Question about Toshiba Satellite A135-S4527 Notebook
Broken laptop's hard drive
Hi everyone! I have a laptop that has a bad power supply and won't turn on.  Instead of fixing it, I decided to purchases a macbook.  Is there any way of getting my data off of my old toshiba laptop?  Thanks for any help.
  • 345 Answers
If you take it to a computer repair store, they should be able to get your data from your drive, however, different places charge different prices for such a service and it might turn out not to be cheap to do. The only other way would be to find a friend that has a 2.5 inch to 3.5 inch IDE hard drive adapter so the drive can be slaved into a desktop PC and the data can then be moved on to a burnable CD or USB drive
Posted on Nov 09, 2008
My 500gb iomega external hd model : MDHD-UP . is not working i think its the power supply that has a problem because my friend use the wrong adapter instead of the right one 12v he use my laptop's
Hi sir/madam
Use only 12v adapter for your drive...purchase same volt adapter...
Still not working remove the casing of iomega , connect it as internal drive on desktop ..
If it is under warranty pls go for service centre
Sep 21, 2017 | Computers & Internet
Error codes keeping you from using your lap top computer?
If you are receiving error codes on your computer most likely thye hard drive has a bad sector. Hard drives last approxamately 5 to 10 years depending on useage. If shut down improperly by powering off the power button the drive will go bad. This cause is the number one problem destrying a hard drive. No need to pull your heair out. Just purchase a new drive and not a rebuilt. Rebuilts do not have a warranty as a new one does and rebuilts do go out wiy=thin months most of the time. The BIOS in your computer is set up to accept any Windows disc for your programming. Here is $10 to $20. After installing the NEW hard drive you simply install the disc and turn on the computer. You will follow simple instructions to get you computer running again. If you love your old computer you will save money repairing it instead of purchasing a new one instead
on Dec 17, 2010 | Computers & Internet
My screen is not working at all,, i master rest it then i took off the battery multiple times also my sim card and nothing works!
are the lights on the laptop burning when you turn it on and is the hard drive spinning ? If not, it's more likely you have a problem with the power. maybe the power supply is broken, is there a light on this that you can check ? If it's broken the battery won't charge and nothing works.
May 03, 2011 | Computers & Internet
My HP S3700Y constantly lock up, both while surfing the web and checking e mails? This is the second hard drive, as the first one went bad after only 5 months of use, so I am absolutely beside myself at...
Was a new or a refurbished hard drive was purchased? If new Replace the power supply instead. The power supply can cause hard drive failures even on new hard drives. Never purchase a refurbished hard drive neither
Feb 26, 2011 | HP s3700y PC Desktop
Power loss in external harddrive
Hi mjcole,
Couple things. What model WD drive do you have? Plugging the laptop adapter into the drive chassis may have fried the chassis. You can buy a new chassis and put your drive into it, or you can buy a new power supply in case the one you have has gone bad and you did not realize it. Not likely though.
The power requirements are very specific and the laptop power supply may have been to much for the WD drive.
Feb 12, 2010 | Western Digital Elements powered by WD 320...
HP DV9000 LAPTOP WONT TURN ON. Christmas time is here and all the pictures that i have took of family and my daughters are lost. I can not turn this expensive peace of **** on, the blue lights around the...
Sorry you are having problems during the holiday season.
All may not be lost. If your hard drive (inside the laptop) is good, even tho the laptop won't power on, your pictures should be OK.
Have you tried connecting the laptop directly to the wall, in case you are connected to a power strip that's faulty.
Is the screen dark, but there is power to the laptop (lights on) ?
Have you tried connecting a monitor to the laptop (if you have one) to see if your display is bad ?
Have you tried connecting the laptop with the power adapter, but without the battery ?? That could determine a bad battery.
If you wiggle the power adapter at the point where it connects to your laptop and the power goes on and off, your power jack is faulty.
Lots of questions, I know. But, hopefully this will lead us in the right direction.
Dec 19, 2009 | HP Pavilion dv9000z Notebook
Asus p5kpl-cm boot problem
Could possibly be a fault on your hard drive the same happened to me ,I checked the hard drive on another pc and it was dead..Good luck John
Aug 02, 2009 | ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7...
Maxtor personal storage 3200 - flashing green light.
First, disconnect the power cable from the back of the external hard drive:
If the power supply LED continues to blink:
  1. Connect the power supply to a different outlet (or instead of connecting to a power strip, connect directly to an outlet in the wall).
  2. If the power supply continues to blink after changing outlets, this indicates that the power supply is defective and needs to be replaced.
  3. If the power supply stays solid, then reconnect to the external hard drive and see if the drive spins.
Jul 01, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Laptop overheating
I understand that your notebook heating up and restarts automatically.
The issue might be with the Fan of your notebook or Hard Drive .
To isolate the issue please perform hard drive self test. This will display whether your notebook hard drive is good or have gone bad. If the hard drive self test result is bad/fail. Then, I am afraid that you need to replace hard drive of your notebook.
To perform Hard Drive self test, here are the steps.
1. Restart the notebook.
2. Tap the F10 key as soon as the HP logo appears.
3. Using the arrow keys, navigate to Dignostics Menu and start the Hard Drive self test.
4. Once finished, navigate to Exit Menu, select "Exit Discarding Changes".
If you are using XP operating system in your notebook. Then in the 3rd steps navigate to Tools instead of Diagnostics.
If you find the above information is useful then please rate me.
Jun 22, 2008 | Compaq Presario Notebook
Used wrong power supply .
If you have used the wrong power supply, the cicuis might be shorted.
If is posible they will solder the bolder & make it work.
I dont recommend it as it will give problems again.
Its just the time to get rid of that.
Be careful in th future.
Good Luck.
Live, Love, Laugh.
May 10, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Toshiba Satellite A135-S4527 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
