This problem should be removed because:
Problem with Projection Televisions
Bought a Hitachi 50HDA39 Plasma TV in March of 2006. The other day the power went out and won't come back on. Tested the powercord, outlet, etc. and all check out. Downloaded the service manual,
popped the back and ran through the troubleshooting - checking voltage on specific pins - all checked out. Next step is to replace scaler pcb (per manual), but before I purchase I wanted to get more opinions. Any one have this problem?
Thanks for any assistance in advance!
Suggested Solution (3)
Check here for the schematic diagram: http://www.eserviceinfo.com/index.php?what=search2&searchstring=ITC222
This site has more info as well: http://wa6ati.com/itc222.html
Good Luck.
Source: Convergence Power Supply
Get out the crowbar. You need to get the chassis at least half way out. You are looking for FP 08 which is one of those small pico type fuse protectors. The line has both overvoltage and short detection, but a short could be intermittant or burned open.
Good Day;
DAVE; Sorry about your problem. .....The TV's board has been damaged by the fluid, causing the PC to have poor/open trace connections. These boards are double trace, circuits top and bottom, so, you have many 'feeds'. You might be able to find some one in your area to repair them. New boards from factory are not available. Some places, factory , will rebuild these boards, it's not an easy fix.
Good Luck, big IRISH.
Source: mitsubishi 50603 no power.
black screen 53in Hitachi 53UDX10B
My tv just went all black today no problems leading up to it. It is 7 years old - I wonder the probability of it being worth fixing vs...
jvc pd35b50bu no brightness
HITACHI 42" PLASMA SOUND BUT NO PICTURE...
We have a HITACHI 42" Plasma tv when we moved to our new home it worked fine but now we only have sound and no picture the screen is...
26MF231D no color I suspect
26MF231D no color I suspect the video audio board I have been all over the internet but cant find one the part#is 318 103 6284.3.Any idea...
TV HAS LINES ON THE SCREEN
THE HD CHANNELS ARE SHOWING PERFECT PICTURES BUT THE CABLE CHANNELS HAS LINES AND ARE FUZZY.
Tips for Helping dancingbull With Their Issue
- Give detailed step-by-step instructions
- A picture or video is helpful
- Use plain language not industry jargon
- Check spelling & punctuation
Add Your Solution
Toshiba dlp ghosting
My dlp has green ghost like or smear to images. All input sources. Have seen responses about cleaning, or replaving the...
How do I know if I need a new lamp?
The TV has no picture.
Picture cutting out on Toshiba 46HM95
Got a new bulb from Part Store less than 3 mos. ago for my Toshiba 46HM95 DLP. Now after about ten minutes of viewing,...
what does it mean when the hitachi hd1080 tv will...
was on but it just turned of and when i try to turn it bach on it will not turn on there is this blue light that keeps...
Fix-O-Meter
84
84 people viewed this problem
- 0 people are following this problem. Be the first!
Top Projection Television Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
