Question about Zephyr Venezia ZVE-E30 Kitchen Hood
Lights The lights on my hood will not turn off.
  • howard Hager Dec 23, 2007
    same but a Venezia Zeneth hood.
  • gk4fish Jan 06, 2009
    can't turn my lights off either model ZVE-E36AS
2002 dodge Grand caravan lights will not turn off
You have a relay that's sticking. Open the hood, then fuse box. Turn the lights off, whichever relay is buzzing replace it (they pull out like a fuse). Usually they are around 15-25 bucks at the local auto parts store. Hope that helps.
Apr 27, 2014 | 2002 Dodge Grand Caravan
Fan and lights blew off
check the fuse. (see post about control board.)
excerpt: ... the control board is in the front of the hood behind the speed & light power buttons. There is a 3/4" Buss fuse onboard that seems to pop on my hood every few months.
Mar 06, 2014 | Zephyr Typhoon AK2100 Kitchen Hood
I have a 97 expedition that has the factory towing pkg. I recently went to plug in my trailer that has always worked fine with this truck and no brake or turn lights but running lights. I checked the...
  1. put fuse back in (fire hazzard)
  2. check to see if got a broke wire at the trailer connector
  3. check wiring under truck at connector see if wire is bad (thats why fuse blown short circuit)
Dec 03, 2010 | 1998 Ford Expedition
Can't get interior dash lights or tail lights to work,i have pulled the fuses and checked them, but they were not blown. My headlights, turn signals, and brake lights work but dash lights and tail lights...
you do have a blown fuse, this car has 2 to 3 fuseboxs, the fuse that holds the dash and park lights is located in the under the hood fusebox, its fuse # 8, heres a diagram of the fusebox in the engine compartment under the hood, hope this helps,36e8e5a.gif
Apr 05, 2010 | 1992 Honda Accord
1991 Toyota Camry, tail lights and dash lights don't work
Have you looked under the hood? There are more fuses under the hood. Is your dimmer turned down on your dash lights?
Jan 25, 2010 | 1991 Toyota Camry
Lights won't turn off - everything else works fine
I have a NuTone Allure WS2 range hood. The fan works fine, so does the control board seem ok, but the lights work only intermittently. NuTone tech support said to replace the control board, which I suspect is its kneejerk response. The board costs almost $200--and for two lights???
My problem is similar to the one whose lights work, fan doesn't, but I have a feeling my problem is different.I hope simpler.
Thanks in advance for help (light) on the problem anyone can offer.
Larry R
Apr 23, 2009 | Broan-NuTone Allure III QS330SS Kitchen...
WS3 Broan Allure Range Hood Premier 36 inch
Hi shealy,
I'm Harvey the Master Plumber.
Your problem is: This hood worked fine until a light bulb blew out. Put in a new light bulb, but the lights will not turn off. Is the light switch bad or is there a problem with the control panel? The fan still works fine but the lights will not turn off or adjust dim or bright.
You're on the right track. The light control switch needs replacing. You might try utilizing the Repair Directory to find a repairman. If you have the tools and ability just remember to turn off the electric first.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 08, 2008 | Broan-NuTone WS330 Kitchen Hood
Zephyr Venezia ZVE-E30 Kitchen Hood Logo
62 people viewed this question
Top Zephyr Kitchen Ranges Experts
reliableservice
Are you a Zephyr Kitchen Range Expert? Answer questions, earn points and help others
