Question about Toshiba Satellite A105 Notebook
Toshiba A10 laptop screen
The screen on my laptop is very dark, unreadable, it works fine with an external monitor, a friend replaced the inverter and it made no difference.
  • 37 Answers
Have tried at all to change some of the basic settings on it? Or is it too hard to even read it to get to the settings? It could be something wrong with the LCD as well, in which case, there is not much you can do.
Posted on Nov 09, 2008
A125 monitor is dark
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Feb 02, 2013 | Toshiba Satellite Computers & Internet
My toshiba laptop will boot when I power up but the screen stays black
Jeff, connect an external monitor for a diagnostic test.
Laptop OFF, monitor OFF, connect a VGA monitor to the VGA port on the back of the laptop,
(RGB/Monitor connector,
http://en.wikipedia.org/wiki/VGA_connector )
The external/VGA monitor can be a CRT type (Looks like a small TV), or a flat LCD screen that has a VGA cable.
Turn the external monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By default the display should show on the external monitor. If not press, and hold down on the Fn key, and tap the F5 key. (One of the Hot Key's)
If the display still does not show, hold down on the Fn key, and tap the F5 key again.
There are three display options;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external monitor
3) External monitor ONLY
If graphics show on the external monitor, you have a problem in the Display Assembly, and/or the Video Cable.
If graphics do Not show on the external monitor, you have a problem with the graphics chipset on the motherboard.
(ATI Radeon 3100)
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-Pro-L450-L455/laptop-disassembly-1.htm
Video Cable
1) Could be the connections. The connection of the video cable TO the motherboard, and the other end of the video cable TO the back of the LCD screen. (In the Display Assembly)
2) Could be damage to the video cable. Check the sheath of the cable for obvious signs of damage. If so, the thin tiny wires inside may be damaged also.
Cable should be checked for continuity of each wire in the cable. (Ohm's with a multimeter)
Video Cable condition, and tightness of connections check out, it's on to the screen Inverter.
Primer:
An LCD screen does not produce light by itself. It needs an additional light source.
A Backlight is the additional light source.
A Backlight is a CCFL, or a series of LED lights.
The Toshiba Satellite L455D-S5976 Notebook PC, uses 1 single CCFL for a Backlight.
Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
A screen Inverter is used to convert the power (Electricity) from the laptop, for the LCD screen, and Backlight.
90 PERCENT OF THE TIME the fault is the Inverter.
The screen Inverter is a small rectangular circuit board, and is located behind the Display Bezel, an at the bottom of the LCD screen,
Example of screen Inverter,
http://www.battery-stores.co.uk/laptop-inverter.php/toshiba_Satellite+L455D-S5976_205_5226.htm
Link to a free Service Manual for the Toshiba Satellite L455D series of Notebook PC's,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-toshiba
Under the main Toshiba heading go down to the subheading -
Satellite A10. (A10 is in blue)
In this 'paragraph' go down to the third line, and scroll across to -
L450D, in blue.
Click on L450D.
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name { L450D } it may take up to 30 seconds before the first page comes up.
Would appreciate it if you would post back in a Comment with your findings.
Regards,
joecoolvette
Jan 15, 2012 | Toshiba Satellite L455D-S5976 Notebook
Thinkpad T20 display is very, very dark (unreadable). Does the display need to be replaced ?
1. Test using an external monitor. If it works, then either the screen bulb or the inverter board might be defective.
2. Test the inverter. Easiest way to do it if you have a good screen with a good bulb. Connect the good screen to the inverter board & test it. If it lights up, then the inverter board is good. If it did not, then the inverter board is bad & needs to be replaced.
3. If the inverter board is good, then we are left with the possibility that the screen bulb is bad. To fix this, we will need to replace the LCD screen.
Oct 08, 2010 | IBM ThinkPad T20 2647 Notebook
Your Question My Toshiba Satellite m115 will boot up but the monitor wont light up, you can see the images in the back round but the screen is dark. if i connect to external monitor the external monitor...
Diagnosis:
Oct 07, 2010 | Toshiba Satellite M115-S3094 Notebook
My screen on toshiba notebook only show blank screen. The screen is not dark but has light . If i hook an external monitor it show on external but not on the laptop. I have replaced LCD screen but still...
How about the LCD inverter? Did you replace the inverter? It is probably not the actual LCD but just the inverter that needs changing. Give it a go, they are inexpensive, try eBay.
Apr 01, 2010 | Toshiba Satellite A135-S2276 Notebook
My brightness control does not work just turned on and can not hardly see anything it is up and running what now
Have you tested it with an external monitor?
I would say you either have a damaged inverter board or screen baclight lamp. Usually the inverter board fails in one of the following ways:
1. When you turn on the laptop, the screen lights up for a short period of time and then goes dark. You still can see an image but it is very dark, almost invisible and definitely not usable. When you restart the laptop, the screen lights up and then goes dark again. The laptop works fine with an external monitor.
2. Your laptop turns on but the screen remains dark all the time. You still can see a very dim image outline. The laptop works fine with an external monitor.
3. The laptop screen works fine for hours or even days, but sometimes it goes very dark as it mentioned above. When you restart the laptop, the screen works fine again.
Inverter failure symptoms are very similar to backlight lamp failure symptoms and in most cases you cannot tell which one is causing the problem until you replace either the inverter board or the backlight lamp. From my personal experience, inverter boards fail more often than backlight lamps. If you have to guess, replace the inverter first.
Mar 24, 2010 | Dell Inspiron 1545 Notebook
VERY Dim screen after a drop
Mar 24, 2010 | Sony VAIO VGN-NS190J/S Notebook PC
Dark unreadable screen
If you see a dim image or flicking image on the LCD screen it means you have a backlight problem.
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 13, 2009 | HP Pavilion dv6000z Notebook
Compaq r3000 dark screen
If you already replaced the inverter and the screen still continues dark, you need to replace your lcd screen. Your video card is good due you have signal with external monitor.
Sep 18, 2008 | Compaq Presario R3000 Notebook
Display is very dark
Dim screen is usually caused by a bad inverter board especially if you get video to external monitor. Usually cost $100-$200 depending on laptop.
Hope this helps!
Jun 11, 2008 | Toshiba Satellite M45-S331 Notebook
Toshiba Satellite A105 Notebook Logo
90 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
