Question about Fedders AED24E7F Wall/Window Air Conditioner
Ac split unit indoor an ouydoor unit electrical wiring diagram
I need wiring diagram of ac split unit indoor an outdoor unit
  • 2 more comments
  • Anonymous Nov 24, 2008
    same
  • Ken Bledsoe May 11, 2010
    Still need wiring diagram?
  • Anonymous Mar 20, 2014
    Where can I find one?
    Split unit AC
  • Anonymous Mar 25, 2014
    How much voltage should I have on the communication wire at the outdoor unit when there is a need for cooling
Machine off
Posted on Apr 25, 2009
Each time i turn on my split unit, it will work for about 5 minutes before blowing up the little 5amp fuse at the circuit board of the indoor unit. Please advice.
Posted on Mar 31, 2014
If want a/c , frigde , washing machine service
concact ; 9043430168
9840928608
only for chennai people
Posted on Mar 19, 2011
WHAT IS REFRIGERANT SUCTION PRESSURE OF MY 1 TON SPLIT AC?
R22= 70-80psig
R410a=120-130psig
Depending on many variables such as blower speed, coils clean, indoor/outdoor temps.
Aug 05, 2015 | AMVENT 18000 Btu 1.5 Ton Ductless Mini...
My LG split Ac is running some times but some times not working and showing error code CH09
Split = Outdoor unit fan problem. Check Outdoor fan motor is plugged in, Electrically & Mechanically sound, if not replace motor, otherwise replace PCB.
Multi V= Indoor unit EEPROM error - Replace the indoor unit PCB, and then make sure to do Auto addressing and input the address of central control.
Jun 06, 2015 | LG Heating & Cooling
Need a wiring diagram for split system heat pump model number ch5536vkc2
need more information to help you.
1) is it single or 3 phase?
2) what power does it have? (example 30000 btus )
3) is it for the indoor unit or for the outdoor unit,? or both?
4) does it has an electronic circuit board in the indoor unit?
5) do you need only the field wiring diagram from indoor to outdoor unit?
Post me back with some details and I may help you out
Best regards,
Silvio
Dec 08, 2014 | Heating & Cooling
ELECTRICAL INSTALATION OF MINI SPLIT AC MODEL AS18CDB
YOU CHECK THE ELECTRIC SCHEMATIC YOU FIND WIRING GOES FROM INDOOR UNIT TO OUTDOOR UNIT MAY 4 OR 3 WIRES SIZE 2.5MM
Aug 22, 2009 | Heating & Cooling
Indoor an outdoor unit wiring diagram
have you tryed to look it up on the net.a lot of the time you can get that sort of info off the web
May 02, 2009 | Heating & Cooling
Panasonic cs-pw9gke i need wiring diagram
Split A/C-Cold:
You need four wires(two #10 and two #12) to the outdoor unit, leaving you house, and three wires(#10) coming from the breaker to tye indoor unit inside your house.
Split A/C-Cold and Hot:
You need five wires(two #10 and three #12) to the outdoor unit, leaving your house, and thee wires(#10) coming from the breaker to your indoor unit inside your house.
This ypical arrangment(all of them use three wires fro the breaker), yet there are other units which may require 6-7 wires connected to the the outdoor unit depends on the added features to the unit.
Regards,
Gulftecheng
Dec 05, 2008 | GE Quiet-Aire Ductless Split System Air...
Split AC install
1. mind it - its a very simple installation
2. connect suction (or big cu. dia tube) connection to cond. unit (outdoor unit) big valve.
3. same way - liquid conn.(less dia tube) to small valve (liquid valve) in outdoor unit.
tight flare nut properly
4 provide power to indoor & run the same wire to cond. unit , you must hv got the ins. kit with wires and cu. tubes.
5. or read wiring diagram given of units for wire.
connect as per wiring dig. provided.
ravi
Jan 30, 2008 | Samsung AS18A6RB Air Conditioner
Fedders AED24E7F Wall/Window Air Conditioner Logo
5,982 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
