Question about HP Office Equipment & Supplies
Message remove and check cartridge - HP Office Equipment & Supplies
    President:
  • 2,712 Answers
First, ensure you are using original HP cartridges. 3rd party and refilled cartridges tend to give this error. If you are using original cartridges, try a hard reset of the printer and see if this helps - unplug the printer from power supply and PC for about a minute and reconnect and see.
Finally, remove the cartridges and try reseating them to see if this resolves the issue. Should the error still persist, it could indicate a sensor failure, which will require servicing.
Hope that helps!
Don't forget to ACCEPT this solution if it helped.
Posted on Nov 09, 2008
  • Swilin Sampson
    Swilin Sampson Nov 09, 2008
    If that doesnt help, please respond with make and model. Use the Add Comment button.
    Scholar:
  • 112 Answers
The problem description you have listed is very vague. Based on the info listed, I would take the cartridge out and put it back in. The problem could be that it is not put in properly. Also make sure it is not empty. Without more description, there isn't much I can do.
    Genius:
  • 1,550 Answers
This indicates that your cartridge is not properly placed .
You need to remove the cartridge and replace it properly.
For further help provide more information .
    Sergeant:
    Novelist:
  • 196 Answers
Just replace the cartridges.
  • mmechanics Nov 09, 2008
    the problem is of the cartridges for sure.replacing the cartridges will solve your problem.
    for any thing else feel free for further queries.
    rate the solution if it helps.
    thanks.
I got a message "Remove and check color
you can try to remove and clean the chip contacts of the cartridge and or the cartridge housing. if it still doesnt work try resetting the printer ink counter.
Feb 28, 2011 | HP PSC 1610 All-in-One Printer, Scanner,...
Error message says "Remove and check cartridge on right" Its a new cartridge I've been using for a few weeks and it has been working fine. I have removed cartridge several times and even cleaned contacts....
The electronics on the cartridge have gone bad. Sometimes cartridges short. Take the cartridge back to where you bought it (they should give you credit for any remaining ink) and buy a new cartridge.
Aug 10, 2010 | HP Photosmart C4180 All-In-One InkJet...
Remove and check cartridge message is on. I've
remove the cartridges, turn the printer off, and on again then install them again, and you are done
Apr 17, 2010 | HP PSC 2210 All-In-One InkJet Printer
Error message HP Officejet 7310 "remove and check cartridge on right. Removed cartridge, checked it (nothing), installed it back - still same message. Installed new original HP cartridge - still same...
Can you find a friend with a similar HP printer, i.e., one that accepts the same model-number of ink-cartridge? If the cartridge gives the same error-message in the other printer, it's time to responsibly recycle your "dead" cartridge, and give the brand-new cartridge to your friend, for his/her usage.
Nov 25, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Error Message: Remove and Check Cartridge. Check
Same problem!
What's the sollution without having to buy new cardrigdes?
Nov 08, 2009 | HP PSC 2175 All-In-One InkJet Printer
"remove and check cartridge" error appears
These messages indicate that the cartridge is not making proper electrical contact, is defective, or is not the correct cartridge. Complete the following steps to diagnose and correct the problem:
Apr 21, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Hp psc2410xi
The following error message appears on the color graphics display after you insert a cartridge: Remove and Check Print Cartridges . The printer will not print. The message does not specify which cartridge has caused the error. Solution This error message indicates that the printer cannot determine which cartridge is causing the error. Follow the steps below to solve the problem.
  1. Remove the color cartridge from the left stall (which has a blue latch) and refasten the latch. Leave the other cartridge in place.
  2. Close the printer, wait 10 to 15 seconds, then look at the LCD display.
    • If the LCD display reads Insert Color Cartridge in Left Stall , the color cartridge may be causing the problem. Follow the steps below:
      1. Clean the color cartridge contacts.
      2. Reinsert the color cartridge into the carriage and close the blue latch.
      3. Close the printer and wait 10 to 15 seconds.
      4. If the LCD display reads Remove and Check Print Cartridges , replace the color cartridge.
    OR
    • If the LCD display reads Remove and Check Print Cartridges , follow the steps below:
      1. Reinsert the color cartridge.
      2. Remove the black or photo cartridge, depending on which one is installed in the right stall. The right stall has the gray latch. Be sure to refasten the latch on the empty stall.
      3. Clean the black or photo cartridge contacts.
      4. Reinsert the black or photo cartridge.
      5. Close the printer and wait 10 to 15 seconds.
      6. If the LCD display reads Remove and Check Print Cartridges , replace the black or photo cartridge.
  1. Remove and then reinsert the cartridge indicated in the error message.
  2. If the error is still displayed, clean the contacts.
    1. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. Remove both cartridges, lower the latches, and close the printer access door.
    2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
    3. Turn the printer back on by pressing the On button.
    4. When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
    1. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty
    Aug 12, 2008 | HP LaserJet 5L Printer
    Remove and check color cartridge
    the problem is the little poorly designed metal thing that is holding up the ink cartridge get's stuck between the cartridge and the printed circuit and it brakes the circuit.must have been some **** drawering on a napkin that came up with that one.wasted a nice unit for that two cent piece of metal.
    Jul 23, 2008 | HP Photosmart 2610 All-In-One InkJet...
    Check drum cartridge
    You need to clean the drum surface as well the charger roller. Removing the paper jammed can caused the surface get the dirty by toner split.
    May 13, 2008 | OKIFAX 5650 Plain Paper LED Fax
    Check black cartridge message
    This happens if you refilled the cartridges, and forgot to take out the air..
    Follow this steps..
    1. Switch on the printer, open cartridge bay, remove cartridge, dont close the cartridge holder flaps, directly unplug the power supply from the printer end.
    2. take a soft cotton, lint free cloth, slightly swab it with pure water, wring the cloth so any excess water is removed, and clean the contact pins inside the printer cartridge holder..
    3. clean the cartridge head by keeping it in hot water (about 50C) and then wiping it clean, keep it upright for a few min, and when both printer and cartridge is completly dry put it back in, voila it should not display the message now...
    Sep 25, 2007 | HP OfficeJet V40 All-In-One InkJet Printer
    16 people viewed this question
    Ben Johnson
