Question about Memorex MVT2195B Combo
Comcast remote The remote that came with Comcast cable tv is supposed to control the TV as well. But all the included programming codes don't work. Does anyone know what code will work? The remote is "Comcast Custom DVR 3-Device Universal".
SOURCE: Programming Device Control code for Memorex MVT2135B
21479 is the Sansui code that worked for me with the Memorex TV/VCR combo MTVT2135 and the Comcast Custom DVR 3 Device remote.
Posted on Apr 17, 2010
0 characters
1 Points
Need a remote code for comcast dta to work with my GPX TDE1380 tv dvd combo
There is no setup codes for GPX with Comcast DTA remote control.
Apr 23, 2012 | GPX TV6000 9 in. TV/DVD Combo
I don't have a code to program my comcast remote to my tv.
I ahve same problem with my Coby tfdvd3297..I found that code 11265 works to comtroll t.v. (volume& power) but have not found a code to cotrollbuilt in DVD player..hope it works for you.
Dec 29, 2010 | Coby TVDVD1350 13 in. TV/DVD Combo
What is the comcast cable code for this tv for the digital box
Comcast remote codes for Emerson TV are:-
10154, 10451, 10236, 10463, 10180, 10178, 10171, 11963, 11928, 11913, 11911, 11909, 11905, 11665, 10282, 10280 10270, 10183, 10181, 10179 10177, 10038, 10019
You have to check with each code, until you find which code sets for your TV
programming TVcontrol
The Comcast Digital Adapter remote control is pre-programmed at the factory to operate the Digital Adapter. The Comcast Digital Adapter remote also contains a universal TV library to allow you to control the Power and Volume of your TV.
1. Turn on the TV
NOTE: Please read steps 2 to 4 completely before proceeding. Highlight or write down the codes and device you wish to program before moving on to step 2.
2. Press and hold SETuntil the Red Light blinks twice, then release SET.
3. Locate the code for your device in Manufacturer's Codes on the back of this user guide. Brands are listed in alphabetical order with the most popular codes listed first.
4. Enter the first five-digit code for your TV. If you perform this procedure correctly, the Red Light will blink twice
NOTE: If you enter an invalid code, the red light will display one long blink and exit the programming mode. Repeat steps 2 to 5 with a valid code.
5. Aim the remote control at your TV and press Power once. The device should turn off. If it does not respond, repeat steps 2 to 4, trying each code listed for your brand until you find one that works. If it still does not work, try Searching For Your Code.
If your brand of TV does not respond to the remote control after trying all of the codes listed, or if your brand is not listed at all, try searching for your code.
1. Turn on your TV.
3. Enter in 9 - 9 - 1. The Red Light will blink twice.
4. While pointing the remote control at the TV and press and release the CH + key until the TV turns off. (Note: You may need to press [CH+] numerous times).
NOTE: In the search mode, the remote control will send IR codes from its library to the TV.
5. Press SETonce to lock in the code. The Red Light will blink twice.
Dec 03, 2010 | Emerson EWC1303 13 in. TV/VCR Combo
I need to program my cable box
The real problem with the Comcast remote is that there is no other brand, it's not like a Sony remote that's relabeled or anything. Fortunately, Google helps again, and it turns out Comcast has a page online about programming the Comcast remote control.
comcast_remote.jpgComcast 3-in-1 remote control To program the remote to work with your Sony TV, you need to take the following steps:
  1. Find the code or codes for your TV from Comcast's list [PDF]
  2. Turn your TV on
  3. On the remote, press and release the TV key on the very top of the remote.
  4. Press and hold the Setup key, until the "TV" key flashes twice, then release the "Setup" key.
  5. Using the number pad, enter in the first 4-digit code found next to your television brand on the chart. If you do this correctly the "TV" key will flash twice. Now it's programmed!
  6. Now point the remote at your TV and press the Power key. If the TV turns off, you're golden. If not, try again with the next code on the list.
Jun 01, 2010 | Symphonic SC3919 Combo
Need remote control code for Panasonic PV-DF2703
I found a newer Comcast PDF file that shows a 5 digit number for tv with vcr ( no mention of DVD) but the code worked to turn on the tv and cable box together. My problem is it won't work the volume, yet
Dec 24, 2008 | Panasonic PV-DF2703 Triple Play 27 in....
13" superscan remote with comcast
all cable networks have a manual that shows how to us the R/C [remote control] to SCAN ALL model #s of tvs for all the codes. If you don't have the manual, call Comsast Cable & they should be able to help you.
Note: sometimes a cable network cannot control all TV's R/C because some companies BUY off excess tvs and place their name on the brand.You could be buying Zenith, Sony, RCA !! guts with E.I. "superscan" brand on it.
P.S. sometimes the code is just enought to turn the tv on, raise\lower volume.
Jun 24, 2008 | Combination Televisions
Jan 20, 2008 | Memorex MVT2135 13 in. TV/VCR Combo
DTV remote code
Don't know if this will help but I have Comcast as my cable TV provider and am using a Motorola DCT-6200 STB and the remote Comcast provides with the STB. To get my Panasonic TV/VCR combo (PVQ-2510A) to work with the Comcast remote I had to do the following:
1) Do the remote code search in AUX mode (or VCR or DVD mode if your remote has that button instead) using the instructions for searching ing remote codes. I had to toggle back and forth between AUX and POWER on the remote until the TV turned off. I saved that code on the remote, but it only controlled the power on the TV, not the volume control.
2) Next I did the remote code search using the TV button on the remote and toggled between the TV button and the volume control until the volume +/- bar appeared on the screen. I saved that code too.
I use the AUX button to turn the TV on and off. Once the TV is on the volume control on the remote operates the TV volume normally. I still need to toggle between CABLE and AUX depending on which device I'm controlling, the cable Set Top Box (STB) or the TV. You may have to experiment some to get it to work correctly.
Here's a link to the remotes Comcast is providing in my area.
Dec 23, 2007 | Panasonic PVQ-2510 25 in. Combo
I need a Universal Remote code for this model.
I got it to work with code 12002. I have the Comcast DVR Remote.
Dec 04, 2006 | RCA 20F510TD 20 in. TV/DVD Combo
Combination Televisions Logo
Top Memorex Combination Televisions Experts
Are you a Memorex Combination Television Expert? Answer questions, earn points and help others
