Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Water on base of the refigerator
Each morning I have about a bowl of water on the base of refrigerator, is that coming from a leaky condensation hose ?
  • patbrady1961 Nov 10, 2008
    it is a freezer on top
  • Bill Haggerty Nov 13, 2008
    I have the same problem wi a sid by side coming from the freezer side, but maybe not that much water at once. Any ideas?
  • 120 Answers
IS IT A SIDE BY SIDE OR FREZEER ON TOP
Posted on Nov 10, 2008
Ge GSL25JFTA is leaking water on the floor from the front of the unit
Turn off the water supply to the ice maker. If it stops the leak, look for a leaky O ring on the filter. There is a plastic hose that runs out of the front of the refrigerator and goes to the freezer door for the water dispenser. It has a connector near the freezer door lower hinge so the door can be removed easily. That connector can leak as well. There is a condensate pan under the refrigerator that may be over flowing too.
Mar 21, 2015 | GE Refrigerators
I have a LSC27910ST side by side refrigerator that sprays out water from a tubing line on the back of the refrigerator when you are using the water dispenser and also the condenser fan isn't coming on
This tubing supplies the icemaker and cold water spout in the refrigerator. If you follow it back to its source (probably below the floor) you will find a shutoff valve. This valve usually is a screw-in with wings so that you can turn off with your fingers. Turn it clockwise until it stops. The water from behind the refigerator should have stopped. Now you need to determine if the nut clinching the tube to the fitting on the refrigerator is tight. This should be visible near the floor. If it moves easily, like with your fingers, this is the source of the leak and needs to be tightened with a small adjustable wrench or pliers. Then turn the water valve back on and verify it solved the leak. If the leak comes from the tubing itself, you will have to shorten the tubing to the leak or buy a hose to hose fitting if you have to keep the full length. The tubing will cut with a sharp knife, but make sure the valve is off before you try that.
Oct 07, 2013 | LG LSC27910 (265 cu ft) Side by Side...
Hi I have a Whirlpool Refigerator and it drips water from the frezzer into the refigerator thru the two opening up in the back middle opening from the frezzer to the refigerator. It does this off and on
sounds like the drain live from freezer to outside is clogged. the water isnt making it you the condensate pan but coming out in the refrigerator. try finding and cleaning the drain line.
Mar 02, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
Condensation at top of inside refrigerator
you have a drain hose from the top back of the freezer down to the condensate pan on the bottom of the refrigerator near the floor
this hose is blocked causing ice to build up behind the rear inner wall.
remove the back of the freezer wall and using a funnel pour hot water in to the hose to clear the condensate hose also remove all the ice behind the wall; remove the back cardboard to see the water come through the hose into the condensate tray when you pour the water it should pour right through if it's clear
Aug 31, 2009 | GE Refrigerators
Three year old Whirlpool Refigerator (ED5FHEXNB), water leaks from bottom of refigerator when outdoor garden hose water is turned on. Only leaks when outdoor garden hose is turned on. Water filter, Brita...
Hello it sounds like you have a leaking water hose which you need to find. maybe check first where it connects into the back of the unit.. Otherwise the fridge has a blocked drain in the freezer. cheers
May 15, 2009 | Refrigerators
find the drain hole and unblock it faily easy on a fridge on the side by side more difficult need to unplug defrost it remuve the bottom panel inside in the freezeer side of the appliance to access the drain tray do nort attemt to remuve the panel while iced up dfrost is must or coud cause serious damage
Nov 13, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Kenmore refrigerator not cooling
Is there frost on the back wall? If so your coil is frozen up and you have a defrost problem. The water coming out of the freezer door could also be caused by the same problem.
May 05, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Dishwasher does not fill with water
It sounds to me like the base safety float has been activated. This will cause the unit to cancel the program it is in and activate the drain pump, hence the "run" that you hear, but no water. You need to remove the lid and two side panels. If you see water inside the base, you know that the safety float switch has been activated. Remove plug from outlet and empty water from base (by tilting to left side and using sponge to syphon water) Restart unit and check where water is leaking from. Usually from a filling hose not correctly/tightly fitted; leaky inlet valve; leaky heater asembly. Hope this helps! C.
Jun 22, 2007 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
79 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
