Question about LG GCE 8240B CD-RW Burner
Cd-rw drive I have the cd-rw/dvd-rom combo drive. my dvd works fine but my cd-rw drive will not read cd's.Can you help?
5 Suggested Answers
  • 1019 Answers
SOURCE: Sony CRX300E CD-RW/DVD-ROM Combo - DVD doesn't read
do you have software/program that supports DVD.
Try a different DVD/Movie/Disk or alternative.
Also install a program, such as Nero which will give you physical characteristics of the drive.
Finally go to device manager, and remove or uninstall the device, reboot the computer and setup again. This can sometimes remedy the problem.
ensure that the drive is set as Master/Slave. if on the same Bus/IDE channel as a hard-drive. set as master/slave opposite to what the hard-drive is setup as.
Hope this helps.
Mike @ Compurepair.
Posted on Feb 24, 2008
AldRezaine
  • 995 Answers
SOURCE: My LG combo drive HL-DT-ST RW/DVD GCC-H23Ndoes not
The lens for reading dvd is busted and needs to be replaced that is why it no longer read dvd.
Posted on Oct 31, 2009
jepito
  • 216 Answers
SOURCE: TSST corp CDRWDVD TSH492B - DVDCD-ROM drive not working
use this tool to reset the cd in the registry
after you run the file - reboot the computer -
http://www.dougknox.com/xp/utils/XP_CD-DVD-Fix.zip
Posted on Dec 30, 2009
  • 113 Answers
SOURCE: My Samsung CD-RW/DVD-ROM Combo Drive
try these steps
) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
* HKEY_LOCAL_MACHINE
* SYSTEM
* CurrentControlSet
* Control
* Class
* {4D36E965-E325-11CE-
BFC1-08002BE10318}
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
* UpperFilters
* LowerFilters
* UpperFilters.bak
* LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7) Reboot your computer
Posted on Jul 06, 2010
My sony CRX320EE CD-RW/DVD-ROM COMBO Drive is not read a dvd
im having sony CRX320EE combo drive. it can read cd but cant read dvd. plz help
Nov 12, 2009 | Sony CRX320EE CD-RW/DVD-ROM Combo Drive
I can burn cd's but not dvd's
Hello Rfd832,
What I see from the description is that the drive is a combo drive. Combo drives are CD-RW and DVD-ROM drives means
CD-RW = Compact Disk-Read Write
DVD-ROM = Digital Versatile Disk - Read Only Memory
so these drives can read and write CDs but can only read DVDs (Cannot write or burn DVDs)
If you want to be able to burn DVDs then you need to have DVD RW drive (either DVD+RW or DVD-RW)
You said that you are able to burn DVDs on other computer so please check the label on the DVD drive.. it should be DVD-RW/DVD+RW drive
Hope that helps.. :)
Thanks and Regards,
Srinivas
Apr 12, 2009 | HP (dc197x) CD-RW/DVD-ROM Combo Drive
DELL laptop does not read blank DVDs
the combo drive you listed above is a cd-rw/ DVD-ROM....meaning that it will play and burn cd, cd-r, and cd-rw disks. the dvd rom will only be able to play dvd-rom and dvd-r disks providing they are in the proper format. check that the disk in question is not a dvd-rw or (+2) disk. the drive will not recognize that a disk is in the drive if the disk isnt compatable. try a dvd movie, if that works then a dvd-r, if that works then try a dvd-rw +1. if the last option doesnt work then you will have to stick with the dvd-rom and dvd-r, or purchase a dvd-rw drive to install.
GOOD LUCK AND DONT FORGET TO RATE MY POST!! :D
Mar 18, 2009 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
CD-RW/DVD ROM Combo
no you want a dvdrw or dvd burner
combo only burns cd's and reads dvd's(not write/burn)
Jan 05, 2009 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
LG GCA-4080N internal drive
It seems that what you have is a combo drive only :(
it only recognize DVD reading. no matter what driver you used. need to buy a dvd writer/ that said can write dvd.
Types of Optical Drives and CD/DVDs
Optical drive type Read from CD/DVD-ROM media Write to CDRW media Write to DVD ±RW/R media Write to DVD +R DL media Write label to LightScribe CD-RW Write to DVD-RAM media DVD-ROM Drive Yes No No No No No DVD and CD-RW Combo Drive Yes Yes No No No No DVD±RW/R and CD-RW Combo Drive with Double- Layer support Yes Yes Yes Yes No Yes LightScribe DVD±RW/R and CD-RW Combo Drive with Double- Layer support Yes Yes Yes Yes Yes Yes Blu-Ray Disc DVD±RW SuperMulti Drive with Double-Layer support Yes Yes* Yes Yes No Yes *Low speed (4X) and high speed (4-12X) are supported. UHS-RW (24X and 32X CD-RW) is not supported.
NOTE: Some of the optical drives listed may not be supported by your computer. The listed drives are not necessarily all of the supported optical drives.
Dec 26, 2008 | LG (GCC4521BBULK) CD-RW/DVD-ROM (Combo)...
Not reading dvd combo drive
HL-DT-ST RW/DVD GCC-4522B
h!, above is the model type of my combo drive dvd. It does not work anymore, it only reads a cd format but not dvd..can you pls help me with this..my personal email address hpbirco@yahoo.com pls send me ur answer to my problem..tnx
Sep 03, 2008 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
Lg dvd rom driver/combo drive
Dirty or out of alignment drive...accordianman
Feb 28, 2008 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
Combo drive not reading DVD
my combo drive also not reading dvd :(
Dec 23, 2007 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
Cant play DVD on CD-RW/DVD-ROM Combo Drive
Assuming you have tried different makes of cd or dvd disks, it's a classic drive failure problem where the laser can no longer burn or read dvd's, but may still be able to read cd's only. You will have to replace the drive, they are quite inexpensive, and very easy to fit.
Aug 10, 2007 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
LG GCE 8240B CD-RW Burner Logo
44 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
