Box went on to stand by on its own and will not turn on again by remote or manually. have tried turning power off and back on but this did not cure the fault. have red stand by power light on but will not turn on. can anyo ne help
Try pressing the small reset button on the back, it works, and you will not loose any stored information which caused the unit to go in the stand by mode.
or
Have you tried turning it off for an hour and then turning it back on. This happens to me quite often and leaving it off for a while ususally allows it to come back on. Also have you tried to press the TV/AV button on the remote as sometimes it switches to TV mode when its on standby and then standby won't work as its on TV mode and needs to go back on to AV mode. Basically just press the AV button on the digibox remote and then try standby.
or
if the batteries are removed and left for about 20 minutes before being replaced again, everything works as it should.
or
if any of the above suggestions does not work then you have to open the unit and on the main board of the tv there is a thin mini tube light like component called fuse you will have to replace that fuse .the fuse is very very cheap and you can easily get it at any electronics shop.and if still the unit does not work then there is a major fault in the power supply board and should be taken to the service center for diagnosing the fault that it is repairable or not.but i hope the above information provided will definately help you to solve your problem.
The codes the manual gives for Amstrad Satellite equipment as... 0317, 0372, 0408, 0488, 0497, 0515, 2014
Or use the auto method...
1) Turn the device you want to program on. 2) Press the button you want to program it in as (i.e TV1, VCR1, etc.) 3) Press and hold the Set and Power Button on the remote for a few seconds, pointing the remote at the equipment. 4) Release the 2 buttons and the light on the remote will flash. 5) As soon as the device turns off press any key on the remote and the light will stop flashing, 6) Check the remote now operates correctly, if not repeat the above until it does
User guide or Manual for Amstrad Sky+ ...YYY 2 posts - 2 authors - Last post: 27 Jun 2007 I need to add a second sat lead from the LNB to the Box. None the less I need a book of words that tells me about the Amstrad 180 sky+ box. ... forums.vnunet.com/message.jspa?message... - 29k - Cached - Similar pages - # Sky Digibox remote control codes for your television This User Manual is the ideal solution if you've bought a Sky Digibox without one. .... it ALSO operated ALL of the functions on my Amstrad Sky+ receiver (not .... in the Digital Installation Manual or via the Sky Customer Service option in ... This actually selects Sky+ mode, but a Sky+ remote works a sky HD box. ... www.satcure.co.uk/tech/digicode.htm - 49k - Cached - Similar pages - # User manual AMSTRAD SKY PLUS - User guide AMSTRAD SKY PLUS ... User guide AMSTRAD SKY PLUS. USING YOUR SKY+ WELCOME TO YOUR SKY+ BOX GUIDE .... to repair your Sky+ box. For repairs, please contact Sky Customer Service. ... safemanuals.com/user-guide-instruction... - 98k - Cached - Similar pages - # For Sale : Amstrad Sky+ Box and QED 1.5m Squart Cable - AVForums.com Due to an upgrade to Sky HD I have for sale my old Amstrad Sky+ box (model no. DRX180). ... Will try to find the manual for it as well. ... www.avforums.com/forums/home-cinema-hi... - 102k - Cached - Similar pages - # Amstrad Sky+ Box - HELP PLEASE! - Sky+ - Digital Spy Forums 6 posts - 5 authors Amstrad Sky+ Box - HELP PLEASE! Sky+. ... The Specifications in the manual state: Hard Drive: 160 Gb (with 80 Gb for personal use); the packaging also has ... www.digitalspy.co.uk/forums/showthread... - 55k - Cached - Similar pages - # amstrad sky plus on standby Following the instructions at the top of page 66 in the Manual fixed it. .... Go back and wait by your sky+ box and you should see the red recording light come on, ... Sky & DLM, Sky Broadband Service Status, SkyUser Bandwidth Meter ... www.skyuser.co.uk/forum/sky/17069-amst... - 117k - Cached - Similar pages - # sky+ box keeps making beeping noise. - Cable Forum 15 posts - 3 authors can anyone tell me how to stop sky+ box from making a beeping noise, ... thanks paul ill read manual & see if that helps. my sky+ is an amstrad pvr3. ... www.cableforum.co.uk/board/64/33616556... - 87k - Cached - Similar pages - # Sky+ box amstrad dx280 - FixYa Technical Support, Instructions & Repair Service. Home | My Expertise | Sign In ... Related Searches: sky remote, sky box, amstrad, skybox, sky manual ... www.fixya.com/support/t1223689-sky_box... - 49k - Cached - Similar pages - # MobilePhoneMadness.com - GUIDE: Upgrading Your Sky+ Box Amstrad Sky+: Equal in size as the Pace Sky+ V2 and looks identical, ... We hope Sky will fix the V1 firmware at a later date, as there no manual fix we can ... www.mobilephonemadness.com/forums/arch... - 13k - Cached - Similar pages - # Amstrad DRX 180 - Review - How did we live without it??? The problem with the cable service, however, is that when you look at the ... No matter which Sky+ box you end up with, the instruction manual is the same ... www.ciao.co.uk/Amstrad_DRX_180__Review... - 82k
i have a amstrad sky box the remote has the record button on it.
i did not change the batteries in it now it wont work the sky box at all.
HELP PLEASE....
HDCP is the encryption sent down when a program is transmitted. Over the years I have had several jobs where this is the case.
What you can do to fix the problem is Download update for your sony bravia telly this will fix the problem. There is another solution, if you get another engineer out ask him to put a different manufacturers box in..... Sky HD is made by Thomson, samsung, pace, Amstrad,
both solutions have worked for me when coming across theses faults whilest installing sky... The first one is going to be your best option... for example at the minute all I am getting when i go to pick my HD stock up is Amstrad. No other manufacturers so you may find it hard for the engineer to source you a different make.
If neither work. Force a download to your HD box (they have been updating the software recently so this may also work for you.)
Take the power out the back of the HD box. hold down the Standby button then reinsert the power. hold Standby button in until all light are lit on the front of the box... Then wait 10 minutes (better off making yourself a cuppa) give that one a try.
if you have had new software downloaded on the box and it still dont work then you will need a new box. have you tried a system download if not then take your viewing card out the sky box then take the power lead out count to ten. then wilst pushing the backup button on the front of the sky box plug the sky box back in keeping the backup button pressed , wait till the on screen message says sytstem download do not disconnect from mains blaa blaa take your finger off the backup button and wait till the tv screen goes blank. give it about 60 seconds then try turning the sky box back on this should work.
I HAVE A SKY+ BOX ALSO , AMSTRAD MAKE ON BACK, TRY SETTING IT TO DIGITAL RECEIVER INSTEAD OF SAT RECEIVER, THEN SELECT THE MAKE PACE, THEN CODE NO 8 ( B676 ) THIS DID TURN OFF MY SAT RECEIVER BUT THEN ACCIDENTALLY SCREWED UP THE NEXT STAGE AND I CAN NOW NO LONGER TURN THE SAT BOX OFF,
BUT YOU MAY HAVE MORE LUCK, IF YOU DO NOT SCREW THE NEXT STAGE UP, BEST OF LUCK
I also have the same problem, commenced today 21/11/08
