Panasonic website under FAQs. Using code shown on dvd readout,
such as RC2, press 2 & enter or ok, hold for 2 seconds, and machine
will reset connection between remote & dvd recorder. So stupidly simple it works.
Try removing the cover and clean the glass laser eye with rubbing alcohol and a cotton swab. Clean the glass laser eye. If cleaning doesn't work, then the circuit will need to be replaced.
You need to install or update the Firmware. Go to www.panasonic.ca and search your model. You will then need to download the firmware for your player and burn it/mount it as an ISO file on to cd. Just follow the instructions and you'll be up and running in no time.
It took me about 25min, but it is working fine now.
Hello, I get exactly the same problem with my Panasonic EZ48 recorder. It also displays FM List DL error .It sometimes sorts itself out by holding the on switch for 20 seconds. Ian
had the same LD FVU (Load FVU or firmware disc) message and fixed it this way: download firmware from http://www.pasctraining.panasonic.com/specialapplications/productfirmwaredownloads/DVD.ASP and make firmware disc and insert. After it loads and updates, you need to activate your remote again. When the message SET 1 appears, on the remote press ENTER and 1 together for 10 seconds. Done.
Did you ever solve this?? I have a similar problem on my DMREZ25EB and got told it could be resolved by updating the firmware which is what the FVU is meant to mean. However, I can't find my version of the Firmware on the panasonic.com site. If you solved this could you let me know what you did.
