HP PSC 2110 Color Printer, Scanner, Copier C8648A Brand
Problem for HP PSC 2110 Color Printer, Scanner, Copier C8648A Brand
Hp psc 2110 incorrect ink cartridge message.
By zyne jr on Oct 26, 2006
My 2110 all in one will not recognize the new ink cartridge i installed. I get an incorrect ink cartridge message. It also makes a strange grinding noise after i turn it on following the self test. How do I fix this?
Same Problem
Oct 06, 2008
-   i get the same right cartridge incorrect error also.
-   Guest
Aug 01, 2008
-   After several power outages, my printer gives me "Error: Right cartridge incorrect". Taking the cartridge in and out doesn't work.-   Guest
Feb 19, 2008
-   i have installed a new black ink catridge and now everytime i turn the printer on it self prints a page too make sure the ink is installed. how do i stop this?-   Guest
Jan 30, 2008
-   My HP 1500 series not recognize the new ink cartridge i installed. I get an incorrect ink cartridge message. It also makes a strange grinding noise after i turn it on following the self test. How do I fix this?-   Guest
Dec 25, 2007
-   I am installing the exact same type of ink cartridge as was in my printer before but now it "is not supported" and is apparently not a correct print cartridge. I would chalk this up to a bad cartridge if i hadn't tried to put the old one back in which receives the same message. Any Help, Please?-   Kudu
Solution #1
posted on Oct 30, 2006
Somewhat Helpful)
Magic
Rank: Apprentice
Rating: 70%, 7 votes
1- If is the correct type of cartridge Mey be you not put in the correct positions the cartridge, check it.
2- clean all the cartridge zone and speciality the sensors of positions for the carrier.
3- Say help me, please!!!!
Was this helpful?
Yes
No
Solution #2
Somewhat Helpful)
sandrew
Rank: Wiz  HP Expert
Rating: 83%, 5980 votes
The ginding can often refer to corrupt driver, if you know the cartridge is installed correctly and it's a genuine chipped cartridge, disconnect printer, uninstal driver.
Re-install driver and re connect printer, this way you will know it's not a software problem, and the printer may of retired itself.
All asuming the catridge isn't faulty!
Was this helpful?
Yes
No
Solution #3
posted on Jan 03, 2009
Helpful)
jkat_racing
Rank: Guide
Rating: 79%, 6 votes
when ever i get that message it's when i use a "Non-HP" replacement cartridge...try using a HP catridge, or most likely, the printer has reached the end of it's usefull life!
you can try a "full reset" of the printer by..
-unplug it and let sit for a little while,
-BEFORE plugging it back in, press and hold both the enter and cancel buttons,
-plug the power cord in, and wait to release the buttons until the display on the printer tells you to,
-in many cases, this corrects some problems (especially that awfull grinding/ratcheting noise).
after many years of faithful service, i think mine is officially dead though...even the full resxet doesnt help.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #4
posted on Oct 10, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
by the correct catridge
Popular Solutions for HP PSC 2110 Color Printer,
Questions and Unsolved Problems for HP PSC 2110 Color Printer,
Do you recommend HP PSC 2110 Color Printer, Scanner, Copier C8648A Brand?
Answer
Answer
I have a HP psc 2110xi all in one printer, scanner, copier and I loaded my cartridges in and the... (More)
Answer
Start 2110, itcomtinuously recycles with a racheting noise, will npt take a project, will not print,... (More)
Answer
on borderless photo printing leaves 3/8 inch border at trailing edge of paper on 4 x 6 prints. on 8... (More)
Answer
The printer function is working fine, but when I press "start scan" (which used to trigger... (More)
Describe your Printers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printer Experts
Top Printer Repairmen
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
