Question about Symphonic SC319C 19 in. TV/VCR Combo
No sound on TV but VCR is OK
VCR sound is working as it should, but the TV sound is not.
  • k8xx Nov 12, 2008
    The problem still exists. It is a thermal problem that comes and goes, but is mostly bad. The audio is perfect using the VCR, but the TV adio is mostly gone all the time. It crackles and pops from time to time, but it is difficult to thermal spot the trouble. Not having a schematic complicates the problem. thanks for you suggestion. jack
  • dawn40 Dec 03, 2008
    good picture but no sound (it sounds like no channel has been found) but when I play a video the sound is fine
    Problem Solver:
  • 19 Answers
Hi there, This sounds like an input control error.
If you find the menu section, then choose Av inputs, you can adjust the settings, I.e. stereo Video or Av (if you are using scart leads then choose Av.
Hope this helps, Chris
Posted on Nov 09, 2008
Cannot get video on my Orion model VRO 211B
Could be a connection problem. Pins on plugs can become bent or damaged, sometimes it is the socket that the plug fits into that becomes damaged. Try a different connection lead.
Dec 26, 2015 | Orion VR0211B Video Cassette Recorder...
How do I hook it up yo TV. Have red yellow and white three pronged cable, but TV doesn't respond.
hi sounds like u r using RCA cables if u have hooked up to the output on youre vcr & the input sockets on tv .....set you tv to AV INPUT..if vcr & tv r working OK this should work ...good luck.
Sep 08, 2015 | Philips DVP3345V/17 DVD Player/VCR
Toshiba VCR. It records OK but playback is black, white shaky
What do you mean by "records OK"? It sounds to me like you are not getting a signal to record. I had this problem before, as well. There are two things I recommend you try. The first is that (if you are trying to record over-the-air tv, you will need a digital television converter box connected directly to the vcr. If you already have one and are sure that it is connected correctly, you may also try an RF modulator. When I got my new vcr, it wouldn't work at first. I eventually found out that I would need an RF modulator in order for it to work on my tv. I hope these suggestions help. Good luck! Sincerely, Der Strom
Apr 26, 2010 | Aiwa HV-MX100 VHS VCR
We have a new vcr snowy
It seems that you need to take the new unit back for exchange, since you are using the same output for the vcr and the dvd and your dvd is giving you a good picture, the vcr is acting up and since it's new either exchange or repair will be needed.
Sep 01, 2009 | Philips Magnavox TS3260C 32" TV
New TV won't ''talk to'' old VCR
using the magnovox remote, reprogram the vcr's channels. set it up to use cable not air. when the vcr was unlugged it lost it's channel memory. don't buy new cables, you're getting a picture and sound so that means your rca cables are ok.
Jan 20, 2009 | Sharp Aquos LC-32D40U Television
No sound on TV
If the TV programs come's up with sound, then is possible that the TV set could be problem free. then cheek the system frequency if it need to be adjust from NTCS, PAL, AUTO MESECAM and so on. Cheek the DVD and VCR if they are in one of the following system settings and adjust the TV set to the settings at which the DVD or VCR is set to. Then you can also cheek if the cable is properly inserted, that is audio to audio and video to video. Nevertheless, if you have properlly connected your cables and set the system frequency to match with each other, and still no sound, then the TV could have sound problem.
Possible courses of sound failure in TV are as follows:-
1 RF stage
2 sound Ics or transistors
3 broken speakers
4 a break down resistor which supplie positive voltage to the sound curcult
Dec 09, 2008 | Televison & Video
NO picture showing on screen even though the VCR is running and hooked up properly
u have to run it directto tv yellow cable ok and sound cables not throw dsh tv
Feb 03, 2008 | Quasar VHQ400 VHS VCR
No sound from VCR
OK here we go, The system is connected in the following manner: DTV-----RG6Coax-----VCR-------RG6Coax-------TVset Might I suggest a simple test? from the VCR to the TV use the Video and Stereo RCA outputs. The reason I want you to do this is to see if the Audio signal is being processed by the VCRs circuitry. I think it is. If it is then you problem might be the modulator that is used from the VCR to the TV when the VCR is on. You see when the VCR is off the RF connections are basically a switched pass-thru, when the VCR is on the switch send the signal to the VCR circuitry and the back into a Modulator and into the audio and video output RCA jacks. If the test works then the signal is being processed by the VCR and it might be a modulator problem, if not then the issue might be the actual RF input circuit prior to the demodulator. Another test would be to play a tape to see if the tape plays. If it does then this narrows down the trouble area between demodulator and the audio and video detector stages. If there is an internal proble you may want to take your unit to a radio and Tv repair shop.
Aug 24, 2007 | Samsung VR8460 VHS/S-VHS playback VCR
Symphonic SC319C 19 in. TV/VCR Combo Logo
107 people viewed this question
Top Symphonic Televison & Video Experts
Computer Repairing
Computer Repairing
Henry  Thomas
Henry Thomas
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
