Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
WINDOWS ROOT SYSTEM32\HAL.DLL. PLEASE RE-INSTALL A COPY OF THE ABOVE FILE. WINDOWS COULD NOT START BECAUSE THE FOLLOWING FILE IS MISSING OR CORRUPT: HAVING TROUBLE WITH MY RECOVERY DISC OR IT COULD BE THE CD ROM DRIVE NOT WORKING, THAT HAS BEEN THE PROBALBY. i WAS TRYING TO RECOVER AND THE LAPTOP STOP AT 68% AND THIS HAPPEN. HELP
  • proshantosen Dec 25, 2008
    windows could not start because the file is missing or corrupt:
    \system32\hal.dll.
    Genius:
  • 1,124 Answers
This error ocurrs due the incomplete installation.
If your CD drive is not working properly must be replaced
You can try to make a copy in another computer of your recovery disk and then try again.
Or you can insert a windows cd and choose the option R (recovery console) and restore all the original windows files.
Posted on Nov 09, 2008
My acer one has no cd rom and has an error report windows could not start because the following file is missing or corrupt <window root>\system32\hal.dll please re-install copy of the above file
You need to repair your windows, with either using Recovery or get the external CD then reinstall operating system. Hal.dll usually still in your system32 folder but corrupted..
Aug 05, 2011 | Acer Aspire One PC Notebook
Dell Latitude 810 will not boot. When computer is turned on a black screen appears with the message "Windows could not start because the following file is missing or corrupt: <Windows...
Boot to the WIndows XP CD (Press spacebar when prompted to press any key) at first prompt in setup, press R to enter recover console.
At the C:\Windows\System32\> prompt type bootcfg /rebuild then press enter
http://support.microsoft.com/kb/330184
reboot see if error resolved.
If not then try running diagnostics by pressing Fn plus power button, see if there is a HDD malfunction
Jul 16, 2011 | Dell Latitude D810 PC Notebook
When I turn my Gateway Profie 3 computer on, it will not boot up and displays the message: "WIndows could not start because the following files is missing or corrupt Windows^Root^\System32\ hal.dll....
Hi There,
Sounds like you're running XP bercause the hal.dll issue is almost always an XP issue. It's not the easiest thing to fix. Most often you need access to a floppy drive and floppy disc or you have to create a bootable CD that fools the computer into thinking it's a floppy with the replacement installer for hal.dll.
I recommend you read the info at the site below and decide whether to attempt the fix yourself or get assistance at your location.
http://www.computerhope.com/issues/ch000490.htm
Regards,
Selk
Nov 19, 2010 | Gateway Profile 3 PC Desktop
Windows could not stat because following file is
You will need the operating disc to download this file again. If you do not have it it must be purchased through Microsoft
Jul 16, 2010 | HP Computers & Internet
Keep getting this message <window
  • "Windows could not start because the following file is missing or corrupt:
    <Windows root>\system32\hal.dll.
    Please re-install a copy of the above file."
  • "<Winnt_root>\System32\Hal.dll missing or corrupt:
  • "Cannot find \Windows\System32\hal.dll"
  • "Cannot find hal.dll"
The "missing or corrupt hal.dll" error displays shortly after the computer is first started. Windows XP has not yet fully loaded when this error message appears. CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location.Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
    Please let me know you have any further questions or concerns.
Thanks.
May 08, 2010 | HP Compaq 6720s Notebook
  1. Verify the boot.ini file is found on the computer by using a boot diskette or use your Windows CD to get to the MS-DOS "C:\>" prompt.
  2. From this prompt edit the boot.ini, verify that it is pointing to the correct operating system, and that no anomalies are found within the file. Below is a listing of what to verify
  • If only one operating system is on the computer verify that the boot.ini only has one operating system listed. In some situations an alternate configuration line may be added for the same operating system, leaving the improper line.
  • Verify that the "default=" line as well as the operating system line are the same and that they are pointing to the correct operating system.
Verify that the computer has the hal.dll file
From the MS-DOS "C:\>" prompt quickly determine if your computer has the "hal.dll" file by typing "dir hal.dll /s" at the prompt. If the computer returns a "File not found" message, the hal.dll has been deleted.
To recover this file boot the Windows operating system CD and choose the option to "Restore", "Repair", or "Recover." This option will prompt you for the Windows installation to use, the administrators password and will allow you to restore the proper file. At the MS-DOS prompt type the below command.
expand C:\i386\hal.dl_ D:\windows\system32\
In the above example "D" would be the letter of your CD-ROM drive and "C" the letter of the drive your operating system is installed on. For example, your disc drive may be D: and your hard drive is likely C:.
Jun 04, 2009 | Compaq Presario 5000 PC Desktop
Windows error ... \system32\hal.dll. Please re-install a copy of the above file!
Use the recovery disks that came with your computer to do a repair installation. Put the disk in your cd / and or dvd rom, restart computer and select repair installation from the prompt.
May 02, 2009 | Computers & Internet
Windows>\system32\hal.dll. corrupt
HAL.DLL Missing or Corrupt
If you get an error regarding a missing or corrupt hal.dll file, it might simply be the BOOT.INI file on the root of the C: drive that is misconfigured
Insert and boot from your WindowsXP CD.
At the first R=Repair option, press the R key
Press the number that corresponds to the correct location for the installation of Windows you want to repair.
Typically this will be #1
Type bootcfg /list to show the current entries in the BOOT.INI file
Type bootcfg /rebuild to repair it
Take out the CD ROM and type exit
Regards
Mar 26, 2008 | HP OmniBook XE3 Notebook
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
140 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
