Question about Texas Instruments BA-II Plus Calculator
Interest conversion I'm attempting to do interest conversion on the calculator. Originally, I believe the only problem I had is that under the ICONV screen, I would enter a number for nominal interest, then a number for I/Y, and then when I would go back up to effective and hit compute, nothing would happen - I would just get all zeros. Then I looked in the manual for the calculator, and it said something about clearing the worksheet, so I did that - the 2nd key and then clr work. Now, when I go to the ICONV menu and enter a number for nominal, it doesn't stay. For example, if I go enter a number for I/Y, and go back up to nominal, my number that I entered has changed to 0. And if I go try to compute the effective, the same thing happens as before - I get 0. Any hints here? I'm taking a test with this in a couple of weeks, so if nothing else I can go buy a new one, but if it's something I'm doing it'll happen on a different calculator too.... Thanks.
Try hitting Enter after plugging in the numbers. That should make the numbers stay.
Posted on Apr 12, 2007
SOURCE:
Where is iconv function for calculating effective interest rate ?
Page 24 of the attached manual shows you how to calculate the effective interest rate. I couldn't find an iconv function, but there are functions to move between the simple and effective interest rate.
Good luck,
Paul
http://www.yorku.ca/ntahani/ADMS3530/EL738_OM.pdf
Feb 16, 2016 | Sharp EL-738 Financial Calculator
How to you get rid of the "c" on display screen
Your calculator is set to use compound interest for the odd period. To switch to using simple interest, press STO EEX
Jul 08, 2014 | HP 12c Calculator
How do I find the ICONV function on my TI 83 plus? Thanks.
All the functions available on this calculator can be found in the CATALOG. Press [2nd] (CATALOG). Scroll up or down to see them listed. To use a function/symbol just select it and press ENTER. It will be displayed on the screen, ready to use.
Oct 21, 2013 | Texas Instruments TI-83 Plus Calculator
Where do I find the iconv function?
Paypal currency conversion
Paypal along with any other bank can charge you above current listed exchange rates. They are charging what is called a currency conversion fee on top of the conversion rate. For instance, American Express will charge say 4% on top of the conversion when you spend foreign currency on their cards. MasterCard & Visa do the same thing. Even if you were to go to England tomorrow, when you bring your US dollars to have them converted in the airport the rate is always above the current spot market rate because they include a conversion fee. Sorry but you aren't due any money back and no interest, Paypal is doing nothing wrong.
Sep 14, 2012 | PayPal Accounts
There is a "c" to the lower right of my screen.
The "C" is indicating that the calculator is set to use compound interest for the odd period. To use simple interest, press STO EEX.
Dec 10, 2010 | HP 12c Calculator
Trying to use unit conversion feature and can't figure out how to use the feature
Assuming you want a conversion listed on the inside of the case:
Enter the value to be converted, press SHIFT 8 to bring up the conversion screen, enter the two-digit number for the conversion, then press =.
For example, to convert 2.1 inches to centimeters (conversion 01):
2 . 1 SHIFT 8 0 1 =
and see 5.334
Sep 15, 2010 | Casio FX-115ES Scientific Calculator
How do i remove the c on the bottom of the screen
The C status display indicates that the calculator is set for compound interest during the odd period. To use simple interest for the odd period, press STO EEX.
Jul 07, 2010 | HP 12c Calculator
TI-84 has problems converting between rectangular and polar. is there a fix for this?
The conversion from rectangular to polar coordinates requires the calculation of an angle . If the angle unit that the calculator is configured for is different from the one you have in mind, you get (not erroneous results) but unexpected ones.
If the angle unit under [MODE] is radian, the angle you get in the conversion is in radians. Similarly, if the angle unit is degree, the angle obtained after coordinate conversion is in degrees.
Check your angle unit and restart your calculations.
Feb 19, 2010 | Texas Instruments TI-84 Plus Calculator
My hp is giving me wrong principal and interest payments.
Various formulas for calculating interests exist. Make sure you are using the correct one. If a C appears on the bottom of the screen and to the right, the interests are compounded. If No C is displayed the interests are simple. That could explain the discrepancies.
Oct 10, 2009 | HP 12c Calculator
Texas Instruments BA-II Plus Calculator Logo
207 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Steve Allison
Steve Allison
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
