Question about Bosch 24 in. SHU5305UC Built-in Dishwasher
Stuck on last minute
The dishwasher has been running for 3 hours and seems to be stuck on 1 minute left. Upon opening, there was sudsy water remaining in the bottom, but the dishes looked clean. The washer just won't go to "CL" in the digitial window.
  • 1 more comment
  • Anne Porcella Oct 26, 2006
    Additionally the drain pump is running continuously (if water is manually added to the unit, it drains right out). Ran the test program and 21 is displayed(as indicated) The fault code of 4 is displayed immediately when the Scrubwash and Del/Econo buttons are pressed a second time...Is this a problem with the board or drain switch stuck open
  • exlost1 Mar 25, 2009
    We have the exact same problem. It's about a year old and our seems to remains on the last minute. HELP!! I thougth I bought a really good brand. My older dish washer worked better.
  • Judgenut Apr 11, 2009
    Exactly the same! Stuck on 1 minute and the pump keeps going. Looks like it may need a new control board...
  • 175 Answers
I have seen a lot of these dishwashers burn out the control board, and usually the symptom is the timer not working or inability to complete a cycle. Most of the ones I have seen, you can remove the control board assembly and its pretty obvious where its burnt. If you can do the repair yourself, the board is about $150. Hope this helps!
Posted on Oct 26, 2006
Dishwasher runs too long
Good Morning Tessa,
I understand that your Frigidaire dishwasher, model# FDB700BFC, is running too long. I also see that it seems to be getting stuck on one particular cycle and runs continuously for hours even though the water is hot. It sounds like there is possibly a miscommunication between the different boards inside your appliance. I please ask that you try resetting your dishwasher, by either unplugging it or shutting the power off at your home's circuit breaker, for 20-30 minutes. Once power is restored, try running any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 16, 2014 | Frigidaire FDB700BFC Built-in Dishwasher
Bosch SHX57 Dishwasher runs for hours.
For the thing: http://www.bosch-home.co.uk/quick-links/customer-service/download-product-manuals.html
Mar 12, 2013 | Dishwashers
When I press the start button, Bosch dishwasher (model SHY56A 05UC) just keep running the motor pumping the water out of dishwasher, irrespective of: 1) the wash cycle it is on, 2) whether the door is...
what is happenig i believe and has happened to me 2 times is that the water level float that is on the left side of dishwasher is stuck.
Either remove side panel and flick lever or pull dishwasher out and tap lower portion of panel and this will cause the level to move and then see hat happens
Nov 26, 2010 | Bosch SHY56A02 / SHY56A06 Built-in...
Our Neff S5454x1/21 dishwasher has occasionally stopped/stuck
Looks like the heater unit has packed up.
I cannot seem to find the actual model you have anywhere on the internet. But I am assuming you connect the dishwasher to cold water inlet and it is meant to have a heater.
Are you in UK or Europe. Bosch also makes parts for the NEFF dishwasher but I am not able to find spare parts for your exact model.
Please post a comment.
Jun 05, 2010 | Neff 24 in. S5453X1 Built-in Dishwasher
We have a Model 587.1440*, 587.1441* Kenmore dishwasher. I had turned the water off to the whole house when we left for vacation and openned one faucet so the water pressure would be off the house while we...
First, have you run it long enough to purge the air from the dishwasher line?
Secondly, the solenoid valve for the water inlet may be stuck due to no pressure on it while you were gone. Tapping it with something light like a wrench may jump-start it.
Charlie
Aug 14, 2009 | Dishwashers
We lost electricity very briefly today which caused the dishwasher, washing, drying, clean buttons to blink when the electricity came back on. I opened the door to do a load of dishes hours after the...
it seems unit fill valve is stuck open and water is coming in even when machine is off.fill valve opens up only when u start the unit.2 chks this u can open the door and look at the hole inside from where water comes in.if water is coming in with dooe open then 4 sure valve is bad and needs 2 be replaced.
Aug 11, 2009 | Frigidaire 24 in. PLD2850 Built-in...
The dishwasher has been running for 3 hours and seems to be stuck on 1 minute left. Upon opening, there was sudsy water remaining in the bottom, but the dishes looked clean. The washer just won't go to...
SHU 53 MODELS To start test program, press and hold both SCRUB WASH and DELICATE/ECONO program buttons, then turn unit on by pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ ?21? = version 1 with jumper). When wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button. To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display alone). Cycle Countdown display will show ?88″ when REGULAR WASH button is pressed and ?8h? when Delay Start button is pressed. To start testing, press both the SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended, Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added together, (e.g./ ?6? = faults 2 + 4). 0 = No faults detected 2 = Heating fault 8 = NTC (temperature sensor) fault 1 = Aqua Sensor (?Sensotronic?) fault 4 = Filling fault F = Filling fault (display occurs during wash, not test) To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty. If water level switch (f1) has failed (opened), display will show fault code ?4″ and unit will continually fill and drain where testing won?t be completed. If flow switch (e5) has failed (opened), display will show ?0″, water won?t heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code ?8″ immediately and testing will end shortly after water has started circulating.
Aug 01, 2009 | Bosch SHU5315UC Dishwasher
Bosch sgi45e12gb/22 dishwasher won't stop
hey you..I have a whirlpool dishwasher too that would not
stop the wash cycle...it would run for 2-3 hours,
and then run thru the whole wash cycle again!
so..I had a whirlpool factory trained repair man come to
the home. He ran a diagnostic and it was 100% good,
so he called Whirlpool headquarters spoke to them;
said...........every 250 hours the dishwasher will
RE-CALIBRATE itself! running for 4-4 1/2 hours
straight, in order to re-calibrate itself. I was
interupting this by opening the door before it had
run the full 4 -41/2 hours of it's self-maintenance program.
Perhaps that your dishwasher is doing too?
p.s. always make sure you get a repairman that
is factory trained in your specific brand, otherwise
you'll waste $$$ money with a repairman who doesn't
have access to the corporate tech's and direct access
to their parts/inventory.
good luck with your dishwasher!
mine is the whisper quiet with computer control on front
of the door.
Apr 11, 2008 | Dishwashers
SHU43 running constantly
Intrrnal leak into base of appliance will make drain pump run constantly.
If appliance fills then dumps water with drain punp then keeps filling/draining sequence then the flow meter could de faulty.
Call in engineer.
Paul Winn Appliance Services (Cumbria)
Apr 02, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 24 in. SHU5305UC Built-in Dishwasher Logo
965 people viewed this question
Top Bosch Dishwashers Experts
shaun taylor
Carmen Mikulic
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
