Question about Durabrand DWT2704 TV
PROBEM WITH MY Durabrand TV DU2701
I CAN'T GO UP AND DOWN CHANELS WITH THE REMOTE, BECAUSE WHEN I PRESS UP TWO TIMES AUX1, AUX2, SHOW UP, THAN SENT ME BACK TO CHANEL 3 ALL THE TIME.
  • Anonymous Mar 19, 2014
    How do i can i get my gaming system to show on my durabrand screen how do i program it or what chanel might i get on to see it
    Scholar:
  • 146 Answers
Go into your menu of the tv and reprogram the channels into the tv. Use "autoprogram" it will be in the menu somewhere.
Posted on Nov 19, 2008
TV has no remote, but is hooked up to dish network
If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Mar 28, 2014 | Orion STV2763 27" TV
Car radio wont work
First make sure that the AUX option is not set to off. Press A.Menu and then Initial Menu. Then select Aux1 or Aux2. Set this to match the type of device connected to the Auxiliary port, (The options are video, audio and OFF.) (When not in use, these should be set to OFF.)
Then press the Source button and try to set the Source to AUX1 or Aux2. If it still doesn't work, make sure that your device is connected to the jack. If that doesn't help, try a different device cable to connect to the Aux jack.
I hope this helps.
Sep 21, 2013 | Car Audio & Video
Everything is plugged in but my tv screen won't turn blue to show that the dvd is on I tried channel 3 and 4 I need help pleassssse
Do you have a "source" button on your remote control? Try pressing that several times to see what source the DVD is on (HDMI, AUX1, AUX2, etc..)
Jan 12, 2011 | Computers & Internet
I"ve hooked up a dvd player but i can't figure out why the tv wont cpnnect with it? Do I have to re programme my universal remote for it to play?
Try channeling down to either 3 or 4. If this does not work, continue to channel down below channel 2 to AUX setting. There may be AUX1 or AUX2. Make sure the DVD player is on, and wait a few seconds on each of the channels to see if a picture from the DVD appears. I hope this helps.
Oct 03, 2010 | Daewoo DVQ13H1FC 13 in. Combo
How to clear remote so I can program it again
Link to the manual
http://audiovox2.info/docs/rca_acc/man/D770_DOC_OM.PDF
Problem: The remote is not
performing commands properly.
• You must put the remote in the
correct mode by pressing the
corresponding component key (TV,
VCR, DVD, SAT, AUX1, AUX2) so
the remote knows which component
you want to operate.
• Make sure the component is “ready”
(e.g., DVD player has disc loaded;
VCR has tape loaded, etc.).
• You may have pressed an invalid
key for the mode the remote is in
(e.g., the RECORD key only works
in VCR Mode).
• If you are trying to turn on an RCA,
GE or PROSCAN component, press
the component key (TV, VCR, DVD,
SAT, AUX1, AUX2) instead of the
ON·OFF key.
• If you’re trying to change channels,
try pressing the OK key after
entering the channel number as this
is a requirement of certain models
and brands.
*There is a possibility that a
programmed code may only be able
to control some of your component
features (e.g., only turns a
component on and off). Follow the
steps provided for programming the
remote (See Programming sections
on pages 5–7). If the component can
be turned on and off, make sure you
press the CH+/CH- key to see if the
component responds. If not, try the
next code from the list.
Good Luck :)
PLEASE rate my solution
Dec 18, 2009 | RCA DIRECTV Satellite Remote Control
I have a durabrand tv and need to figure out how to take sap off the tv. the tv is model DU2701
on the remote there may be a button marked MTS. if so press this button (toward tv) repeatedly till stereo mode displays. otherwise go into tv menu under audio section and scroll to parameter that allows you to adjust mono,stereo, or sap mode. mch
Mar 09, 2009 | Televison & Video
RTD170 Aux Surround
the manual for a rca rtd170 shows how to hook up the audio on the system for a sat. dish,but not for the video, how do u hook up the sat. reciver to the rca tv and rtd170 system?
Sep 28, 2007 | RCA RTD170 System
Televison & Video Logo
241 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
