FixYa.com
Tags:
D-Link AirPlus DWL-G630 802.11g/b Wireless Adapter
Using G630 but get "network cable unplugged"... (by 2 users)
posted by ozinwichita on Oct 26, 2006
I have the DLink G630 C2 with latest drivers installed on Windows 2000. It used to work then all of a sudden it stopped working upon starting the computer and would just place a computer icon in the tray with a red X through it and when you hold the mouse over the icon it says "network cable unplugged". I've uninstalled the Dlink and all software and tried reinstalling it, no luck.
My ethernet card (Kingston) works fine and both the Dlink and the Kingston used to work at the same time when each was in its respective slot. I've tried uninstalling the Kingston then reinstalling the DLink and software but no luck. I have tried switching slots, no luck.
Any help would be appreciate. I'm relatively new at this so please keep it simple! :-)
Comment by ozinwichita, posted on Dec 16, 2006
To responsed to the previous suggestion. I have tried my Dlink and Kingston independently. The Kingston (wired) works fine. It is then disabled and I try the Dlink (wireless). The WIRELESS (emphasis added not shouting) once installed with drivers etc. according to instructions is the one that shows up with a computer icon with a red X through it in the tray, that says "Local Area Connection # network cable unplugged" when the mouse is held over the icon. When I go to Open Network Connections and look at the connections there for the LAN connection specified in the tray message, under Device Name is listed Dlink DWL-G9630 Airplus Wireless Cardbus Adapter and under Status it says "network cable unplugged".
Now I know that "network cable unplugged" does not seem to logically refer to a wirelss adapter, but however it does. Hence why I am as are others baffled by this problem.
Thanks.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by cartoonist, posted on Nov 15, 2007
I HAVE AN AMILO LI 1718 OPERATING WIN VISTA. I CONNECTED IT TO A BT HOME HUB IN WIRELESS MODE AND IT WORKED FINE FOR A COUPLE OF DAYS THEN ON TRYING TO CONNECT I RECEIVED THE "YOUR PCI WIRELESS ADAPTER IS UNPLUGGED OR HAS BEEN SAFELY REMOVED". ANY SUGGESTIONS ?
Best Solution
posted on Oct 26, 2006
Thanks for Trying (70)
sandrew
Rank:Wiz Wiz
Rating: 83%, 4484 votes
A little confusing this, it would not say 'Network cable unplugged'
if windows was refering to your D-link wireless connection(It's wireless)
The cable unplugged should be refering to your Wired Ethernet card, so there must be no cable connected at one or other end.
You don't mention anything about what the wireless card is trying to connect to(eg Wireless modem/router or another wireless PC).
Maybe your pc is getting confused as to whether you wish to connect wirelessly or wired, as it can only work through one IP Address at a time.
i could be wrong, but you probably thought that they were working but only one was, you really need to explain why you are using both wired and wireless and what is connected to what,
Please reply and hopefully it'll get sorted
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jan 05, 2008
Not Rated (0)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
have the DLink G630 C2 but i cant to find the drivers any one know where i can to download it ??? i only have the card and i cant find the drivers
Solution #3
posted on Aug 16, 2007
Not Rated (0)
scucca
Rating: 100%, 1 votes
I'm having the exact same problem with my Zyair B-100 PCMCIA card. I install the drivers, ones I got from driverskit.com , and it just adds a LAN icon in the taskbar, in addition to the LAN card I already have. In Network Connections, it adds Local Area Connection # Network Cable Unplugged. Yet in "Connect using..." in the properties of the connection, it shows "ZyAIR 100 Wireless PCMCIA". The LAN connection works fine, and I have another PCMCIA card that works as well (Cnet). It just happens with this particular card.
I don't know, I'm starting to wonder if it's a hardware problem...
This Problem Also Relates To: EnGenius EUB-362 (EUB362 EXT) Wireless Adapter HP (319468-002) (319468002) 802.11b Wireless Adapter Motorola PC850 Bluetooth Wireless Adapter Motorola 2.4GHz Wireless G 802.11g/b (wpci810g) Panasonic (ET-CDWL1) 802.11b Wireless Adapter 2wire (1000-000005-002) 802.11g/b Wireless Adapter 3Com (20300024) Wireless Adapter
Can you Help with these Wireless Adapters problems?
Wireless Adapters
Asante Areolan AL1611 PCMCIA...
The Asante Areolan AL1611... Answer This...
Wireless Adapters
wireless connection speeds
Have netgear wireless attached... Answer This...
Wireless Adapters
WMP55G
hi , i am using rhel 5.0. i... Answer This...
Wireless Adapters
Wireless card suddenly cannot...
My Buffalo wireless card has... Answer This...
Wireless Adapters
info
hallo ik hep een usb.adapter... Answer This...
Repair Service
Find Wireless Adapter Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
