Replaced spark plugs. it starts from time to time,but its not consistent
Try turning the key on and off several times. Do not turn the engine over, just on and off. You will need someone to stand with their ear close to the "open" gas filler tube. What they should hear is a quiet buzzing sound that cycles about one second long then stops. This should happen at at least two of the key turns. If nothing is heard you may need a fuel system fuse or a new fuel pump.
SOURCE: Replaced spark plug in VW polo, warning lights is on...
are the plugs gapped to spec this could cause misfires whick would set off the engine light make sure your plug wires are good and not split for this to may cuase misfires cause the wire is grounding out on the head or the manifold
SOURCE: vw polo electrical problem
If spark is good, it could be fuel pump or filter, or even your solenoid. Message me with more info. does it:
1. Try to start? - Fuel issue, or battery issue?
2. Click - Battery issue
3. Nothing? - Solenoid issue
SOURCE: 94 saab 900 wont start
did you use belt alignment tool? cam settings must be exact. Ck compression, may have bent valves, very common to jump time and ruin engine
SOURCE: MY 1995 BY CAPRICE CLASSIC WILL START BUT WON'T STAY RUNNING
The fuel pump is shorting out,replace the fuel pump in the tank to repair the problem.
Testimonial: "Thank you. the pump was the first change made. Perhaps it nedd to be rechecked. Will let you know how it turns out."
SOURCE: car wont start, not getting spark
crankshaft sensor, or computer on toyotas then it was usually the distributor or the computer, but the crankshaft sensor might be bad too thats what helps to get you spark.
