Question about Brother IntelliFAX 560 Plain Paper Fax
Brother 560 when I fax someone all they get is a black line. When I recieve their fax it is fine what can I do to solve this
  • cpcm Nov 12, 2008
    didn't work
    Genius:
  • 2,120 Answers
Open the document feeder and look for debris on the scanner glass.
Posted on Nov 10, 2008
Black line going down the middle of the page
lift the auto feeder and clean the scanner glass that your pages scan across -it is dirty. You can make a copy afterward and this will tell you if you have solved the problem.
Mar 05, 2009 | Brother IntelliFAX 775 Plain Paper Thermal...
Brother 560 fax. replaced old cartridge ,now copys come out all black
Try removing the print cartridge, cleaning the roller with alcohol, replace the print cartridge and press firmly to ensure it's installed correctly and replace cover. This should solved your problem.
Mar 01, 2009 | Brother IntelliFAX 560 Plain Paper Fax
Large black line
Your printer has a technical bug, DO NOT try fixing it. Send it back if you have a warranty or get it repaired.
Dec 10, 2008 | Brother IntelliFAX 4100 Laser Fax
I have a brother ppf-4100 fax
There should be a blue slider on top of the cartridge, move it left and right 5 times.
Nov 03, 2008 | Brother IntelliFAX 4100 Laser Fax
Cant receive faxes
First make sure your line cable is plugged into the correct place. Most Brother machines have a plug for Line and a plug for Extension (EXT), make sure it's plugged into "Line".
Go into the menu on your Brother machine and select Fax, then Setup Receive and then select Easy Receive. This will usually solve most recieve problems.
Brother machines come with s default of 4 rings before they will answer, make sure none of your other devices (such as an answering machine) are set to a lower number of rings or the fax machine will never grab the line.
If you have distinctive ring, make sure you have it set up in the machine. There is a section in the owners manual for setting up discinctive ring.
If the machine grabs the line and goes through the motions but nothing comes out on the page (no black print) then make sure you are using a Brother ink cartridge (not refilled or generic) and print out the test page using the "ink" button. Allow the machine to clean a few times and see if the test page prints out correctly. If you are using refills or a generic black, you might have premanently damaged the print head. In this case take it to a service centre to have the head tested.
Sep 10, 2008 | Brother IntelliFAX 4100 Laser Fax
Pc compatibility
The brother 560 has NO provision for connection to a PC.. The specifications do not mention PC compatibility, nor is there provision for either USB or RJ-45 connections on the machine.. You could use the phone line connector on your PC, but there is no exchange of data on the phone line between the PC and the fax. The phone plug on your PC is meant mainly for connection to the Internet via telephone, or to use the PC-to Fax feature, if so equipped.
Apr 09, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Ink cartridges, recieving fax
It sound like your machine is receiving but as soon as it tries to prints the fax it has this problem.
Rewind the ink ribbon so it is nice and tight in the housing. Clean the black roller above it with some cleaning alcohol or equivalent (nothing too harsh).
See how that goes if you are still having problems replace the whole cartridge (not the refills) PC-401.
Feb 19, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Brother IntelliFAX 560 Plain Paper Fax Logo
59 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
