Question about Mitsubishi WS-55859 55" Rear Projection Television
Mitsubishi WS-55859 55in Rear Projection CONVERGENCE won't correct
My RED convergence is in right field and will not correct using the setup procedures.
I found the correction posted on a previous support problem of changing the IC chip and or power resistors.
I found the chip number (on another fixit site) of IC8C01 267P155010 HIC -STK393-110 for the convergence chip.
MY QUESTION IS: Where in the V19 chassis is this chip located? AND;
With all the stuff in the chasis, what is the best way to replace it??
    Scholar:
  • 167 Answers
HELLO YOU FIRST NEED TO UNPLUG THE SET , THEN TAKE OFF THE BACK OF THE SET. AND LOOK FOR TWO LARGE SILVER HEAT SENK'S THE IC CHIP'S WILL HAVE STK-393-110 ON THEM.!!! WILL BE SCREWED TO THESE HEAT SENK'S WITH SCREW'S AND SOLDER TO THE BOARD ON THE BOTTEM OF THE BOARD,!!! WELL "GOOD LUCK"
Posted on Nov 25, 2008
  • bluemage Nov 19, 2010
    Old Topic, Got a Mitsubishi WS-B55, the chassis version number is located on the back-right, on the very bottom of the name plate. I'm looking for a convergance IC for my blue controller, and stumbled upon this forum. I'll keep looking, and good luck.
My 55" WS Mitsubishi projection
The convergence is out, and the convergence ICs' would have to be canged on convergence board, and you are looking a a repair bill between 300-400, and if it was mine for the year that it is I would not lay any money into it, Just buy a new LCD, take care.
Aug 16, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Ws 55809 color
So you are still haveing the convergence issue with your tv, the convergence ic chips need to be replaced to correct this problem you can't adjust it as the components are failing.
Aug 19, 2008 | Mitsubishi WS-55809 55" Rear Projection...
We can set the convergences great but after about 10 to 15 minutes ithe reds lines start moving a little again will not stay in position. It's a widescreen Mitsubishi rear projection tv ws-55857.
The problem - you're setting the convergence settings, but you're not saving them, you're
simply exiting the menu screen. Be sure to save your convergence setting for each
of the three colors. It sounds like you're setting RED last, and not saving its convergence setting,
whereas the GREEN & BLUE are holding their convergence settings, since you're saving them
correctly before proceeding on to RED....
Mar 15, 2011 | Mitsubishi WS-55857 55" Rear Projection...
The red field on the screen, bends within the image, creating a 3D like effect.
The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alingnment,have colors shadows pictures or 3D pictures.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the convergence board,require replacing to fix the tv picture convergence problems.The shop,will cost $300-350 for parts and labors.
Oct 19, 2010 | Mitsubishi WS-65712 65" Rear Projection...
It looks a great deal like watching a 3d movie without 3d glases. The convergence is not correct. I tried to correct with a convergence back to factory settings and a manual correction from the remote. Not...
Common convergence problems like this require the set to be repaired. Transistors are used to control convergence and they will go bad eventually and require replacement. Expect a repair cost in the 100 to 175 dollar range depending on who you can find to complete the repair.
May 04, 2010 | Mitsubishi WS-65869 65" Rear Projection...
Intermittment convergence problems. Color overlays appearing blur
yheshospot,
You have a bad convergence circuit. I have a tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which explains how to correct the problem and where to get the parts at the best price.
Thanks for using FixYa and for the great rating.
hardrocko
Apr 05, 2010 | Mitsubishi WS-65809 65" Rear Projection...
Convergence
First look for open solder connections on the convergence ICs. next bad reisistors around convergence ICs. If you find none of this then replace the convergence ics.
Mar 25, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Can not align red even though convergence board WS-55819
Did you replace the center board with the STK-392-570 chips or the Digital convergence board mounted on it?
98% of the time if you have a convergence problem it is on the center board---the small board on the left under the metal shield box stores and controls the convergence of this set.
WHICH DID YOU REPLACE?
I am here to help----I have fixed hundreds of Mitsubishi sets with convergence troubles.
Regards, SD TECH
Oct 28, 2009 | Mitsubishi WS-55819 55" Rear Projection...
replace vertical IC and shadows/ghosting the problem is either electrolytic capcitor or video IC or convergence adjustment
Aug 18, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WS55809 "red" converge problem
Proper description is convergence IC ...part # STK392-570...
there are two in model # WS 55809...replace both.......T.
Jul 30, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55859 55" Rear Projection Television Logo
377 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
