Question about Kenmore 63942 Dryer
Not urning on
The dryer was working fine then it stopped when I push the start button .. it just makes a buzzing noise but will not turn on ???
  • 1 more comment
  • pharris798 Feb 12, 2009
    My ultra care dryer will sometimes turn on and work correctly for one cycle but then will not turn on at all or only make a buzzing noise when tried again and then it will make no noise when tried later in the day. help!
  • castrnghrt Mar 04, 2009
    I have a whirlpool electric dryer model #LE4440XWW0 and when I push the start button it makes an almost buzzing sound - it seems like half the noise I would expect if it was working properly. Ideas?
  • James Chandler May 11, 2010
    need model numbers folks
  • Kenmore Master
  • 3,361 Answers
All these are bad motors or possibly lint jammed in the blower wheel attached to the motor.
No lint= bad motor.
Posted on Mar 08, 2009
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' ...
? 4:32
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
My maytag Neptune dryer is not working. It makes a noise when you hit the start button but doesn't start. The timer continues to go until it reaches stop. Have checked belt and it seems to be fine? Any...
I have worked at sears appliance have come across exact or similar problems. You push the button and you hear something like a loud buzzing. My experience has been that the drive motor is locked and needs replacing. Depending on the age of the dryer and the cost of a motor and installation, you might but another dryer.
Mar 03, 2015 | Maytag Neptune MDE4000 Electric Dryer
When I push the "Start" button there is a buzzing
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
Jun 15, 2011 | Fisher and Paykel DE06 Electric Dryer
GE dryer, Mod# DDE7209RALWW the timer work when you set it but when you push the button to start it makes a buzzing noise and the drum won't turn. When you let up on the button it stops making the noise.
There can be many reasons why your dryer will not turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out what is happening...
Dryer Repair ? The dryer will not start
Aug 13, 2010 | GE Dryers
Whirlpool dryer makes a buzz noise when push
pull motor switch out(the one with wires go in motor) best use compressed air.... lint is stopping lever... this all happens after you turn breakers off...hi hi
Aug 27, 2009 | Whirlpool ET8CHEXSQ Dryer
My dryer makes a buzzing noise when I push the start button
My Hotpoint dryer is seven years old and did the exact same thing. When I got over the anger and the thought of spending 4 or 5 hundred dollars to replace it I started messing with it. I finally decided that since it buzzed when I tried to start it there was current there. The only other thing it could be was the drying cycle knob.
I held the start knob and let it buzz while I slowly turned the dryer cycle knob to the right. As I turned through each cycle it would hit "off" and the buzzing would stop and then resume as I moved past the "off " setting. On the third trip around the dryer "started" and has been working since. Maybe something got out of kilter. Apparently the problem was in the knob that controls the drying cycles.
Mar 24, 2009 | Hotpoint NVL333EY Electric Dryer
Knemore 80 series dryer won't start every time
Go to and enter your model number and it will show you all your parts, but I suggest you change your thermostats and basically have the dryer cleaned out of possible lint build up on the interior
Mar 20, 2009 | Kenmore Dryers
Dryer work turn on, buzzes when start is pushed
It may be just your timer switch. Look at all the wiring first. The receptacle to the plug, cord and into the back of the dryer.
Feb 15, 2009 | Amana Dryers
Kenmore dryer model #11060932990
Jul 23, 2008 | Dryers
Kenmore 63942 Dryer Logo
74 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
