Question about Pyle PLDINTV7 Car DVD Player
NO VIDEO Everything works with this system except when I insert a DVD you can hear the sound but no picture. You can see setup on the screen (brightness, etc.) but no video. You can hook up an external dvd player and it works as well as the built in tv tuner. But when using the dvd player it plays sound but no picture. Also, am I supposed to see a picture or background when not playing a movie or just accessing the setup on the system? Because I don't see that either. I hope anyone here can help me. Thanks.
  • Anonymous Aug 19, 2008
    Can't play video can hear the sound on my toshiba tv
    Scholar:
  • 35 Answers
It sounds like the video signal is being routed to a different out put. Search the menu for "Source" kinds of settings. Often you will have Vid 1 and 2 and maybe HDMI 1 &2 etc. Try what looks right and keep trying all combinations (usually less than 6). Take your time, it often takes them numerous seconds to recognize the signal. The fact you see the settings means the Video is working if it just had the signal. Also, if there is any wiring involved, check the cables and maybe swap them for known good ones if possible.
Posted on May 20, 2017
j_del
  • 1586 Answers
SOURCE: pYLE PLTSD7BT
DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On mine, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in whatever manner is required by the manufacturer of your head unit. If there is no off/on sequence with yours, as there is with mine, simply ground the wire to a screw inside the dashboard and you're done.
Posted on Jul 23, 2008
j_del
  • 1586 Answers
SOURCE: HELP ME!!!!
MNfisherman
  • 11896 Answers
SOURCE: wont play throught speakers only crakles
If everything is hooked up correctly, you may need to wire harness. It could be a bad capacitor in the audio outputs. Easy to try wire harness first. Sometimes turning off and back on again works.
Posted on Jul 08, 2009
  • 306 Answers
SOURCE: why picture does not show when playing dvd?
you need to hook up the parking break wire on the back of the radio. usually light green
Posted on Feb 07, 2010
Baker Audio
  • 29 Answers
SOURCE: my pyle dvd player has
What Kind of Vehicle Do you Drive... It is Possible that you have a Factory Amp installed that runs all the stock speakers in the vehicle(LF, RF, LR, RR.). You would have locate the Amp remote wire for the stock amp and hook it up to the remote amp wire on your deck.
Posted on Jan 10, 2011
I have a cable controller connected to a Bose sound system and a Haier 32 " flat screen TV. Everything works great until I want to view a DVD, then all I can hear is cable audio with the DVD video. How do...
That sounds like a miss-wired setup. I would unplug the wires and re-wire it making sure the right wires are in the right holes. Sounds to me that the DVD audio is not going to the bose and only the TV audio is.
Mar 02, 2018 | Televison & Video
My lg dvd player doesn't show images (except the black and white diplay on the screen) but i can hear the sound playing, the kids might have changed some thing in the setup. please help if there a
Hello
You haven't given the exact model number ot your LG DVD, so I can only give you a general solution to this problem.
Get into its meny, surf through, come to SYSTEM adjust window, change the system. If a NTSC system recorded disc played with PAL system adjustment with DVD, there will be only black/white pciture, and vice versa.
Adjust it to the color system thathave been adopted your country. this must solve the problem. OK.
Jan 31, 2012 | LG Televison & Video
Cant get sound from tv on speakers.
lost remote and cant get sound from ks3102
Dec 16, 2009 | Koss KS3102 System
My video in jack will not work?
I had to goto setup and change the setting from s-video to video
Feb 18, 2009 | Toshiba DRW2 DVD Recorder
XOVISION CAR DVD PLAYER SOUND NO PICTURE
hook your brake line wire from stero to your ground wire. it needs to be grounded
Dec 30, 2008 | XO Vision XOD1735 Car DVD Player
I need set up help
Most amps these days have to told which input is being used,ie if you have the dvd into dvd video input for picture and are useing coax or optical for sound you have to go into the setup menu on the amp and find the input menu and tell the amp the dvd is on optical or coax.
hope this helps.
CABLE GUY.
Jun 27, 2008 | Pioneer VSX-D510 Receiver
DVD picture is black and white
Sounds like you are either trying to play an NTSC (US or Asian) DVD on a PAL (European) TV.
Go into the DVD settings and look for picture, video or display options.
If the DVD is set to NTSC, then set to PAL.
Jan 06, 2008 | Philips DVD 622 DVD Player
No picture from dvd, but sound
What type of output are you using? Try using the component video output on the DVD player. (that's the one with three colors) This worked for me when the composit and s-video outputs stoped working.
Oct 12, 2007 | Coby DVD815 System
Black screen- cannot view pictures, can hear sound
ok do one thing,connoet rca video pin in component socket.. so that you can see bblack n white picture.
Aug 06, 2007 | Philips DVD 622 DVD Player
Pyle PLDINTV7 Car DVD Player Logo
35 people viewed this question
Top Pyle Car Audio & Video Experts
Mike Duncan
Mike Duncan
xxxxxx xxx
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
