Question about GE JVM1190 Microwave Oven
JVM1190 wont cook
I have a GE JVM1190 that will not cook. The clock and all control panel functions seam to work normal. I can make the range fan and lights work, set timers, etc. When I try and cook with the unit the interior light comes on and the timer counts down but no microwave action (fan or unit hum) same with convection bake. Thought it might be a door switch but I would think the clock would not count down or light come on like it is operating, any suggestions?
  • 1 more comment
  • werlingfamil Nov 09, 2008
    I messed with this today after looking up some suggestions and found the door safety switch was bad. There are two stes of switches on the door latches. The top has a close switch and the bottom has a close switch and light switch. I jumped the switches and was able to make the micro wave work which told me the problem was in the door switches. I alternated jumping one switch and leaving one connected and found that the top door switch was not working. I removed the top door switch housing and removed the switch. i appeared as the switch and trigger were working properly. I opened up the switch and blew out any dust that may have been interrupting the contacts. I reassembled the switch in to the door switch housing and all worked fine. Not sure if it was in the switch it's self or the housing may have not been aligned properly. Alls well that ends well.
  • ajbn Mar 18, 2012
    Had the same problem Mar.2012 & your fix worked like a charm - THANK YOU!
  • Bill Sempel
    Bill Sempel Feb 23, 2013
    Thank you for posting this. I was able to troubleshoot my unit and test resistance of each switch. Found the top switch was not activating.
  • 44 Answers
You have a blown actuator. This is the device that creates the microwaves that cook the food. The cost of one of these will be as much as a new unit.
Posted on Nov 09, 2008
  • Scott Jelt
    Scott Jelt Dec 03, 2008
    Sounds like you need to be the one answering questions on this site not asking them.
  • jim harrington Jul 08, 2013
    thank you
What is the cubic feet for jvm1190
GE JVM1190 825 Watts With Convection Cook Microwave Oven. 1.1 Cu.ft. 825 Watts output power
May 15, 2014 | GE JVM1190 Microwave Oven
My daughter's GE Model JVM2070SK02 failed to shut off this morning which ignited a muffin that was in the microwave. She stated that she had been having problems with it that that required unplugging the...
It sounds like a cook relay stuck closed and this is why it continued to cook. When the door was opened it should have blown the monitor fuse (which is how it is designed to for safety) so that it cannot cook when the door is open. Or, a cavity temp fuse was blown due to the fire inside. Also a safety feature.
Oct 08, 2013 | GE Profile Spacemaker Over-the-Range...
I have a GE Profile Spacemaker model JVM1660SB005, maufactured in November 2000. I attempted to change a burned out bulb on the left side. I did not check the manual to see how to remove the bulb, nor...
I regularly see (and repair) this light and / or fan failure on model JVM1660SB005 and most any model of over the range microwave.
The problem is on the controller assembly, which I regularly repair very affordably.
At my Web site, you can get details, plus I have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
For more free DIY and other help & advice, feel free to contact me via my site.
Please include FULL model number*, FCC ID number*, + detailed symptom information. ( * on the tag in cooking cavity or around door frame or control frame or on back)
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 05, 2017 | GE Microwave Ovens
Mar 05, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE JVM1190 Microwave Oven. It's sounds
It's cooking when it shouldn't, but the internal cooling fan is not running, so the magnetron is overheating, which can kill it.
Then when it gets hot enough, it trips the magnetron's thermostat, interrupting all power to the microwave. When it cools, it comes back on.
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and of course one should never leave a microwave unattended while cooking.
The problem is almost certainly that the power relay on your control circuit board is shorted.
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid with a one-year guarantee.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more free information & help.
prototech@usa.net
http://www.microwavedisplay.com
Jun 15, 2010 | GE JVM1190 Microwave Oven
I have the ge profile performance jvm1190 the heat doesnt work and when u push the quick cook buttons F4 appears on the display? can this be fixed?
F4 would be an open humidity sensor.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If there is no heat when you just cook normally (as opposed to the quick cooking) then some questions arise:
When you hit "Start" to microwave, do the inside light, cooling fan, and turntable all come on?
If not, then you probably have a bad door switch or door switch mount and should see these files:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
If the inside light, cooling fan, and turntable are all coming on, then the problem is in the high voltage section, and then the next questions arise:
Any unusual noises? Is it louder or quieter than usual?
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are operating here.
A loud buzz, hum, or groan is usually a shorted high voltage rectifier diode, but a sound like gurgling into an empty coffee mug is one symptom of a failed magnetron, and yet the mag can be bad without that sound.
If there's no unusual noise, it may just be a bad connection at the magnetron.
Here are some links you or someone you know can use (in order given) for high voltage section test help, but read the safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it is NOT shorted or burned looking, it's probably fine)
http://www.gallawa.com/microtech/mag_test.html
(continuity can be good even though mag is bad!)
http://www.gallawa.com/microtech/xformer.html
You can find links to helpful exploded view diagrams and part ordering help here.
I'd recommend that your bookmark this link to your favorites.
Accessing some parts may require you to pull the oven from the wall and remove the cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Jan 15, 2010 | GE Profile Spacemaker Over-the-Range...
Have GE JVM2050 over the range microwave, which stopped heating food and water since this morning. All other functions including light, key pad, clock, turntable work normal. The magnetron sound also
if everything works except the heating, it is most likely the mag tube is on its way out.........that is the most common reason for it not too cook.......since the microwave is a GE and it is 3.5 years old, i would say you are better off buying a new microwave, the mag tube starts at around $70.00 and up + the labor it costs too have a service person put it in........around another $60.00
May 02, 2009 | GE JVM2050 Microwave Oven
Ge JVM1190 appears to be working but does not cook.
I spoke with a qualified microwave technician who advised me to buy a new microwave as the problem I was having indicated that the magnetron tube had blown. What a waste of time to ask for help from you.
Sep 01, 2008 | GE JVM1190 Microwave Oven
My jvm1190 reads F4 when we try to use auto functiions
There is a fuse blown, but I can't explain how to replace it. They are inside the unit. Good microwaves have many fuses and can be powered up, but have a blown element fuse.
Nov 10, 2007 | GE JVM1190 Microwave Oven
GE JVM1190 microwave oven light comes on, but no the FAN or "microwaves"
If it were just just not cooking, I would suspect the magentron. But since the fan is also not working, I think you have a bad door switch. If you or a friend decide to work on it, we have *critical* safety and disassembly info at our site, as well as other specific troubleshooting information and help. In my professional opinion, no one should work on a microwave unless they are fully informed and aware of the deadly hazards and necessary precautions. You can find safety and disassembly text files (as well as a text file which helps in diagnosing and repairing door switch problems) at http://www.microwavedisplay.com You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Apr 08, 2007 | GE JVM1190 Microwave Oven
GE JVM1190 Microwave Oven Logo
1,104 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
