Question about Craftsman 4 Cycle Blower/Vac
Craftsman leaf blower
I have a leaf blower that will start but when you try to idle it up it dies any help appreciated
  • tabsher1 Nov 22, 2008
    Mine starts up fine and I can manipulate it into staying on by adjusting the control knob from half and/or full throttle back to full choke, back to half choke, and back into throttle. After 10 or 15 seconds in either throttle, it starts to die and I have to move it back to full choke again and repeat the process. I replaced the spark plug and the gas cap (had fuel leaking out of it) but didn't make a difference. I'm thinking either carb needs cleaned or there's a leak somewhere in the engine.
  • 211 Answers
Hi
Check the fuel lines,fuel filter and clean the fuel tank.Disassembly the carb and clean it carefully.Diafragm type carb has a fuelpump,pay attention to it ,has to be tighten not folded.When the engine gets warm ,the fuelpump cannot keep the right proportion of fuel and the air/fuel mixture is changing.It has to be changed.
regards savumihai71
Posted on Dec 05, 2008
Gas blower starts idles then when choke is opened stalls out. Gas bulb stays deflated when you push it down twice
If its started and idling,why are trying to choke it??????
Don't do that just start blowing dude. Good Luck......
Sep 16, 2013 | Craftsman Garden
How do I adjust the carburator on a craftsman blower
All carburetors have 3 screws high and low and idle, then screw high and low all the way in, then turn them back 1 and half that should be factory settings go from there. start with the high idle back it out slow until it sounds good. My blower ran good on two turns out on high idle then three turns on low idle. Good luck...
Sep 15, 2012 | Craftsman Garden
My craftsman 200mph/430CFM 25cc leaf blower will start and last for about 5 mins. on half choke and then die out and not start. It cant be put on run or it will die right away.eplaced spark plug. Still...
check age of gas. Cannot be more than 30 days old.
Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage.May need to clean or replace carburetor.
May 12, 2012 | Craftsman Garden
I have a shihl br 340 leaf blower it starts but when I make it accelerat bogs down and dies ive tried ajusting the idle screws cleaned the carb not sure what to try next any sugestions
check the muffler for the exhaust being plugged, If not start checking your fuel lines and fresh gas, then fuel filter and ,all esle failes clean carb out.....hope this helps
Apr 25, 2011 | Garden
NEED TO SET IDLE SCREW AND MIX SCREW ON A GAS LEAF BLOWER
The Idle screw should just touch the throttle lever to start, the low speed should be set at 1 to 1.5 turns out from lightly seated, and the high speed should be set the same. Final adjustments are made only after it has been warmed up. If you adjust before 2 minutes of use the mixture will be too rich.
Hope this helps
Nov 10, 2010 | Craftsman Garden
Hi. My craftsmal leaf blower runs OK for 3-5 then dies????
Could be a blocked vent on your fuel tank - is there a vacuum in the fuel tank immediately after it stalls?
Oct 25, 2009 | Craftsman Garden
Need a leaf bag for a chipper/shredder/vac
That is actually a good price. MTD wants $225.00
Oct 04, 2009 | Craftsman 4 Cycle Blower/Vac
Craftsman blower stalls when choke is disengaged
You need to play with the timing adjustment, either on the spark plug, or the gap between the contact and the magneto.
That'll do it ;)
Don't forget to rate, thanks
Jul 31, 2009 | Craftsman 4 Cycle Blower/Vac
Homelite ut o8107 blower 25cc will only idle
Hello:
Have you Removed the Muffler and Checked the Exhaust Port and Muffler for Carbin Restriction?
Remove the Muffler and Start the Unit. If the Operates Correctly, then the Spark Arrestor Screen is Clogged and the Muffler/Screen Requires Replacing.
Make Sure the Exhaust Port is Not Restricted Also.
Hope this Helps.
Good Luck
Respectfully
John
May 09, 2009 | Homelite 'Yard Broom' Leaf Blower
CRAFTSMAN LEAFBLOWER TROUBLE
After you do the above, try to clean out the fuel line. It may only be letting in a small amount no matter the throttle control.
Dec 30, 2008 | Craftsman 4 Cycle Blower/Vac
Craftsman 4 Cycle Blower/Vac Logo
586 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
