I HAVE A WURLITZER 2610 JUKEBOX. WHEN YOU SELCT THE RECORD IT COMES UP, DOES NOT PLAY AND RETURNED TO CAROUSEL. I HAVE CHECKED THE ADJUSTMENT AND CONTINUITY OF THE TRIP SWITCH. HAVE CHECKED THE CONTACT AND FUNCTION OF THE REJECT BUTTON.
  • 19,396 Answers
If this is the vinyle model, the arm has a sensor that detects the end of a record.
the sensor is probably stuck.
If this is a CD model, instead, try unplugging power cord for ten minutes to reset the machine.
Posted on Nov 09, 2008
  • Ginko
    Ginko Nov 09, 2008
    Your model is a vinyle model.
    Check the arm on the turntable. When the disk comes to the end , this will activate a mechanic sensor (a small lever near to the base of the arm).
    When this sensor is stuck or broken, the Wurlitzer will remove the disk before the disk is finished, or before even playing it.
How much is my 1950 Wurlitzer Juke Box worth?
How to Determine the Value of Your Jukebox ' eBay
www.ebay.com/gds/How-to-Determine-the-Value-of-Your-Jukebox-/.../g.html
  1. Cached
  2. Similar
The value of your jukebox will depend on certain aspects, and they are listed below ... Jukeboxes from the 1940s and 1950s such as the Wurlitzer 1015 are more ...
Wurlitzer Jukebox ' eBay
www.ebay.com/bhp/wurlitzer-jukebox
  1. Cached
  2. Similar
Find great deals on eBay for Wurlitzer Jukebox in Collectible Jukebox Machines. ... 1946 Original Wurlitzer model 1015 Jukebox Bubbler Plays 78's Restored .... The Wurlitzer Classic 2000 - A replica of a 1950s masterpiece comes to life!
Jukeboxes for Sale: GameRoomAntiques.com
www.gameroomantiques.com/DMSeeburg.htm
  1. Cached
  2. Similar
1940s & 1950s ... 1958 AMI Model I-200 45 rpm Jukebox. Incredible, original 1958 AMI Model I-200 Jukebox. Plays 45 RPM ... Fully Restored 1950s Seeburg Jukeboxes .... In some countries that can add 15 - 20% to the cost of the item.
jukebox Auctions Prices ' jukebox Guide Prices - The-SaleRoom.com
https://www.the-saleroom.com/en-gb/price-guide/jukebox
  1. Cached
View realised jukebox auction prices from 137 auction lots.
Jukebox Questions & Answers
tomszone.com/JBQandA.html
  1. Cached
  2. Similar
Jun 26, 2002 - Conventional wisdom (for whatever that is worth) has determined that the origin ... According to interviews with former Wurlitzer employee's the first ... for $100-$500 to a 1950's plain looking (but visible record mechanism) 80 ...
Listing of Jukebox Models and Manufacturers - Tomszone.com The ...
tomszone.com/Listing.html
  1. Cached
  2. Similar
Jun 26, 2002 - Wurlitzer: 258 Models covering 1933 to 1987 including 146 Jukeboxes, ... machines are popular, though are probably the best value for money today. .... Jensen IMA-AMI, 1950 - 1957, Denmark, Denmark's largest jukebox ...
Wurlitzer Wurlitzer Wurlitzer Jukebox Wurlitzer Jukeboxes Wurlitzer
www.jukebox-world.de/.../Wurlitzer/Wurlitzer-Bilder-Uebersicht.ht...
  1. Cached
  2. Similar
Translate this page Bis 1974 baute die amerikanische Wurlitzer Musikboxen, bis sie dort ihre Tore schlo?. .... (1950), Wurlitzer 1400 1450 W1400 W1450 Musikbox Jukebox 1400 / ...
Antique Jukeboxes ' Technology Price Guide ' Antiques & Collectibles ...
https://www.kovels.com > Price Guide
  1. Cached
  2. Similar
Jukeboxes used 78 rpm records until 1950, then 45 rpm records were used. .... advertising pottery ashtray cowboy hat rockola jukebox capitol recordsUS $34.95.
Videos as well
1950 Wurlitzer Juke Box worth Google Search
Oct 29, 2016 | Wurlitzer Audio Players & Recorders
45 (record) Jukebox. While playing the jukebox was changing records, the arm lifted the record slightly off the turntable. the credits and song selection would not clear off the readout, even after...
Have you checked all the fuses or circuit breakers on the jukebox?
Are all the power supply led's lit?
Make sure that all the connection plugs into the boards are fully seated and making good connections.
After checking the above if the fault remains you will need to contact a Wurlitzer service engineer.
Regards
Alan Hood
ami-man
UK
May 23, 2011 | Wurlitzer Jukebox 1015 One More Time...
Jukebox lights work - when turned on the record carousel does not reset and the LED display does not work and records do not play
The problem could be the selection and credit computer or possibly the K7 switch actuator. I can repair the computer and I stock the K7 switch actuator. Please email tech@wurlitzer-ohio.com
Jan 12, 2011 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer 3600 Jukebox turntable problem
The 3600 has a hub that is supposed to play dinked and undinked records. They had 33rpm and 45 rpm records back then, so to change the record speed the undinked (small hole ) records pushed down the hub flat when it landed on it, which changed the gearing. When a dinked (big hole) record lands on it falls onto the larger part of the hub. So if the hub is down and stuck there that's your problem. After the hub has been pushed flat (because of a small hole record) it is supposed to rise up again when the record is returned to the carousel. Have a look under the turn table and push up the centre rod.
Dec 20, 2009 | Wurlitzer Jukebox 1015 One More Time...
Hi, I have a Wurlitzer 3600 Superstar that I am working on. I am having trouble figuring out why the carousel won't stop spinning. It is looking for it's "Home" position, but won't stop. If I select a...
Look at the switch and solenoid assembly at 1 oclock on the carousel. That is what activates to set it going and it then clocks off a ratchet wheel to do two full cycles looking for a selection then stops. If it gets stuck the carousel wont stop.
Oct 07, 2009 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer 3600 series wont select a record ?
If the buttons don't latch in, the machine is not in credit. Put on free play or put some money in.
Dave F.
May 30, 2009 | Wurlitzer Jukebox 1015 One More Time...
JUKEBOX WAS SHUT OFF WITHOUT REJECTING ALL THE RECORDS.
What exactly do you mean by "shut off before all the 45's were rejected" ? The mech only load one record at a time, either from the left or right side of the carousel. If the power was shut off before a record unloaded from the turntable, you can manually return the mech to the start position. Do this by getting in to the back of the juke. on the upper right, near the top of the deck, there is a motor. There should be a little white gear coming from the bottom of it. I am assuming if you look in the middle of the mech, you will see a cam with a lobe on one side of it. Turning the white gear will advance the mech adn turn the cam counter clockwise. As the lobe on the cam nears the front of the mech, the record lifting arms should pull down clear of the carousel and return the record to the carousel. Stop turning the gear when the lobe of the cam has driven the lifting arms downward. Inspect your pin bank and push down any "popped" pins. This will prevent the juke from trying to start when you turn it back on.
Hope this helps
Jan 16, 2009 | Wurlitzer Jukebox 1015 One More Time...
My jukebox doesn't play
The machine knows where the Cds are on the carousel by counting as it turns. The sensor that does this is a light gate situated at about 6 oclock on the edge of the carousel. There is a little light in there like a torch bulb. If you cant see a little light in there then thats yiour problem. The machine rotates continuously because it is trying to find position zero and can't.
Jun 09, 2008 | Wurlitzer Audio Players & Recorders
Jukebox does have power but lights (except change box light) do not work nor does machine play. Although it is a 1015, it has not been converted to play C/D's. It still plays 45 rpm's.
The Wurlitzer One More Time comes in two types. CD or vinyl. No-one converts them.
What lights do you have on? Do the flourescent lights come on? Is there anything shown in the red LED display in the middle of the mechanism?
Is the machine in freeplay? If it isn't you need to put money in it.
Does the record carousel turn when you press the latch on the edge of the carousel? (It's at 5 oclock).
Dave.
May 04, 2008 | Wurlitzer Jukebox 1015 One More Time...
110 people viewed this question
 Grubhead
Grubhead
