Question about TruTech PVS31170S1W 17 in. LCD Television
Lost remote control Trutech® 19" 720p LCD TV/DVD/PC Monitor - PLV31199S1
I have lost the remote control to a Trutech® 19" 720p LCD TV/DVD/PC Monitor - PLV31199S1 and would like to buy a replacement. Can you tell me where I can buy one?
Thanks,
Madeleine
    New Friend:
Wont connect to my cable trutech 19 tv/dvd/pc monitor
Posted on Dec 07, 2010
    New Friend:
This remote code works with the Trutech PLV31199S1 19" inch TV
and will replace your lost remote with a universal remote you
have available that may work with the code.
ENTER CODE 10171 into the universal remote controller.
Basic general entry code instructions for TV remotes if you do not know how to program universal remote or lost the instructions for it as well:
Basic Set the "Mode Switch" to TV.
Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
Enter the 5 digit Code above.
To purchase a factory Trutech PLV31199S1 remote $29.95 plus $7.95 shipping:
http://www.remotecontrolscenter.com/trutech/plv31199s1.html
Twenty dollar substitute Trutech PLV31199S1 remote with free shipping:
http://www.emtcompany.com/trutech-plv31199s1-remote/rc64.html
plv31199S1 Trutech TV Factory Support:
1800customersupport.com/trutech
8664446478 8882526252
Posted on Apr 11, 2014
I cant get sound from my trutech lcd,dvr,monitor how do i hook it up
Posted on Mar 24, 2009
SOURCE:
I need the code for programming a universal remote for TruTech 19" TV/DVD serial nunber PLV31199S1
Use code search to find something that can handle some or all functions of your TruTech TV. If a search through all codes stored in the remote fails, you may have to try a different universal remote. All universal remotes do not contain all possible codes.
Dec 29, 2016 | TruTech Televison & Video
I have a trutech 3 in 1 tv , dvd , pc monitor tv mdl. no. plv31199s1 and i turn on the tv and after 5 mins. the picture goes black , but the sound remains.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should be troubles hooted. Contact any service technician. The circuit will differ with models and versions.
Mar 10, 2015 | TruTech Televison & Video
I have lost my remote control for my Trutech DVD TV....where may I locate one to purchase???
<a href="http://www.remotes.com">www.remotes.com</a> or 1-(800)REMOTES
Aug 26, 2010 | TruTech Televison & Video
I lost the remote control in mving and my manual
Try Website 1-800-Remotes Factory Original.Get the exact same remote.The manual try the tv website for a print out.
Feb 04, 2010 | TruTech PVS31170S1W 17 in. LCD Television
Needs remote which remote is best for this unit
Any of the universal remotes should work.  Check their sites on line first to see if they have codes for your TV.  I recommend a Logitech Harmony remote that is "activity based" and can control all your electronics with a single remote.
Jun 02, 2009 | Audiovox PLV31199S1 19 in. LCD TV
Remote control switch destroyed
If you get an universal remote, you won't have all functions to control the TV. Moreover, the codes for many audiovox model are often not reported on universal remote manuals , therefore you may need to use autodetect feature on universal remote.
The best choice is buying a replacement original remote like the ones below:
New Original TruTech PLV31199S1 Remote Control
$39.95 -
New Original Trutech PLV31199S1 Remote Control $39.95
Apr 18, 2009 | Audiovox PLV31199S1 19 in. LCD TV
Remote control
Trutech is made by Daewoo. Anything that works for Daewoo should work for trutech.
May 22, 2008 | Televison & Video
Trutech t2000-d remote control codes
I have the same problem as well. I bought 3 different remotes and not one will work with the tv. Although all 3 gave Trutech codes (1116, 1504, and 1713).
Feb 02, 2008 | TruTech PLV16190 Television
Hello
If your TV is an LCD (flat/thin panel), then it's 19", not 20". Support for that TV is at http://www.1800customersupport.com/trutech. But, if you have a Trutech tube TV, then it won't be listed on that website, and they won't be able to help you. In that case, call Target Customer Service (1.800.440.0680), and they should be able to put you in touch with the manufacturer, who can sell you a new remote control.
Aug 26, 2007 | TruTech PLV16190 Television
TruTech PVS31170S1W 17 in. LCD Television Logo
2,861 people viewed this question
Top TruTech Televison & Video Experts
Steve Allison
Steve Allison
Joaquim Martins
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
