Question about Frigidaire GLTF2940ES Front Load Washer
  • fourwindbb Nov 11, 2008
    Same problem, will get a short blast of water then nothing. in the diagnostics in also get a error code E31.
Thanks for your help, i will check it out. :)
Posted on Nov 12, 2008
  • 196 Answers
E31 ERROR MEANS. Pressure sensor not communicating with control board.
Water cooler runs for 20 sec and then stops says that bottler is empty. not pumping water?
either you faild to unpack it properly and left some thing in the dispenser area where the bottle drops in. It doesn`t pump water, it gavitys out of the bottle.
Apr 23, 2014 | Vitapur Energy Star Bottom Load Water...
Beko dryer
i have had this problem and its usually the pc board is faulty
Mar 28, 2014 | Dryers
Culligan Gold series softnerdrain line runs constantly in street.
The main piston/sealpack is frozen up and needs to be replaced. There is a retrofit kit available from Culligan to repair this issue. The reason it stops when bypassed is the water is shutoff to unit.
Jul 25, 2010 | Culligan Sediment Water Filter Heavy Duty
665.15824000 dishwasher
What is your water temp. This model has 4 automatic water heat cycles built in to it and it heats the water to 145 degrees and won't let advance till that temp. If the water coming in is lower than 120 degrees it will add about 2 hours to your normal wash cycle.
Feb 12, 2010 | Dishwashers
The water runs during the spin cycle. The clothes
Does the water run through the ENTIRE spin cycle? There is a period where the water will run during the spin; This is called, the "Final Rinse". But it usually only runs for about 10 seconds then stops.
Dec 22, 2009 | Washing Machines
Pump runs for a minute - stops and water light
Make sure that the inlet solenoid is not blocked, the manual fill might be fine but the solenoid could be blocked.
Nov 01, 2009 | Nuova Simonelli Premier Maxi Espresso...
Whirlpool LSQ9500LQ0 stops runs only for about 2 minutes
Try this first..Same thing happened to me yesterday..
I pulled the washer away from the water source..unscrewed the water lines from the water intake (not the washer)..there is a screen in the both hot and cold screens were filled with debris..after cleaning the screens the washer works just fine..try this easy fix before you start looking into things like the motor or a switch somewhere...
Dec 19, 2008 | Washing Machines
Hotpoint aquarius FDW60 FAULT
dishwasher runs for 1 min then stops and 40c indicator and 50c indicator flash on and off together it pumps water out then stops
Jan 03, 2008 | Dishwashers
Frigidaire GLTF2940ES Front Load Washer Logo
257 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
