Question about Gateway Computers & Internet
My computer does not recognize my cd's, only recognizes memory sticks, cannot download pc tutor learn windos vista or any other cd's.
  • 345 Answers
Drop a factory made music CD into the drive while the computer is on. Most CD Readers have a small headphone jack on the front face of the drive. After you drop a music CD in the CD reader plug in a set of headphones in the headphone jack (if your CD reader has one, some of the newer one don't have this feature) and see if you hear music. A CD reader will play a music CD with out you doing anything to your computer or the CD reader. If you do hear music the CD reader is most likely good and it will be a problem with a driver or a physical connection to the computer (physical connection = data cable going to the CD reader isn't pushed in all the way in the connector on either the CD reader or the motherboard).
Posted on Nov 09, 2008
    Scholar:
  • 60 Answers
First go to my computer see if drive shows up…
second (figuring it didn’t) go to control panel -> System -> hardware(tab) -> device manager
third check to see if little (!) is on the tiny pic of cd-rom drive if so you have a driver problem and need to reload it off your system restore disk or windows disk (do this by right-clicking on cd-rom, -> properties
and click roll-back driver first, when that fails click re-install driver and do that…
fourth after doing that and restarting, and the comp STILL fails to see it, open up comp. take plugs out the back of cd-rom and look at them (shouldn’t be dusty on inside, make sure no burn marks on power cord plug-in) then plug back in snuggly… restart again and see if that works… if not…
fifth…. go to comp store and buy cd-rom for >$20 (if that much)
best-buy, walmart, online at tiger direct, etc.
CPU will not recognize the last memory slot in my FX4710
RAM, or random access memory, is the physical memory on the computer but only holds data while the computer is on.
The benefit of adding more RAM is that it generally makes your computer faster.
Almost all new computers recognize your RAM after you install it and restart the computer, but if yours doesn't there are a few simple things to do to get the memory recognized.
Check the type of memory you have.
Computer motherboards will work only with the type of memory they are designed for regardless if the memory fits or not.
There will be either a sticker on the memory or a listing on the packaging giving the memory type and speed.
Check the computer's or motherboard's manual for the type of memory that is compatible.
Install the memory and make sure it is tight, otherwise it may not get recognized.
The memory fits into slots on the computer's motherboard.
There are tabs on the side of the memory slots to release it.
Release the memory if it is installed and put it back in by pushing it down straight into the slot until it clicks.
Restart the computer and hit the appropriate key to enter the BIOS.
The key will be listed on the screen.
Go through the menu choices by using the arrow keys.
Look for the memory listing under hardware.
Make sure all memory listings are not listed as disabled.
If so, change them to enabled.
Choose anything listed similar to "Auto detect."
Exit the BIOS and restart the computer.
Jul 26, 2013 | Gateway FX4710-UB003A Core 2 Quad Q9300...
Not all installed memory recognized
Open your computer and install one memory stick and try powering on the computer. Try one stick at a time to determine if you have a bad memory module or a defective memory slot on the motherboard.
Jul 03, 2012 | Dell Precision T5500 PC Desktop
After formatting my drive C: and re-installing my winXP OS, hardwares were detected (printer,mouse and keyboard), except for pc camera, external speaker and ethernet. PC cam was corrected after installing...
> my P5KPL-AM SE cd cannot be recognized by cdrom....
Huh? Open "My Computer". Is there an icon for the CD-ROM?
If you double-click that icon, does it "open" the files on the CD?
> Where can i get my drivers for ethernet???
From a computer WITH Internet access, access the web-site for the manufacturer of the motherboard, and download the network device-drivers to a USB memory-stick. Move the memory-stick to your computer, and install the device-driver.
Sep 26, 2010 | Computers & Internet
My d610 does not recognize my cd drive
Is the USB-compatible drive recognized when connected to some other computer? If OK, then the drive is OK.
Is _ANY_ USB device (memory-stick, camera, mouse, keyboard, printer) recognized when connected to any of the USB ports on your computer?
If not, then the USB device-drivers for Windows have not been loaded.
Drastic: backup all your data files, bookmarks, and music, to an external hard-drive, and reinstall Windows from the Dell-provided "System Restore" set of CD-ROMs.
Nov 14, 2009 | Dell Latitude D610 Notebook
Memory stick pro not recognized any more by dell inspiron 6400
I suggest going into the control panel/device manager and removing all the usb devices.
Restart the computer and let it find the devices again. That might help.
Also--have you tried the stick in another computer just to make sure it works?
Sep 25, 2009 | Dell Inspiron 6400 Notebook
My computer with Windows Vista doesn't recognize the Lexmark X125
http://downloads.lexmark.com/perl/downloads/downloads.cgi
The link above is the driver for that printer. Download that driver and then install it. Once you install it, the computer should recognize it.
Mar 26, 2009 | Lexmark Pro X125 All-In-One InkJet Printer
Vista will not recognize sandisk memory stick pro duo 2.0 GB
Try the memory stick on another computer. If it still doesnt work, clean the contacts on your memory stick. Re-insert it. If it still doesnt work, use another working memory stick and insert it to the reader, if it recognizes it chances are your memory stick is either fried or destroyed. You'll need to by one.
hope this helps!
-levibit-
Mar 20, 2009 | Computers & Internet
I need help opening a file saved on my memory stick with my pc
IF the win98 box wont recognize the usb stick you will need to install the drivers in order for the OS to recognize the device, after this you should be able to see the device and files on it
Jan 22, 2009 | Computers & Internet
Maxtor and vista
Try some other USB device (memory-stick, printer, camera) in the USB slot in the Vista computer, just to "prove" that Vista will recognize _any_ USB device connected to that slot.
May 31, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Free Software Download from Net
My camera ( Sony Cyber Shot W 30's memory stick is not working and i am unable to dowload pictures from my camera on to my laptop. My laptop's OS is Windows Vista.
Please let me know how could I go about downloading pictures from my camera to my laptop.
Many Thanks.
Prachi Vashisht.
prachivashisht@rediffmail.com
May 17, 2008 | Kodak EasyShare C653 Digital Camera
Computers & Internet Logo
94 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
