Question about Sony KP-61V80 TV
Won't Turn on, standby LED lit
My Sony KP-61v80 will not turn on. When I plug it in, it almost sounds like it might turn on. When plugged in, the standby LED blinks once and then remains lit. The power button on tv or remote doesn't do anything.
tv was on then suddenly no picture and the tv is on with a lit standby timer led in front but no other activity can turn off or on
  • 10,594 Answers
Let me know do you want to repair it at own?
If yes, you should have basic electronics knowledge and good soldering work. I can guide you step by step.
Posted on Nov 09, 2008
  • 905 Answers
This is going to be a fix that requires getting into the television to do some test and measurements of components
can you do this?
    Genius:
  • 1,550 Answers
Did you check the fuse ?
Fuse can be burned out
    Sergeant:
    Novelist:
  • 196 Answers
Its the problem on the main board of the tv asnd it needs reparing.
  • mmechanics Nov 09, 2008
    may be the capacitors or the faulty ics or the blown fuse please check irt out.
    thanks.
I'm working on my 1996 model KP-53v35 Sony. The problem is that I plug it in and it tries to come on and the red LED flashes and it shuts off.
If the lamp light is blinking, then lamp needs to be replaced. If the standby light is blinking, the try resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue still persists, then the service may be required.
Jul 26, 2010 | Sony KP-53V35 53" Rear Projection...
No picture or sound, standby led flashes 11 times when first turned on after AC plug has been removed and reinserted into the AC outlet. Every attempt to turn on after the initial attempt yields 6 flashes...
It seems that your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur. The flashing LED is justa coincidence I would think.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done.
Jan 22, 2010 | Sony KP-53HS10 TV
Hello..i have a sony kp-61v80 tv year 2000
I have a sony codes for sony TVs that tell what is wrong by the blinks as soon as a can will ck it to see what it says.
Dec 03, 2008 | Sony KP-57WS500 57" Rear Projection...
4 times flash of standby light shows that TV has problem in Vertical Deflection area and possible causes are IC1509(V out) is broken and / or Q1505(V Pulse Buffer) is broken.
Please check / test above said IF you have experience of TV repair.
Nov 29, 2008 | Sony KP-57WS500 57" Rear Projection...
Sony KP-51WS510, standby led blinks 5 times
It sound like you have a bad picture tube...check your 1k circuit for correct voltage and wave form.
Oct 03, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony KP-65WS500 65 in.
Check your CRT boards on the end of the tubes for burn spots, and burnt components, check the resistors to make sure they are not shorted, burnt, and they read the correct resistance. Check the diodes to make sure they conduct in one direction only and are not shorted or open.
Mar 24, 2017 | Sony KP-65WS500 65" Rear Projection...
HI,
I am having the same problem, any solution? Thanks! -Steve
Aug 19, 2008 | Sony KP-61V80 TV
Sony KP-61V80 TV Logo
121 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
