usually occured by dust and debris in the printer . clean up ur printer from inside . also align ur paper tray. that will fix the problem. thanks and take care of urself.
Jun 09, 2009 | Canon Pixma MP480 All-In-One InkJet...
Kyocera FS 9130DN is showing MP tray transport jam and to open front cover. No paper is jammed or in the machine.
check the bypass transport connector for a small piece of paper. or the paper sensor arm is jammed down there are 2 one in the transport unit and one in the mp tray
Nov 03, 2008 | Kyocera Office Equipment & Supplies
Photo Paper Jams
Based on your question, my first thought is that you changed the type of photo paper you used starting "this week" (when you first posted your question). If you did, the photo paper size/thickness may not be compatible with your printer.
Otherwise, there may be a problem with the paper sensor. Click on the following link and review the troubleshooting steps, particularly Step 2, to see if that helps:
Paper Jam Troubleshooting
Post back your results. If you are still having the problem, post any additional information you think might help solve the problem. Thanks and good luck.
Sep 09, 2008 | HP Officejet 5610 All-In-One InkJet...
Paper jam error message
Try this website for a paper jam problem with your printer.
Click Here
May 26, 2008 | Lexmark P4350 All-In-One InkJet Printer
Kyocera Printer FS-1800 plus - paper jam Can't find the printer manual. Please provide steps to clear the paper jam and reset the printer.
Hi, first of all,pull out paper tray and check any paper,or scrap jammed.When paper tray is pulled out,open paper transport unit-You have green handle on the right side of machine,in the place of right side of paper tray.Pull out paper transport and remove paper.Just close paper transport unit and paper tray,open and close top cover.
Nov 29, 2007 | Office Equipment & Supplies
Clear Paper Jam error -- but there is no paper jam!
Sometimes while clearing the jam (if there was one) you may leave a bit of paper left behind which obscures a sensor causing it to think there is paper still in the paper path, or sometimes even paper dust can do it. Try a bottle of compressed air and blow the path out very well. Get a bright light (good flashlight) and very throroughly eyeball the paper path for any "foreign" objects...
Apr 16, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Canon PIXMA  MP810 All-In-One InkJet Printer Logo
81 people viewed this question
old marine
old marine
