Question about Craftsman Garden
Sweeper-mulcher starter cord won't move
After several successful starts and stops while picking up leaves, the starter cord won't move. Any attempt to pull the cord just moves the mulcher.
Is this a symptom of something locked in the mulcher blade and is this a home-fix?
    Genius:
  • 1,550 Answers
It indicates something locked in mulcher blade .
This can be fixed by professionals only.
Posted on Nov 09, 2008
    Sergeant:
    Novelist:
  • 196 Answers
Yes it the locking problem for sure.calling a tech is much advisable.
Robo sweeper
ARE THEY CLOGGED AROUND WHEELS WITH HAIR ,AND TRY SOME W D FORTY OIL ,
Apr 09, 2013 | As Seen On TV Robo Sweeper
If my generator shut off due to low lubricant will it reset automatically? If not is there a reset valve/button?
The pull cord is like a starter on a car (separate from the motor/engine). If the pull cord will not turn it could be because the motor/engine is seized.
Mar 04, 2013 | BlackMax 3000 Watt Gas Generator - Powered...
No power
First perform battery test and make sure that your battery is producing the cranking amps to turn starter over. If battery passes battery load test, check and make sure that the battery terminal connecting ends are clean and tight. Check ground cable and make sure that the connections between battery to engine block and frame are good as well. Make sure that the battery connection going to the starter is tight. If that checks out okay, then you may have a bad starter solenoid. Hope this information helps out.
Jan 10, 2013 | Garden
2002 Ford Taurus, V6 3.0 won't start. Attempted to start, but stop mid start. No clicking, just slience. What else?
Just to the left of the battery is the main fuse junction box and below that under the manifold is the starter with the solenoid on top with the positive cable going to the starter check for a loose connection, and the battery ground sould be right there nearby the starter grounded to the block check it also. You could have a bad cable although it may look okay under the insulator the copper cable may be damaged test with a volt meter while moving the pos and neg cables at both ends.
Oct 28, 2012 | 2002 Ford Taurus
Starter turns but no ignition, PK3 M security, the problem is intermittent and does not cause a problem with every start. So far I have been able to get it started after several attempts with differing...
is your security light in dash flashing if so try to start let off key but do not cut off leave key on so all your dash lights are on let vehicle set for at least 15 mins. flashing security light should stop flashing once it stops flashing start vehicle sounds like it has tripped security
Mar 16, 2010 | 2002 Pontiac Grand Prix
1995 Buick Lesabre: security blinks and car will not start
If the starter is turning the engine, try re-setting the security system (leave key on till light stops blinking.) If the starter does not turn, you may have some success in re-setting system, if not you need to check battery voltage and voltages in starter system till you find the problem...can be something as simple as a bad connection at the battery. If you need help with further testing, just ask.
Jun 08, 2009 | 1995 Buick LeSabre
Kia stalled while driving?
Check to see if the serpentine belt is still on the car.
Mar 13, 2009 | 2000 Kia Sportage
Insert disk indicator problem
Unit may have defective disk motor or optical pick-up. There is a chance the lens on pick-up may need cleanning. If you can reach it, try gently useing a q-tip in a circular motion on lens
Jan 06, 2008 | Philips FW-R7 CD Shelf System
Garden Logo
166 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
