When you try to program the oven to come on it will not accept program selection,as it used to,it maybe a fuse?does anybody know where they are,hence me also asking where can I get hold of a manual for this cooker,regards DavidWhen you try to program the oven to come on it will not accept program selection,as it used to,it maybe a fuse?does anybody know where they are,hence me also asking where can I get hold of a manual for this cooker,regards David
You can't post conmments that contain an email address.
Question edited for clarity and toss in a load of CAPS.
Disconnect the element and the fan and check them both for continuity with a multimeter. If the circular element or the fan fails, nothing works, so it could be either.
You can find the manual for the Tecnik TKC 1285 Dual Fuel Kitchen online. You can search for the specific make and model of your kitchen to find the manual. Alternatively, you can contact the manufacturer of your kitchen to request a manual.
If the program selector on your Tecnik 2677 appliance will not move, it could be due to several reasons. Here are some possible causes and solutions:
Obstruction: Check if there are any obstructions, such as food or debris, that may be blocking the program selector. If so, remove the obstruction and try moving the selector again.
Loose or damaged parts: Check if any of the parts of the program selector or control knob are loose or damaged. Tighten or replace them as necessary.
Mechanical issue: If the above solutions do not work, there may be a mechanical issue with the program selector mechanism. In this case, it is recommended to contact a qualified appliance repair technician to diagnose and fix the problem.
its the cooling fan to keep the control and metal and top of cooker cool. mine is also extremely loud. I think it basically turns unecessarily quickly and could be slowed with a resistor in line
