Question about Panasonic PT-47WX51 47" Rear Projection Television
PT-56WX51E panasonic cinemavision - Panasonic PT-47WX51 47" Rear Projection Television
SOURCE:
Slinteriors
  • 8617 Answers
SOURCE: panasonic cinemavision pt-53wx54j
if the led is blinking one time its the 140 volt circuit. If its blinking a series of 3 blinks its the convergence circuit
Posted on Feb 16, 2009
hacker8499
  • 74 Answers
SOURCE: Panasonic CinemaVision PT-47WX53G : half the screen is distorted
did you try to try to adjust the vertical and the horizontal of your tv?
Posted on Oct 05, 2009
SD Tech
  • 14553 Answers
SOURCE: I have a Panasonic PT-56Wx51E that started showing
This is really a very simple thing to diagnose---go into the customer menu and select convergence--if red or blue is skewed there and will not adjust in some direction--you have a convergence circuit problem.
These sets use two convergence IC chips--if convergence will not adjust you need to replace both chips along with any of the resistors around them that protect the set and are bad.
Parts are cheap for this ----less than 30 dollars for everything you will need.
Based on the Pt56wx51e model number this set uses two of the STK-392-110 chips--they are black and side by side on metal heat sinks with fins and will have the full STK number printed on them in white letters.
Most shops get 300 or more for this kind of repair. If you or someone you know can do it you can save a lot of money.
The repair really only involves two things: getting at the chips and parts and being able to unsolder and replace them.
I HAVE START TO FINISH STEP BY STEP INSTRUCTIONS FOR THIS REPAIR ON THIS MODEL. They will tell you everything you need to do the repair and how to do it--I have fixed hundreds of these sets with convergence problems.
If you think you can do it let me know and I will post the full instructions here for you.
Once the problem is fixed the set will not have the same trouble for 5-8 years--lifespan of the parts.
If this has helped you rate this solution as I do this here for free.
SD TECH
Posted on Dec 06, 2009
Testimonial: "The information was very informative and with it I will be able to fix the problem. Great response time, Thanks. Please post instructions for this. "
SD Tech
  • 14553 Answers
SOURCE: bad color then no power on 51'' panasonic cinemavision
Check the power light for blink code--usually if this model shuts down the power light will blink in a sequence--3 blinks a pause and 3 blinks is short protection--usually means a convergence circuit problem.
Let me know what you find--I am here to help.
if this helped you rate this solution as I do this here for free.
SD TECH
Posted on Dec 17, 2009
falspet
  • 438 Answers
SOURCE: Panasonic Cinemavision PT-56hx41e, wording on screen is red?
the convergence circuit governing the red picture has gone defective and needs attention possibly a convergence amplifier IC or and convergence coil at the red CRT went defective
Posted on Apr 28, 2010
Panasonic Cinemavision (Another Problem)
3_24_2012_6_00_06_am.jpg This is a common problem on many brands of Projection Tv sets. Its usually a convergence issue. You can get more details and a solution here on fixya using this link http://www.fixya.com/support/r11932741-convergence_repair_dull_video_repair
Mar 24, 2012 | Panasonic PT-47WX52 47" Rear Projection...
Apr 28, 2010 | Panasonic PT-56HX41 56" Rear Projection...
Where can I get a bulb for Panasonic CinemaVision 2002?
eBay is always good here is a link for a search just find the model you need. LINK
Apr 08, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Bad color then no power on 51'' panasonic cinemavision
SD TECH
Dec 17, 2009 | Panasonic PT-51HX41 51" Rear Projection...
I have a Panasonic PT-56WX51E that started showing double images with a green & red tint, above the original image. I have attempted to connect straight to the box, using DVD & VCR to see if the...
SD TECH
Dec 06, 2009 | Panasonic PT-56WX51 56" Rear Projection...
Oct 05, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic cinemavision hdtv 1080i projection TV. Is this tv digital? how does one access the digital aspect?
go to this link for the manual.
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=d17d8491251fb501911086409da7f697&modelid=275504&q=Panasonic+PT-47WX49
Jun 11, 2009 | Panasonic PT-47WX49 47" Rear Projection...
No hdmi input?
You can use the component inputs on your Tv which is almost as good.
Mar 30, 2009 | Panasonic PT-47WX51 47" Rear Projection...
Panasonic cinemavision pt-53wx54j
Feb 15, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-53WX53 cinemavision HDTV keeps powering off right away
5 blinks is telling you that IC4511 on the DG board is faulty. This is not serviceable you will need a new DG board the part number of that board is TNP2AA126
Mar 25, 2008 | Televison & Video
Panasonic PT-47WX51 47" Rear Projection Television Logo
32 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
