Question about HTC TYTN GSM Phone
White screen wont disappear after letting the battery die
I have a spv m3100 and after letting my battery run completey flat i tried to charge it and it charged but the screen is still white. ive tried to reset it but *** does nothing. i was told to try a new battery. can anyone help please.
and can they be unlocked, as mine is on orange and i want it on o2.
  • 42 Answers
Hi, Assumimhg that the setting which tells it to switch off the back lighting is set correctly, you have a fault which will need repair. You may consider living with it if you intend to get an other phone any way. Yes, they can be unlocked by specialists.
Posted on Jan 10, 2009
Orange SPV M3100 pin code
try soft resetting the device.. may be it'll help.. but in that case all the data will be lost & there is no way to retrieve it..
Mar 18, 2010 | Orange SPV M3100 Smartphone
Please I don't have the manual and I find it hard to use the phone features.
Diplodocs help download the user guide ORANGE SPV M3100.
manual-pdf-e.png manual-help.png Download the complete
user guide (580 Ko)
Need help, support, reviews, tips or troubleshooting for your ORANGE SPV M3100 products ?
This product, although classified under the brand ORANGE, may have been manufactured by FRANCE TELECOM after mergers, acquisitions, or a change in name.
Feb 05, 2010 | Orange SPV M3100 Smartphone
How to turn on the phone spv m3100
there should be a turn on button hold down for 1-2 seconds at the top of the phone if nothing happens the battery may be dead i have an mda vario that if it is not turned on the battery won't charge its just the way they work not a fault.
I got it working by taking the battery out and cut off the small end of a normal usb lead i.e. big usb to small. strip the wires and there should be a red and black wire, posative and negative the red posative and the black negative.
attatch the red wire to the posative metal strip on your phone and the black to the negative strip on your phone, it should say on your phone by the battery or on the battery which side is posative and negative. turn on your computer and plug the usb lead in and then insert the phone battery making sure that none of the wires touch any of the other strips on your phone let your computer load and press the on button at the top of the phone for 2 secs and wait it should turn on and charge.
wait for 10 or so minutes making sure the phone is charging, then plug your charger for your phone in and at the same time remove the usb lead and wait for the battery to charge before taking the wires out of the phone.
Jul 14, 2009 | Orange SPV M3100 Smartphone
I want the full user guide manual of my orange spv m3100 phone
i need spv m3100 driver for my mobile phone i lost the cd
Apr 03, 2009 | Orange SPV M3100 Smartphone
Orange SPV m3100 not charging
Hi I've got the same problem well did have you need to do a hard reset so save all your files a bit of a pain I know, the other alternative is simple turn off the phone and it will charge fine.
Hope this helps anyone
Dec 18, 2008 | Orange SPV M3100 Smartphone
Spv m3100 phone pda
Have you tried doing a hard rest. Here is the procedure;
Caution if you perform a full reset, your phone returns to its default settings and looses all information that is saved on phone (Like contacts, messages, emails, mms etc).
Hard reset: Press and hold the Left SOFT KEY and Right SOFT KEY, and at the same time, use the stylus to press the RESET button at the bottom of your device. You will be presented with a menu saying 'press R to reset, X to exit', if you press R Your device will be set back to factory default settings.
(The L/R soft keys are the "- -" keys just above the start and OK buttons)
May 01, 2008 | Orange SPV M3100 Smartphone
Spv m3100 re boot
Display disappeared of orange spv m3100
sounds like your backlight brightness is turned all the way down. this happens automaticlly on my windows 5 mobile device when the battery is almost dead and when i recharge it it stays this way. if you take and turn it from side to side you can see a faint outline of the windows under a bright light go start settings and adjust the backlight brightness up this should resolve your problem
Apr 03, 2008 | Orange SPV M3100 Smartphone
SPV M3100 - sync problems
Pleset let me know that are you using MIcrosoft Active Synk...if not you can download the this form http://www.microsoft.com/windowsmobile/activesync/registration.mspx with the help of this Active synk you can explore your PDA from your computer.
i hope this would help you
wish you luck
Was this solution helpful? Show your Appreciation by rating it:
Oct 11, 2007 | Orange SPV M1000
HTC TYTN GSM Phone Logo
191 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
