Question about Sony DHC-ZX50MD Shelf System
CD Changer MEC ERROR
The CD Changer will not eject any CDs. It gives an error message "MEC Error". The result is the same for both local and remote. I have also cycled the power to no effect. It does whirr for some time like the internal changing mechanism is doing its thing, but then it stops with the Error Message and no CD ejected or played.
  • 3 more comments
  • OneLucky Nov 04, 2007
    I have the same probelm. My model is: MHC-ZX10 i get the same error. No motors seem to work at all.
  • Ribeiro Nov 12, 2007
    I Also have the same problem. When I try to play or eject the cds, it says that CD MEC ERROR. I don´t Know what does it mean.
  • Adam Jerome_lagudi
    Adam Jerome_lagudi Aug 08, 2008
    WHEN YOU TURN ON UNIT. IT POWERS UP, CD CHANGER MAKES NOISES, CD MECH ERROR APPEARS ON DISPLAY, THEN TURNS INTO STANDBY. IF ANYONE CAN SUPPLY A SERVICE MANUAL OR SCHEMATIC IT WOULD BE GREAT.
  • Grosu Cristi Alex Feb 07, 2018
    I got another answer. I opened my sony and changed all the old bands feom inside because those were damaged an it worked :))))
    Cd mec error means CD mecanical error, this means that inside it got stuck or the rubber bands are too old and they are broken.
I have the same problem!!!
do anybody knows how to fix it??
thank you very much
Posted on Apr 16, 2008
You need to make sure that the CD mechanism is working correctly. If it is not working correctly, it will not eject or play any CDs.
When you power it on, it tries to load the CD and you will get a message "CD Mec Error"
This means, the CD got stuck inside , or the rubber bands is broken and you need to fix the CD mechanism.
I have a suggestion: You need to disassemble the CD mechanism and take off the CD which got stuck inside or change the rubber bands.
I think this will help you :)
Posted on Dec 23, 2018
Musisz upewni? si?, ?e nap?d CD dzia?a poprawnie. Je?eli nie dzia?a poprawnie, nie wyjmuje ani nie odtwarza ?adnej p?yty CD.
Mam ten sam problem. Zmieniam tryb na CD, pokazuje CD 1-1, Ale nie odtwarza i nie wyjmuje p?yty.
Je?eli jest taki problem, to po uruchomieniu go z trybu gotowo?ci, pr?buje za?adowa? p?yt? CD,
a potem pokazuje "CD Mec Error"
Jak to si? dzieje, to znaczy ?e nap?d jest uszkodzony i ?e trzeba go wymieni?.
Posted on Dec 19, 2018
  • 456 Answers
You need to make sure that your cd mech is aligned correctly. if it is not alligned correctly, it will power up from standby, try to load the cd trays and you will get mech error message on the display. good luck with allignment.
Posted on Aug 08, 2008
  • Anirban Naskar
    Anirban Naskar Aug 15, 2017
    I have successfully wasted three changers and yet to get the alignment properly. can you suggest some videos or tutorial?
2010 Mazda 5 CD changer not working
if you have a genuine unit it may be connected to the CPU or need resetting after the battery change.
Dec 12, 2013 | 2010 Mazda MAZDA5
Cd will not eject from cd 3.gives disc error message and will not read the cd.. disc errors on cd2 and cd4,but will eject the cd.will not play cds. have unplug both units for an hour. no change...
My first guess would be that the loading belt is slipping. This will prevent the cd from loading completely and thus won't read. The belt costs around $2-$3. Care must be taken when opening up this unit.
Let me know if you need any additional info.
Dan
Sep 30, 2010 | Bose Wave music system Multi-CD Changer...
Jammed cds in a 6 cd changer ford ranger 2002
sounds like the tray inside was misaligned when the cd went in. and it probally sent the disc into a occupied slot. you will have to remove radio and disassemble to repair. also try just unpluging radio and plug back in. sometimes it resets the radio and will start ejecting the cds
Feb 05, 2010 | OEM Systems Car Audio & Video
2001 Lincoln LS: CD Changer wont eject CD's. Keeps saying CD ERROR when I press eject then select any of the 6 CDs. Also, it says slots full when I press load and press any of the 6 CDs. I just bought the...
you really need to take the cd changer out of the dash,and then open the cd changer ,is one of you cds is making the problem,ones is remove it should be working fine,good luck
Sep 17, 2009 | 2001 Lincoln LS
Cd mech error
Hello, j'ai eu le meme probleme!!!
Il s'agit d'un branchement électronique à l'intérieur qui est à moitié enlevé..
Il suffit d'ouvrir le capot prinicipal et de reconnecter la fiche correctement (il y a 3 cables blancs, c'est celui située le plus en bas, large de 1cm)
Aug 13, 2009 | Sony DHC-ZX50MD Shelf System
Six cd changer with 6 cds stuck inside, none will play and message appears no cd, or cd error,or eject error in a 2004 ford escape
Ok this may seem barbaric but it worked on mine.......Hit the top of the stereo a couple of times and see if it corrects the problem.
May 30, 2009 | Blaupunkt IDC-A09 5-Disc CD Changer
Monsoon Radio CD CHANGER ERROR
CHANGEUR CD ERROR . g6 2006
Jan 14, 2009 | 2003 Hyundai Santa Fe
Bose multi cd changer wont work, reads "Disc error"
I think there may be a problem with the system (defective parts) - I, too, am having this issue. I am going to contact the BBB - maybe if enough of us complain we will get a recall. To file a complaint:
http://www.bbb.org/boston/business-reviews/department-stores/the-tjx-companies-inc-in-framingham-ma-97/
Bose
PO Box 9168
The Mountains
Framingham, MA 01701
Dec 01, 2008 | Bose & Wave& Music System
Error message appears when magazine is put into changer
why doesn't my cd changer reads. it keeps saying no magazine, when i insert it in. when i hit the eject button it ejects it out but wont read it or the cds why???
Jul 26, 2008 | Car Audio & Video
Sony DHC-ZX50MD Shelf System Logo
1,860 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
