Question about Lexmark X2350 All-In-One InkJet Printer
Lexmark z730 my cartridge slams back and fort and the plastic strip in the printer has fell off. how do i fix this?
  • 53 Answers
Try putting the plastic strip in. I think it should help. Anyways i had the same problem but mine didnt work even after replacing it. So Igot an HP all-in-one and I'm satisfied :).
Posted on Nov 10, 2008
Lexmark 5400 cartridge carrier slams up against back???? Won't stop!! It's a new printer, put in a high cap black and low cap color cartridge. Any ideas how to fix this?
Cartridges may not be seated properly. Remove all the cartridges from the printer. Close the cover. Unplug the printer from the power source. Wait for about 10-15 seconds. Plug printer back to power source. If printer ink cartridge carrier still slams on the sides, encoder strip of the printer might be damaged. If it's still within warranty from where you bought it, have it replaced at that store. If ink cartridge carrier is not slamming to the sides, re-insert the cartridges. Make sure there are no obstructions along the carrier's path. Close the cover. Let the printer print the alignment page. If it's still going to slam the carrier, have it replaced.
Apr 07, 2010 | Lexmark 83 Color Ink Cartridge (Twin Pack)...
The cartridge bay goes crazy and slams both sides of the printer. Thus, this will not let me print. I was printing fine, and then I heard a slam, and a notification popped up sayin there was a problem with...
Clean encoder strip, thin plastic strip runs width of machine pararell to silver scan rail. Ensure it is running threw carriage smoothly otherwise the light that read it is dodgy, this will be unecomical to fix unless dirty strip
Nov 07, 2009 | Lexmark Z715 InkJet Printer
Ink cartridges make a slamming sound from left to right and wont print
The encoder strip is most likely the problem. Unplug the power from the printer. Open the front cover and move the cartridge carrier to the center. You should see a white ribbon cable, a thin plastic strip and a black belt with teeth.
The thin plastic strip is the encoder strip. It rides in a sensor on the back of the cartridge carrier that you will not be able to see. Reach in with the first finger of either hand and carefully strum the strip as if playing a guitar.
The strip will need to be lowered slightly and brought towards you slightly. Please be careful not to break the strip or your printer will not function. Once you believe the strip is set correctly, plug the power back and try printing the self test. If it slams to the left again, the strip is not yet set correctly.
If you cannot repair the strip, please let us know so that we can assist you further.
Please Note: Fixing the encoder strip is a delicate procedure. During the troubleshooting, if the strip breaks, you will not be able to use the printer.
May 28, 2009 | Lexmark X2580 Wireless All-in-One InkJet...
The runner in the printer
May 08, 2009 | Lexmark Z845 InkJet Printer
Long thin plastic piece fell out of Lexmark Z33
Google your printer, try pcappliancerepair.com. This item goes from one side of your printer to the other, passing through the cartridges holder. Look for the places it attaches. You may have to move the cartridge holder to the center to install the plastic.
May 01, 2009 | Lexmark JetPrinter Color Z33 InkJet
Hardware error 0502 and error code 50c
Please Note: Fixing the encoder strip is a delicate procedure. During the troubleshooting, if the strip breaks, you will not be able to use the printer. Lexmark will replace the printer, only if it is under warranty.
Apr 26, 2009 | Lexmark X5150 All-In-One InkJet Printer
Cant put printer piece back in
Try to print any document.
If this failed then printer cannot be repaired, if the printer is under warranty then Lexmark will replace the printer else. I am sorry to say you need to purchase a new printer
your's tech expert
Jeeth
Mar 28, 2009 | Lexmark X1270 All-In-One InkJet Printer
Part FELL off!
It sounds like this is the is the position indicator tape. There should be a small hole on both ends of it that fits over a small plastic tab on eich side of the printer. It normally needs to fit in a small **** on the back side of the print carriage.
With the printer turned off & preferably unplugged, gently slide the print carriage to the center of its range of motion. Ensure that this plastic strip is still attached on the opposite end and it feeds through the back of the print carriage. There should be a small tab to attach the free end to similar to what you see on the other end. The strip should be taut but not tight enough to stretch and it should not sag. Exactly where the attach vary somewhat depending on make and model, but they are all similar.
Mar 22, 2009 | Lexmark JetPrinter Z515 InkJet Printer
Carrier Jam
I loaded to new cartridges into the printer1.gif, switched it on, cartrigde went from one side to the other with a bang, error on printer reads, clear the carrier jam, cn you help?
ed
Jan 11, 2008 | Lexmark OfficeCenter X3350 All-in-One...
Small thin film fell out
Try to cut off a thin plastic strip. just try to copy that. it basically guides the cartridge on where to print. also i remember that it should have a spring connected to the holes.
Oct 04, 2007 | Dell 924 All-in-One InkJet Printer
Lexmark X2350 All-In-One InkJet Printer Logo
62 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
