Question about Epson Stylus CX4400 All-In-One InkJet Printer
On light flashing and stop light flahing
New printer. OEM ctrgs.CMY ctrgs OK. Does not accept black. Tried 3 other blk ctrgs all w/same resault. Ran user's guide troubleshooting tips all to no avail !!.........what to do ? THX JFlanker
  • danroy Jan 14, 2009
    WHen I replace the cartdiges with "compatible" 88x cartdiges it prints ONCE!!! Only one page and after that the idiot tear drop light is on...
  • sdenapoli Apr 14, 2009
    Did you figure out what is wrong with your printer as i am having the same problem?
  • 24 Answers
You might want to try a chip resetter as these carts are a smart chip design. Heres the link for one:
http://cgi.ebay.com/CHIP-RESETTER-For-Reset-EPSON-7-PIN-9-PIN-ink-Cartridge_W0QQitemZ290285956034QQcmdZViewItemQQptZPrinter_Accessories?hash=item290285956034&_trksid=p3286.c0.m14&_trkparms=72%3A1234|66%3A2|65%3A12|39%3A1|240%3A1318|301%3A0|293%3A1|294%3A50
Posted on Mar 03, 2009
Printer not accepting new black ink cartridge
put that cartridge in and perform a head cleaning process, and allignment... follow the procedure (2 or 3 times if needed) and in the end, shut down the printer, disconnect usb cable (both end), then wait for some time, aprox. 20 sec. and then put both end in again, turn printer on and wait for ready signal or some sort of confirmation that all is ok... If not, replace or update the printer driver and software, or reinstall all printer software.
Apr 22, 2014 | Epson R1900 Printer
IP3300 doesnt recognise the inkcartridges-service error 6502
could you please confirm that all the stick stuff is off the chip on the cartridge, and check the pins on the printer side were the cartridge fits is clean.
Jun 30, 2017 | OEM Systems PIXMA iP3300 Photo Printer
All the lights keep flashing --won't print!
I removed the black ink cartridge that was REFILLED at a popular retail outfit and replaced it with a remanufactured one I bought on the web. As soon as I closed the lid, the flashing stopped and it has been working GREAT ever since. Many postings had already recommended the changing to a "new cartridge" to remedy this flashing lights and "pen failure."
Jan 14, 2010 | HP Photosmart 2410 All-In-One InkJet...
MFC-420CN refuses to recognize or use black ink
The print head is clogged.Try powerful cleaning:
Press menu, then start black copy, then four times arrow-up quickly after another.Machine will be in maintenance mode
(all lights will flash).
Press 7-6-4 and OK (or start-black-copy).
When finished press 7-6-3 then start black copy,
printer will do a power purge.
Leave maintenance mode by pressing 9-9.
If this not help better think about new printer, because cost of repairing this one is profitable.
Nov 25, 2009 | Brother MFC 420CN All-In-One InkJet...
Blue does not work properly after cleaning several times. Is there something else I can do. I have changed cartridges as well.
If cyan ink cartridge is not OEM, try with OEM ink cartridge.
Nov 18, 2009 | Brother Multi-Function Center MFC-240C...
Stripes on Images only - Text OK
Perhaps the CMY color heads need alignment. If you have not already done so, run a head alignment from the driver maintenance section. It will print out a page containing several lines and text, and request you select the closest-aligned images. After this is done, do another image print to check for improvements.
Normally, the printer uses the black cartridge for text and the CMY inks for images (even for black on photo and specialty paper). So when you are printing normal text pages on plain paper, only the black ink is used. A good check for this would be to print a normal text page, but select photo paper in the driver to trick the printer into using the CMY inks to make a substitute black text page. If this looks ok, then you are having issues other than cartridge alignment.
May 24, 2008 | Canon BubbleJet i560 InkJet Printer
Printronix P7210 Ribbon problem
Call 800-854-3181 to talk to a LIVE tech support which is located in the US.
Mar 03, 2008 | Printronix Line Matrix P5210 Printer
SC 441
Hi there the following is the description from the service manual hope this helps you Thanks J
441 PCU (CMY) motor error
The drive motor of the CMY
PCU is not locked.
• Defective gear
• Voltage between pins 2 and 14 (CN12 on engine
control board) abnormal (not +24V), or pin 12
(CN12 on engine control board) unable to send
motor clock
• Defective CMY PCU drive motor
1. Replace the CMY PCU.
2. Replace the engine control board.
3. Replace the main drive unit assembly.
I would try replacing the CMY PCU (Drums (Photo Conductor Units) first before any of the others.
Thanks J
Jan 06, 2008 | Ricoh Aficio CL2000 Laser Printer
Black stopped printing out. Dell 922 all-in-one ink jet.
clean contacts on back of blk cart and printhead with alcohol on micrfiber towel
Oct 14, 2007 | Dell 922 All-In-One InkJet Printer
Epson Stylus CX4400 All-In-One InkJet Printer Logo
269 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
