Question about Hitachi 50V500 50 in. HD-Ready LCD Television
Hitachi hdtv 60" yellow circle on screen
The screen has a big yellow circle on it.  It started out as a small yellow circle in the middle then spread out to the larger screen.  Hitachi told me I need a new lamp but other people told me it's not the lamp, it's the light engine. Before I spend $ on a new lamp, has anyone  had the same problem?  thanks.  tico@aloha.net
  • Anonymous Nov 20, 2008
    my Hitachi 60V715 has the same problem. New bulb does the same thing. Internet research I did favors a bad light engine. Over a $1000 fix.
  • dstallard Nov 20, 2008
    I had the "red bloom" problem that many people have reported online, so in April 2008 I had the light engine replaced. Everything was fine until now, in November 2008, when I am seeing a slightly yellow circle on the screen. It's invisible except in darker scenes. I don't know if it is going to get progressively worse or not. I guess the solution would be to replace the light engine yet again, but I don't have confidence that a new engine would be any less flaky than the two I've already gone through.
VOTIT
  • 2071 Answers
SOURCE: hitachi 50vs69a blue oval circle in the center of
Just try to reset HDTV. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Regards:
VOTIT
Posted on Jul 08, 2009
  • 129 Answers
SOURCE: problem in Hitachi 53UWX10BA
The convergence ic's, and related components that could'be affected need to be replaced cost to repair 250.00 2hrs job max with alignment this depending on the tech. If you need more help let me know
Posted on Jun 14, 2007
puneetgarg
SOURCE: Hitachi 42" LCD 16:9 HDTV
lvd demej
Posted on Sep 11, 2007
  • 1153 Answers
SOURCE: Hitachi HDTV
Do not try to fix take back or call dealer, You shoud be still in warranty. No need to try to fix. Get new set or demand new set.
Posted on Sep 13, 2007
  • 579 Answers
SOURCE: Hitachi Rear Projection LCD TV Lamp
Projection TV makers charge an arm and a leg for their replacement lamps. They make it easy to do but as a result the custom lamp assy is expensive. The trick is to just buy the bulb for your model TV from any number of us aftermarket sources at a fraction of the lamp price and install it in the old lamp yourself. really easy. Some models are real bulb hogs though. Look them up on the net (include the word complaint or repair) before you buy, or you might be sorry. Many class action lawsuits out there - even against some of the name brand makers.
Posted on Dec 31, 2007
My 60'' sony grand wega kds60a2000 started with a yellow haze circle in the middle of screen and now has spread to almost whole screen with a yellowish green tint. Is this an optical drive problem...
It's the Digitial Optical Block. Sony is working with owners of this, and many other sets that have the same problem since the 2004 model year lineup. http://sites.google.com/site/sonylcdrptvproblems/
Start your search to the appropriate link from the site above. Hope this helps
Jul 02, 2011 | Sony Grand WEGA KDF-60XS955 60" Rear...
Having a big yellow spot background in the middle of the picture.
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixilation even vertical lines.You will need to replace the light engine. Have a blessed one!
Apr 09, 2010 | Hitachi 50VS69 50" Projection HDTV
Yellow hue circle in middle of screen. after leaving tv on all night
spherical or oval shaped light starting in the center of your picture is an indication of an led backlit tv.. probably a hitachi. solution, replace light engine..ps no garuntees not with led backlit sets.. was bad idea to begin with. when the leds start going they start at the center and branch out.
Apr 13, 2009 | Hitachi 50V715 50" Rear Projection...
Red circle and yellow tint in our white
If you have RED color that starts from Center of the Screen,(no red color on sides ) 100 % your light engine is deffective..
In order to solve this issue Replace Light Engine Control Board (also called Driver Board ) attached to light engine.
Good Luck
Do not forget to Rate!!
Dals123
Jan 03, 2009 | Hitachi 60V500 60" Rear Projection...
Blue haze spot-yellow tint
I have the same problem with blue haze that just spread out on model 55VS69A ,
tv is almost 2 years old. i called hitachi and they advised to call a local repair center to check the tv...they confirmed Optical Block (light engine ) replacement light engine cost $1400 and labour $400, so i called back hitachi and they said they will provide light engine and will have to pay labour!....this is not right paying out of pocket for a tv less than 2 years old....I am not sure if the issue will resurface again...more likely ....Hitachi is supposed to issue a recall or atleast like sony did to cover all cost for there defective TV's....I will NEVER buy hitach again.
Hitach SUCKS.
Dec 28, 2008 | Hitachi 60V500 60" Rear Projection...
Hitachi 50V710 has a yellowish circle in the middle of the screen
If you're good with electronics you can probably do it yourself. It's the price of the part that hurts ... around $1000.
Feb 18, 2008 | Hitachi 50V710 50" Rear Projection...
YELLOW CIRCLE
sOUNDS LIKE YOUR LIGHT ENGINE
Feb 11, 2008 | Hitachi 60V715 60" Rear Projection...
No Warranty TV
call a tech to correct your problem your lens might be your problem out of alignment.good luck.
Apr 01, 2007 | Hitachi 42V710 42" Rear Projection HDTV
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
376 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
