Question about Sony FD Trinitron WEGA KV-32HS500 32" TV
Tv won't turn on
When you turn the set on with the remote, you hear it power up and almost immediately it turns off, and the stand by light blinks six times. If you unplug the set and plug it back in multiple times it will come on. When it is on it works great. The problem is getting it turned on. The set is 4 years old.
  • Lynn Richey Oct 27, 2006
    actually the light blinks seven times.
    Novelist:
    Champion:
  • 236 Answers
The set is telling you that a circuit is trying to start. Which one?? Maybe the horizontal oscillator or drive or output circuits ? Stargazer
Posted on Apr 10, 2007
SOURCE:
The stand by power lite is steady until you try to turn the tv on, When the tv is powered up, the standby light blinks 6 times, the tv then turn off. no picture or normal sound. what do the six blink codes...
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Mar 11, 2015 | Hisense 32K20DW 32" 720p 60Hz LED Smart...
I have a sony wega trinitron, when the tv is turned on, (no visual, or sound) the red stand by light blinks 7 times, and you hear the tv click off? Please help
Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
Jun 06, 2011 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Won't turn on.stand-by light flashes.timers are
my Sony trinitron kv-g21s2 TV not working . conned to the power blink in TV power indicator led
May 29, 2011 | Sony FD Trinitron WEGA KV-13FS100 13" TV
My tv won't turn on anymore. The power light and the opc light blink twice at the same time and then the opc blinks once and it keeps doing that. Please help!
Hi
Make sure the AC cord is not loose or disconnected. Check to ensure the cord is firmly plugged into the outlet at one end, and firmly connected to your television at the other end. The AC cord connects to the television about midway across the back of the set, near the bottom of the back panel. The hole for the AC connection is shaped like a figure eight. Try powering up the TV with the cords firmly connected.
Check the "Main Power" to ensure it is on. Locate the button on the top of the television among the "Volume" and "Channel" buttons. Press the button to switch the television on. If the "Main Power" button is off the remote will not turn on the television. Wait to see if pressing "Main Power" will activate the TV.
Press "TV Power" on the remote control to power up the TV from stand-by mode. If the power light on the front of the television glows red when you press "TV Power" on the remote, press the "Main Power" button on top of the television to remove the TV from stand-by. If the TV is accidentally in stand-by mode it may not come on when pressing certain buttons.
Check the circuit board. If your set still won't turn on and you hear a clicking noise when you plug it in, you most likely have a defective circuit board.
Oct 23, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
I have power but it will not turn on. unplugged from power cord overnight then plugged into wall worked fine until i shut it off again, now it keeps blinking the delay light
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
Feb 14, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
TV will not turn on
Sounds like the thermal fuse has gone bad. Sony part# 191002393. Very enexpensive part. It is located near the lamp housing from the back of the set. Once you have the new part in your hand, it will be easy to find.
Jun 01, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Stand by light blinks 6 times, wont power on
Here you find sony blinking codes
SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking selfdiagnosis
function immediately. Check C515 & 516 and the jungle IC, IC206.
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k
Aug 10, 2008 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Sony tv repair
I own a Sony T.V. model #KV36HS510, Serial # 9024184,Event# E36002407 and it"s aTrinitron brand name. Like the problems before no picture or sound, stand by light on front of unit flashes. When trying to turn it back on you can hear the power click, like it wants to turn on, but does not.
Dec 22, 2007 | Televison & Video
Will not turn on
how many times does the light blink? There is a diagnostic set-up built into these Sony TV sets.
Apr 01, 2007 | Sony KP-51HW40 51" Rear Projection...
Sony FD Trinitron WEGA KV-32HS500 32" TV Logo
73 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
