Question about Linksys WRT54GL Wireless-G 54Mbps Broadband Router w/Linux all-in-one Internet-sharing Router With 4... (WRT54GV4)
Connection My router is on, but I cannot connect to the computer unless I disconnect the cable from the router and place it directly into my laptop.
  • Anonymous Nov 20, 2008
    i am using linux ubuntu and i cannot connect to the router
    Genius:
  • 1,124 Answers
You have to set the wireless connection
Check if you have the wireless card ON or check if your wireless card is installed
My computer >> right click >>Properties>>Hardware>>Device Manager>>Network
If yes,
Click your Start Button
Select and click Control Panel
Select Network Connections
Select Wireless Network Connections
Right click
Select View Available Wireless Networks
5. Highlight the network you want to connect to
Click Advanced
6. Select the wireless network tab
7. Highlight the network in the available networks window
9. Click configure
9. IN the Properties Window
Double check the SSID (network name)
Enter the WEP KEY provided to you by the office
Click OK
Posted on Nov 09, 2008
D-link DIR-625 wireless router is setup and wired to laptop
First of all make sure the Wireless switch in your Laptop is turned on.
Now Disconnect the cable from the Laptop to the Wireless router
Now go to your Wireless Network connection and search for the available network. Select the appropriate network and connect.
Thanks
Nov 01, 2008 | D-Link DIR-625 (790069292637) Wireless...
I have a Sony Vaio laptop and my internet (Time Warner) works when connected directly into the laptop, but will not when the cable is connected to the D-Link to the WBR-2310 router. I think it's...
reboot your modem(power it off for about 10-15 secs), reset your router. make sure your laptop is disconnected from the modem when doing this. Modem needs to catch router's ip address. Start your laptop and search wireless networks. look for your d-link router and connect. Now this is assuming you didn't firewall your router, which in tun you will need to enter your key to connect.
Sep 29, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
My two laptops were connected to my belkin ni router all of a sudden disconnect and refuse to connect back
1.you should turn off the router and computer. 2.turn off the modem. 3.disconenct all of the cables. 4. connect all of the cables back. 5. restart the modem, router, computer. if you are able to connect, it is fine. otherwise try to connect the laptop directly to the modem and bypass the router and check if able to go online.
Jun 08, 2009 | Belkin (F5D7231-4) Wireless Router
Cannot connect to internet when Symantec is running and:
Disable the Symentec fire wall and try,Still if you face the same isssue reset the router and re-connect the cable and check..
May 26, 2009 | Linksys Wireless-G Broadband Router
Router has stopped routing
Hi, Check to fix with the router's warranty.
Somethings that you could try yourselves are:
- Disconnect the router and power it down. wait for 30 secs and switch it on.
- Go into the router settings and change the transmitting channel to either 1,6 or 11.
These steps are to avoid air traffic congestions.
Feb 24, 2009 | Linksys Wireless-G WRT54GS Router...
I can get on the net through my isp (wild blue)if I connect the cable to the computer directly. If I connect the cable to the router I cannot get a connection. my router has been working fine for about a...
RESET YOUR ROUTER. If it was working fine before but has now stopped it has locked up. there is a rest button on the back. depress this for 30 seconds with the power TURNED ON to the unit then just set it back up on your home network as you did before
Rangemax-internet only works when comp directly connected via LAN
it sounds like you have the wireless connection to the WAN disabled. Go through the wireless settings on the router and check to make sure it's not being blocked from the WAN/Internet connection.
Nov 11, 2008 | NetGear RangeMax WPN824 Wireless Router...
No internet connection through router D-Link DI-524
-Connect your router to the wall and connect your laptop to the router using a cable.
-Use Internet Explorer and type the following line in the address bar: http://192.168.0.1
-You should see a Username and Password Screen...type admin for the username and leave the password blank, unless of course you did give it a password.
-Next you should see the D-Link setup page with tabs across the top that say Home - Advanced-Tools-Status-Help
-Click on the WAN button on the left side of the screen
-Now you should see the WAN Settings Screen
-Click on "Dynamic IP Address" (You should not use PPPoE)
-Click on the Apply button at the bottom of the screen.
-Now close your browswer and restart your computer.
-You should now be able to access the Internet...through the router cable and wireless
-Let me know if you need more help with any of these steps.
-Good luck...and I hope this helps!!
Jan 14, 2008 | D-Link AirPlus DI-524 Wireless Router
Computers & Internet Logo
95 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
