Question about Philips Magnavox Learning Universal Remote
PHILIPS CL034 UNIVERSAL REMOTE
LOST MANUAL .. NEED TO KNOW HOW TO SEARCH FOR VCR AND TV CODES AND WHICH BUTTON TO HIT TO SAVE CODE ONCE I FIND THEM OR THE CODES FOR TOSHIBA TV AND RCA VCR
THANK YOU
  • Anonymous Nov 14, 2008
    lost the manual sheet
  • 689 Answers
Hi
I am attaching a link that you can obtain free user's manual which contains step by step instructions and code list. Click on the link below
http://rsk.imageg.net/graphics/uc/rsk/Support/ProductManuals/1500115_AD_EN.pdf
Good Luck
Posted on Nov 10, 2008
I have a phillips CL034 universal remote need code for sharp tv
this should work:
SETTING CODES
HOLD THE CODE SEARCH BUTTON DOWN UNTIL THE RED LIGHT STAYS LIT.
PRESS THE DEVICE BUTTON (ie TV)
CHANNEL UP BUTTON UNTIL THE CHANNEL CHANGES. (300 SHOULD BE MAXIMUM)
PRESS THE MUTE BUTTON TO SET THE CODE
Oct 19, 2009 | Philips Magnavox Learning Universal Remote
HI MY FRIEND sreeki.
Try this site:
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
It's the manual for a Phillips remote control. The codes should be rather universal. Otherwise, there is a way to program it without using a code.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Jun 14, 2008 | Philips Magnavox Learning Universal Remote
Lost Instruction sheet for cl034
May 12, 2008 | Philips Magnavox Learning Universal Remote
Can you help me program my remote?
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Hope this helps :)
Apr 15, 2008 | Philips Universal PH301S Remote Control
Philips universal remote control cl034
hey i tried this and it worked. hold code search till the light stays lit(it may take a couple of secs ) then after its lit press tv and then keep pressing channel up or down till the channel on your tv changes when does press mute to save the code. also the power button will work to during code search , but i use channel because if you accidentally skip your code you can go back the other way. you might need to take out the batteries then re-insert to reset any previous codes. hope this works for you guys as well.
Mar 08, 2008 | Philips Magnavox Learning Universal Remote
Philips universal remote codes for symphonics tv
Hope this helps :)
Dec 22, 2007 | Philips Magnavox Learning Universal Remote
Manually turn on the device you want to control
1. press and hold the CODE SEARCH button til the light stays on release the code search button
2. Press and quickly release the desired button ( TV, DVD, etc ) the red light blinks off once
3. Press the CHANNEL UP button repeatedly ( up to 300 times ) til the device changes channel and stop
(the red light will blink off after each time the channel up button is pressed )
4 Press the MUTE button to set the code
hope this helps
Nov 23, 2007 | Televison & Video
Codes for a universal remote
i have a philips remote and it is a cl034 and i can not program it without the codes for it
Oct 14, 2007 | Big Button TV Universal Remote
Philips Magnavox Learning Universal Remote Logo
2,107 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
