Question about Maytag CWG3100A Gas Single Oven
Won't heat up
I have a 1997 Magic Chef. The range works as well as the broiler but when the oven takes a long to heat up. After about an hour you start to smell Gas. It takes about 45 minutes to bake muffins. Model# 31213xaw
    Problem Solver:
  • 16 Answers
You have two ignitors one for bake and one for broil your bake is not working
Posted on Nov 23, 2008
Oven Won't Heat To Desired Temp / Burner Quits Working Sometimes
The temperature sensor in the oven needs to be replaced. Here is the part to order. As far as the top element, lift the top up and look for lose or broken wires on the element. Keep me posted.
Nov 20, 2012 | Magic Chef Ovens
Oven won't heat up, you can see a little orange light glowing and it heated a little bit, but now the light does not come on at all. Also, not sure this is a double oven, but it does have the broiler...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jun 15, 2011 | Magic Chef 9112 Gas Double Oven
Magic Chef oven does not work but all burners do
25 yr old oven...........so I bought a new one with a few blemishes for $200.
Apr 04, 2010 | Magic Chef Ovens
ELECTRIC OVEN THE RANGE WORKS BUT THE OVEN AND BROILER WILL NOT WORK
Without a proper model number I would say you need to replace the electronic clock/timer control. It could also be a relay power board in the back of the range if it has one. beast to call a reliable repair company such as sears.
Jan 31, 2010 | Magic Chef 9815 Electric Single Oven
How do I troubleshoot my Magic Chef electric built
Hi,look in the control console for the tech sheet or under the top of the unit.A good place to start.Hope this helped.
Nov 17, 2009 | Ovens
My oven, model 38HN-6TVW won't preheat
I was unable to get the full model to come up. I was able to get a Magic chef range to come up. I would replace the control and oven thermostat.
Aug 14, 2009 | Magic Chef 9815 Electric Single Oven
Magic chef oven/stove top range not staying hot
Hi, It very well could be the ignitor. Sometimes they work at first and then will not open the gas valve later in cycle. You can set the oven to heat and watch the ignitor. If it glows and the gas will not ignite in 30 to 45 seconds, the igniter is getting weak. I jope this helps.
Please let me know if I can assit you further.
Vic
Jun 20, 2009 | GE JGRP17 Gas Single Oven
Magic chef gas oven range 6498xvs oven no longer works.
i have a magic chef gas range. broiler work, burners work, fan works when you turn the oven on, but oven does not get hot. could it be the electronic ignitor or does even have one.
May 20, 2009 | Ovens
Magic Chef oven won't heat up past 200 degrees
You obviously have one or more elements not working, you need to test same, and replace as req'd.
Dec 12, 2008 | Magic Chef Ovens
Magic Chef range
Ignitor is very fragile and may have cracked.
Nov 28, 2007 | Magic Chef 9122 Gas Single Oven
Maytag CWG3100A Gas Single Oven Logo
268 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
