Question about Acer Aspire 3680 Laptop
Acer 3680. only half of the harddrive works.
On my laptop I can only use 40GB of the 80GB of the hard drive, why?
    Problem Solver:
  • 16 Answers
First: Open "My Computer" (on the start-menu for instance) and see if you have more than one local hard drive there. The first drive is called C and usually has 40gb on these Acer laptops. The other one is called D or E and has the rest. If your computer is full, you may want to move some files to the other drive (partition).
Posted on Nov 10, 2008
  • Acer Master
  • 1,250 Answers
Check it on the bios the size of your hard disk, if its 80 gb then go to the control panel after booting open the administrative tools, open computer management, then select disk management, check the hard disk there, if there is an unpartitioned space , then convert it to the partioned space
Hardrive is unknown device in bios
The BIOS determines the maximum size hard disk the computer can support.
The max hard disk size for this model Dell is 80Gb.
To use your 250Gb hard drive, install this Hard drive into an USB hard drive case and use it as an external USB hard drive.
Mar 09, 2013 | Computers & Internet
What is correct hard drive to replace original in an Acer 5051 aspire laptop?
To my knowledge the Acer Aspire 5051 takes a SATA HDD, any 2.5" SATA HDD will do, but you will need to install an operating system once you get it. Here is a link to all the new SATA HDDs on ebay:
Hope this helps you
Mar 21, 2011 | Acer Computers & Internet
Aspire 3680 Laptop/Notebook 80GB 14-WXGA Vista HomeBasic 9980286710 PC Notebook: how to change my hard drive...
That is a link to a, zip file with a Service Manual in PDF format, use this as inside it shows you everything about repairing a servicing this PC.
May 06, 2010 | Acer Aspire 3680 Laptop
Need Acer 3680 VISTA all driver
Below there is the download page for your laptop from Acer.
Acer Europe - Service & Support, Drivers & Utilities, Downloads
Download drivers on the Vista section in page.
Remember to rate the solution.
Feb 18, 2009 | Acer Aspire 3680 Laptop
Hard disk and ram
Hello Kevin Shaggy...
Let me see if I can help you out a bit...
Adding a 160gb to a 40gb does give you 200gb. BUT!!! you will loose a little bit on each one after formatting the harddrive. The new drive will wind up being about 157 or 159gb give or take a little.
ANY harddrive partition, whether it is a c:, d:, DO have to format EACH drive letter.
If you partition your 160gb harddrive into 2 parts, (2) 80gb drives, then they would get two drive letters and both of them get formatted.
IF the 40gb drive is C: then the new 160gb partitioned in half would be D: & E:.
CDROM Drive would be F: and so on....
Floppy Drives, CDrom Drives, DVD Drives, you do not have to format like a hard drive...
If you add a 1gb stick of memory to your existing 256mb stick of memory then you WOULD have 1gb + 256mb. If you remove the 256mb and just add 1gb, then you would just have 1gb.
Nov 24, 2008 | Samsung Computers & Internet
HDD failure on an ACER laptop
With the exception of interface, laptop hard drives (2.5" drives) are easily interchangeable. You can look up the specs of the drive you pull by googling the manufacturer and model number, but the main specs are interface (sata or ide, yours is ide according to the info I found about this laptop- not interchangeable with sata), drive speed (yours probably 5400 rpm, faster ones are 7200), buffer size (usually 8 MB).
So, if you think the issue is your drive, check out something like:
although Iwould probably go to a store personally instead of any kind of mail order. Take your old drive with you if you are not sure. You could even put in a bigger capacity drive; I believe your laptop came with only 80GB??.
Aug 10, 2008 | Acer Aspire 3680 Laptop
Don't have HDD passwords
To clarify the request, it is a harddrive password not a bios password or windows.
Jun 10, 2008 | Acer Aspire 3680 Laptop
Upgrade hd on laptopp
The easiest way is to remove the casing under your laptop and see what make your drive is, but any make of laptop hardrive sould be ok. Sometimes the hard drive may be held in a cradle so you will have to remove it if this is the case and use it with the new hard drive. A problem comes when you probably have the Acer backup/restore folder on another partition(which sometimes includes Windows, as you don't always get a hard windows cd rom),on your current hard drive, so make sure you have a Copy of Windows otherwise You'll have to purchase another Windows installation disc, or clone your drive with something like Norton Ghost.
Nov 24, 2006 | Acer Aspire 3000 Notebook
Acer Aspire 3680 Laptop Logo
70 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
