Question about Acer Aspire 1710 Notebook
Backlight fluorescent lamps died
About after 1.5 year one lamp died in a month the second one.
What I can do with this problem?
  • dank84 Jan 30, 2009
    Backlight lamp no longer working in my acer 1710 laptop. Is there any way to replace or fix this issue?
  • Justin Case
    Justin Case May 11, 2010
    Hi there ego,
    You didn't mention in your post, so I need to ask: What is your level of expertise in the diagnosis and repair of Notebook Computers?
    I ask because after thirty years of programming in thirteen languages, being an expert in the operation, maintenance, diagnosis and repair of data processing machines ranging from mainframes to PC's, I have only the most cursory knowledge of the problems specific to laptops and notebooks.
    They require additional training. Often training is geared to specific makes and product lines.
    That knowledge I do have was gained by repairing my own company's laptops. The first thing I learned was this was the training I mentioned was absolutely necessary.
    Experts
    here volunteer their services. Their only compensation may be the
    satisfaction of helping others and pride in the ratings they receive.
    They freely give you, The Asker, the benefit of decades of experience for exactly zero pay.
    Some people come here looking for a simple fix (press the the Ctrl-F key and all your problems will be solved) when one simply does not exist. Magic 'One Liner' solutions are rare.
    And sometimes in the best interests of the Asker, the best advice is to take your equipment to a qualified technician.
    This advice is given when there is ether a danger of injury or death to an untrained person attempting repair or an attempt to make repairs will result in permanently damaging the equipment. I see that to be the case here.
    So I ask you again, what is your level of expertise?
    If it is anything less than A+ certification with a backround in laptops, I would
    like for you to reconsider the 'Inappropriate' rating you gave Jazzy.
    This
    rating is worst type of insult. It should
    only be used in the rare case that the advice you received was totally
    irrelevant to the problem or outrightly profane in which case should be
    reported as abuse.
    Neither one of these was the case here. Your rating
    of Inappropriate is the only inappropriate response appearing in this
    thread.
    At the very least, he earned a Helpful.
    If you had made the mistake of opening your machine up, then tried to reassemble it after you realized you were in too deep, I guarantee you would have rated his advice a FixYa retroactively in exchange for not having done it.
    You
    blasted a lot of hard work, reduced his rank and the smeared the reputation of someone that was
    not only trying to help you, but was doing it for free. Doesn't exactly make you feel all warm and fuzzy, does it?. I would think this is something you would want to
    rectify.
    Also keep in mind that Experts here pick you, not the
    other way around. An Asker who doles out IA's for helpful advice
    without any interaction, even as a mistake (which I'm hoping it must
    be)
    is unlikely to be helped by a second Expert.
    That includes future problems too. It depends on you either getting that IA removed
    or improved. Until then, you have already received the only help you are likely to
    get.
    It's a Karma thing. I don't make the rules, I'm just letting you
    know you shot yourself in the foot.
    You know how to fix it.
    You know
    you should fix it.
    So take 15 seconds and Fix it.
    The balls in your court.
    Good luck and have a nice holiday.
    Mike258
  • 4,234 Answers
This note is primarily in response to dank84:
The "backlight" is built-in to the display panel itself, so there is no way to replace the lamp itself. In most cases, it is the "ballast" that has gone bad. This is a small board either on the side or bottom ofhte top case. There are a number of reasons for this to fail. Many times a bad battery or weak charge can cause extra current draw that pops a soldered fuse on the board. Other times, capacitors fail. Still others, the onboard transformers that convert the "low" voltages to "high" voltages required for the flouresceent lamp to fire go bad.
The bottom line is that this is not a consumer type of repair in most cases. Depending upon the age of the laptop and the skills of the local servicer, this may not be an econimical repair.
Dan
Posted on Jan 30, 2009
  • 728 Answers
You will need to get it checked at a shop because you might have a short that is causing too much power to go to fluorescent lamps and is making them die.
Posted on Nov 09, 2008
WHY DOES THE SCREEN STAY BLACK AND THE VOICE COMES ON?
First off, it is not a picture tube if it is a flat panel. It is either a plasma or LCD screen. It is possible that the backlight circuit or backlight itself has failed. This is not uncommon on units once they reach approximately the three-year-old mark, especially the units that are backlit with fluorescent lamps rather that LED lamps.
May 06, 2015 | Televison & Video
Stays on a few minutes than flashes goes off while still hear voice
Sounds light a bad backlight or an inverter board issue. The fluorescent lamp that supplies the brightness can be bad or the board that provides the current for the lamp is faulty. LCD TVs have an average life of 3-5 years before backlight problems. That is why almost all new TVs today are LED backlit.
Aug 24, 2014 | Sony BRAVIA KDL-52X2000 50 in. HD-Ready...
Samsung 2233RZ going black after 1-2sec
First if you can, try the monitor with other PC first to make sure it is not the PC problem.
If it behaves in the same fashion, then most probably has dying power supply due to bad DC filter caps, just see the top side of the caps to ensure it has not bulged up distorted.See the images bellow
12_24_2012_5_33_15_pm.jpg OR
Then there is the logic board. Plug the monitor in but do not activate the power switch so the backlight inverter circuits will be off. Check the 5vdc and the 12~24vdc to make sure they are OK. They should be tested with the load, you can use 6V 1A (6watts) lamp for the 5vdc, and car lamps such as 1157 (12v 8watts lo/26watts high) turn signal brake lamp using high filament connection for testing the 12~18vdc (or use two 1157 in series for 19~24vdc) for the backlight inverter circuits.
If the power supplies are working, the output voltages should be steady at the rated voltages. The power supply will go into shut down if it detects too much current draw due to false in the power supply or short circuits in the backlight inverter or in the logic board.
The backlight inverter circuits:
It takes the 12~24vdc and converts it to high frequency AC to drive the inverter transformers CCFL (Cold Cathode Fluorescent Lamp) assemblies. The transformers will drive the CCFL by applying the start up voltage (around 1500~2000v), when the CCFL start conducting, the voltage will drop down to about 500~800v.
The inverter has detection circuits to detect open circuit if the lamp is not attached or does not fire up after the start up voltage is applied, it will go into shut down. It will also shut down if the lamps draw too much current due to ages (when lamp gets old it will draw more current).
The inverter gets two signals from the logic board, one is the backlight ON/OFF signal, the other one is the Dimming signal for the lamps.
Common problems:
Bad filter caps, resonant caps (in the inverter output circuits), blown transistors/IC, shorted or open transformer winding.
If you are confident with your skill then go ahead else go to an authorized outlet for repairing
Do write back if you face any difficulty while working on the monitor
Dec 22, 2012 | Computers & Internet
Toshiba satellite backlight
Mohammad,
Toshiba Satellite P100 screen Inverter replacement;
1) http://www.irisvista.com/tech/laptops/Toshiba-Satellite-P105-P100/remove-lcd-screen-inverter-1.htm
(You can click on any photo to enlarge it. At the top, and bottom of the page are the page numbers. They are in white; Page1 :: Page2 :: Find another model )
2) Primer:
An LCD screen cannot produce light. It needs an additional light source.
A Backlight is the additional light source.
A Backlight (Present technology) is a CCFL, or a series of LED lights.
The Toshiba Satellite P100 series of Notebook PC's uses a CCFL.
Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
Average size is approximately 2mm Thick, and the length is close to the height of the LCD screen. 2mm is a little larger than 1/16th of an inch.
This means the CCFL can be broken quite easily, as it is fragile. (You also DO NOT want to be cut by a Fluorescent lamp )
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
A screen Inverter converts the power from the laptop, for the Backlight, and LCD screen.
As previously stated in a Clarification, 90 PERCENT OF THE TIME the fault is the screen Inverter.
Regards,
joecoolvette
(I never request commendations, but thank you for offering.
We, the older techs here, feel that is begging.
3 years at FixYa so far.
Regards,
joecoolvette)
Mar 23, 2012 | Toshiba Satellite P100 Notebook
How to check the backlight life of my hp l1706
Claimed life for the lamp is 50,000 Hours, but in real life, no way to tell. You can look here what is failed in the backlight lamps, it can be from worn out (blacken ends is one sign of bad lamps, same as home fluorescent lamp), poor soldering works on the lamps. see pictures here: http://s807.photobucket.com/home/budm/allalbums
What is the problem with your monitor anyway?
Mar 30, 2010 | HP L1706 17" LCD Monitor
Sony KDF50E2000 lcd tv has burned out it's second bulb. Replacement bulb was OSRAM brand. It only lasted 10 months, now it won't come on. Should I be looking at the ballast or did I just get a poor...
Hi,Osram lamps average around 3000-4000 hrs.Normally 1 -1 1/2 yr.I do think the lamp went out.The ballast is a possibility,when it's going bad it will make clicking noises or attempts to light the bulb.I recommend to get the Original Philips lamp for they average 6000-8000 hrs 3-4 yrs.
Mar 25, 2010 | Sony KDF-50E2000 50" HDTV
How to FIX
Televisions have protection circuits which prevent full power-on if a fault is detected in a high voltage/high current circuit such as the backlight inverter.
Some googling on 'Sony Blink Codes' found that 4 blinks is 'backlight failure'. A common failure in LCD displays is the backlight inverter board which is a transformer similar in function to a fluorescent light ballast, as the backlights are fluorescent lamps.
If the screen color is getting pinkish/reddish, that's a sign that one or more of the lamps themselves are going bad.
Since multiple lamps are connected to (typically) two inverter boards (a primary and secondary board), I am fairly certain that the blink code refers to a failed inverter board and not a failed lamp.
Oct 19, 2009 | Televison & Video
Flickeing like a dying fluorescent light bulb
Actually this is a 'warning' signal from your lcd monitor. The problem is your lcd ccfl lamp are near to their life, need to change. The ccfl lamp like our home fluorescent lamp, when the lamp need to dead, the lamp will flickering first, after some time, will totally off(dead). So, this is a signal for you. Some lcd monitor, when their inverter board are using fairchild inverter ic(oz series), will easily shutdown your monitor when they detected some flickering on your screen (ccfl lamp). If you need more information on repair your lcd monitor please visit http://www.fastrepairguide.com . Thanks.
Jan 17, 2008 | Samsung SyncMaster 710N 17" LCD Monitor
TV flickers when turned on
this sound like panel or inverters that drive the lamps ( fluorescent lamps that are not replacable they are part of the panel).
Jan 16, 2008 | Polaroid FLM-3201 Television
E-125 Owners BEWARE!
Unless a Casio technician has looked at it don't take Casio's word for it. There is an inverter PCB which converts the DC to high frequency AC for the fluorescent back light. lamp. This is available & can be repaired / replaced. There is also an issue with the E-125 backlighting which simply requires resoldering of a connector on the main pcb. Then there is the fluorescent lamp itself which can go bad & may be replaced. So DO take your device to a well equipped competent technician to look for the precise problem.
Sep 05, 2005 | Casio Cassiopeia E-125 Pocket PC
Acer Aspire 1710 Notebook Logo
160 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
