Question about Texas Instruments TI-5045 SVC Calculator
TI-5045 PRINTER ASSEMBLY paper feed roller broken and off its shaft.
After a long storage period, paper stuck to soft rubber paper feed roller. Pulling ******* paper split the rubber roller and it came out. Now paper will not feed. Is a new printer assembly module available somewhere?
  • 3 Answers
SOURCE: Texas Instruments TI-5045 SV paper won't advance
The foam on the feed roller is probably decayed/ soft. Which has caused the plastic gear that engages that drive gear to wear. If the gear is moved/ spaced over to pick up the 40% that isn't trashed - it'll feed.
I'm going to try to fix my Goodwill purchase anyway. Anything is better that the Canon piece of rubbish I have now. Mybe someone can tell Canon that a few months of use is not enough?
-Sano-
Posted on Dec 31, 2008
SOURCE: Need new ink roller for TI-5045 SV
Try www.fjaproducts.com Nu-Kote NR-78BR ink rollers - worked for me!
Posted on May 15, 2009
You can get Nu.Kote Calculator Ink Roller NR42 from any office supply chain.
Posted on Jun 18, 2009
SOURCE: We have a TI-5045 11 calculator. It won't print
Yes it can. Go to "Office Max" look for Porelon 11203 calculator black ink roll.
Posted on Sep 06, 2009
lbrown1806
  • 488 Answers
SOURCE: Need part number for ink
part number IR-87T
Posted on Nov 25, 2010
Can't load new roll of paper
The rubber sleeve on the paper advance shaft has likely lost it's elasticity. It expands then the shaft just spins inside of it. It's tricky but I disassembled the paper advance assembly and replaced the old sleeve with a piece of small silicone tubing. Works fine now.
Mar 31, 2014 | Texas Instruments TI-5045 SVC Calculator
13.2 paper jam/open tray error, but its not. It doesn't make the right sounds when initialising, no motor running.
Hello There,
After working with HP for quite sometime,
here is what i recoimmend.
1.Ensure that paper trays are loaded properly, so that paper can feed from the tray
2.Check the input area for obstructions, such as paper in the path or visible damage to the paper path near Tray 1.
3.Remove the print cartridge and lift the green handle attached to the metal plate underneath to check for paper in the paper path.
NOTE: Try swapping the tray and print cartridge with one from different printer, same model. Determine if issue follows the tray or the print cartridge.
4.Ensure that paper is feeding correctly from the appropriate tray (try using a freshly opened **** of paper).
a.Inspect the pickup assembly by removing the paper tray in question to look inside the printer.
b.Locate the rubber roller with a purple, plastic hub (paper feed roller).
c.Locate the paper pickup assembly that is directly behind the paper feed roller. The paper pickup assembly consists of a shaft with four half-moon shaped rubber and white plastic rollers attached to it.
d.Rotate the shaft to locate the half-moon rollers and ensure that it turns easily.
e.Locate the black plastic coupler shaped like a dog bone that is immediately to the right of the shaft .
f.If either the pickup assembly or the coupler is missing or damaged, the printer will need to be serviced.
5.Do not fan paper to separate, bend the **** into a U shape to break the sheets free from one another.
NOTE: If the steps listed in this document do not return the printer to a READY state, service may be required. Contact the HP Customer Care Center for more information
Please feel free to leave a testimonial if this works and please do not forget to click 4 thumbs.
Cheers!
Mar 22, 2011 | HP LaserJet 4000 Printer
How do i load my printer paper ti-5045sv
To load paper into a ti-5054 sv calculator.
  • Turn Calculator on.
  • Press down on the front edge and slide in the direction of the arrow.
  • Insert paper on the roller so that the paper rolls out toward the bottom, and the loose end is closest to the calculator.
  • Cut of the end of the paper.
  • Insert the end of the paper into the printer slot in the back of the calculator.
  • Press the paper feed button ( karmahm_0.png) until the paper is in position.
Mar 17, 2011 | Texas Instruments TI-5045 SVC Calculator
Double printing on pixma mp470
Double printing or double feed??. Double printing means document printed in 2 copies. Double feed means printer feed double paper in one moment. For double printing,please check number of copy of document in printing preference properties.
Double feed occurs when pickup roller fails to pick the paper correctly. It's usually caused by shaft of paper pick up roller which is broken. You should replace drive assembly (include pick up roller) in this case
May 13, 2010 | Canon PIXMA MP470 All-in-One Printer
Stuck paper in printer
the only solution for this is to dig it out
remove the paper feed cartridge, open the printer up and remove all corona wires, and anything that will slide out
look to see the feed rollers and try lifting on the rollers with your fingers to take any tension off of the top roller always try to remove the paper from the feed area slowly work the paper out if you still see small piece of paper try working them out with a stiff piece of index stock
avoid damaging the rubber rollers with a sharp object and by all means do not force the feed rollers they were designed to move in one direction..towards the copy area a pair of tweezers and hemostats work very well
the fact that the paper went in sideways lends me to believe you have a fed roller problem or an obstruction
once you clear the jam cean the feed rollers with soft cloth and alcohol
good luck
Dec 03, 2008 | Brother HL 1440 Laser Printer
Paper does not feed completely properly.
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
If the error still exists then its the problem with rollers it needs to be serviced..
Good luck..
Nov 13, 2008 | Lexmark P4350 All-In-One InkJet Printer
Lexmarkx73 Won't feed paper through while printing
Jul 13, 2008 | Lexmark X73 All-In-One InkJet Printer
Paper tape in my TI 5045, please.
Feed the paper in the back press the paper advance button while pushing the paper in the rear slot, and it should feed the paper through.
Hope this helps.
Good luck.
Mac
Feb 08, 2008 | Texas Instruments TI-5045 SVC Calculator
-Sano-
Oct 03, 2007 | Texas Instruments TI-5045 SVC Calculator
Texas Instruments TI-5045 SVC Calculator Logo
240 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
