Question about Gyration Televison & Video
Gyration Air Music Remote
I am trying to program a Gyration Air Music remote to control an Arcam A70 amplifier. Arcam is not listed in Gyrations user manual under their list of 4 digit codes to control other manufacturers devices but they say that Arcam will use a standard set of codes that other manufacturers use and I should contact Arcam to find out what codes they use. I have contacted them and they do not know what I mean. Do you know how one can find out the codes to control this Arcam amp? I can be contacted on garistina@runbox.com. Many thanks, Douglas Garistina
SOURCE: Olevia 242T television
The code you want is 11610. Buy a remote that can accept this code.
Posted on Apr 17, 2008
TVtechmaniac
  • 140 Answers
SOURCE: "Code List" for RCR311B
http://remotefinder.rca.com/default.aspx?site=rca
Select your remote model RCR311B from the pull-down list, then select the device your want to program, then select the brand and it will give you the codes....
Posted on Jul 22, 2008
  • 8 Answers
SOURCE: rca universal remote control
Manual Code Search and Entry 1. Manually turn on the TV
2. Press and hold the TV button The illuminated ON•OFF key turns on and remains on.
3. While holding the component key down, press and hold the ON•OFF key. The illuminated ON•OFF key turns off.
4. After holding down both keys for three seconds, the illuminated ON•OFF key turns back on.
5. Release both keys. The illuminated ON•OFF key remains on. TIP: Throughout the programming of each key, be sure to keep the remote pointed at the IR sensor of the component you are currently programming the remote to control.
6. Press and release the ON•OFF key repeatedly until your component turns off. Each time you press the ON•OFF key, the illuminated ON•OFF key blinks, and the next
code in the list is sent. This process continues until all of the codes in the Code Lists have been searched. If your component turns off, you have found the correct code.
TIP: Because there are so many codes, you may have to press the ON•OFF key many times-possibly up to 200 times.
7. Once you have found the correct code, you must save the new code by pressing and releasing the STOP key. The illuminated ON•OFF key turns off. You must press the STOP key to save the code or the correct code will not be stored!
8. To confirm that the component key is programmed with the correct code for maximum functionality, test the component. Attempt to control a variety of the component's functions with the remote. If some of the features of your components do not work, try programming the remote with a different code in the list until you find the code that allows the remote to control the majority of your component's functions. Different codes can provide different levels of functionality
Posted on Jul 28, 2008
SOURCE: dmtech remote control programming codes
I have been looking for the same codes myself and all I have found is: 0157 0159 0335 1994 2024 2031 0067 0312 0910 0208 0586
hope one of these work for you.
Posted on Dec 31, 2008
Techjoel
  • 79 Answers
SOURCE: 4 digit code for handheld remote control to program a Crest Universal remote control
Here are the codes for the RCP3 and RCP5:
RCP3 1023 1024 1074
RCP5 1014 1024 1074
Posted on May 12, 2009
What is the TEAC amplifier code in Newstar Universal Remote Control NTR-D85E
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; to which you want set-up codes; in the "Search box at the top right of the display window" to get gathered related posts.
Feb 19, 2017 | Universal Remote Control Televison & Video
I have a universal remote and trying to program it to work with Kirsch k3 5.1CH surround reciever amplifier. Already tried auto search and no codes in the booklet that it came with please help thanks
Programming Notes
Nov 02, 2016 | Universal Televison & Video
I have a universal control and i don't have the codes for it to work the tv
    Remote Control Code List
    www.jumboremotecontrol.com/remote_control_code_list.html
    Jumbo Universal Remote Control · 8 Device ... Programing codes for the remote. If you do not see your device listed, you can use the code search feature to program the device into the remote. TV Codes ... JVC, 013,054,055,060,065,067,089.‎Guide to Programming the ... - ‎Download the Manual - ‎8 Device Learning Jumbo ...
    What is the universal control remote code for a JVC television?
    www.ask.com > Technology > Television & Video
    JVC universal codes can also be found on the instruction sheet or manual guide that comes with the remote control or television set. If these universal codes do ...
    JVC Remote Codes
    remote-codes.findthedata.com/l/163/JVC-Remote-Codes
    A list of TV, HDTV, DVD, Receiver, Audio, Amplifier and and VCR remote codes forJVC. images for codes for universal remote control jvc
Jan 03, 2016 | JVC AV-32D305 32" TV
Need program codes for one for all remote\
Which One For All remote do you have? The manuals and code lists for most are available here: http://www.oneforall.com/support/manual . Use the drop down menus to select Universal Remote Control and then the specific remote model. Then click on the link to the manual.
You may need to program the amplifier and the dvd player separately. The codes below are for the URC-9960.
RCA Audio Amplifier codes: 1023, 1254, 0531, 1390, 1609
RCA DVD Player codes: 0522, 0571, 0717, 0822
Please note that universal remote controls only have codes for devices released 6 months or more before the remote was programmed. If your Home Theater System is newer than your One For All remote, you may need a newer remote.
I hope this helps.
Jun 24, 2011 | RCA RTD215 Theater System
Gyration GYR3101US not working
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. In some cases, the remote control might need to clean.
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly.
https://youtu.be/wUpnETSm6_k
https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean]
https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean]
Apr 23, 2017 | Gyration (GYR3101CKUS) Remote Control
Can't play iPod on my panasonic sa-en27 with out a remote
I ran into the same issue, instead of buying a replacement remote I was able to dial in a Vip 211 dish network remote control with remote code 643 in AUX setting. Then once the code was in, i pressed the 6 key on the remote and now I can listen to audio on the music port. The 643 code refers to the first Panasonic amplifier/receiver in the code list. To further clarify, I pressed AUX for 4 seconds, pressed 2 to signal I am programming an amplifier/receiver device, then punched in 643 then pound sign.
Good luck with yours.
Feb 14, 2009 | Panasonic (SCEN25) Shelf System
Gyration remote control will not sync with the rf receiver.
I had this issue and this is what I did.
1: Control panel
2: Double click Mouse (To access "Mouse Properties)
3: On top click Hardware
4 Check how many hardwares you have and one by one highlight them and click properties and update the drivers.
Try that and post any message
Jan 12, 2009 | Gyration (GYR3101CKUS) Remote Control
Gyration remote issues
Yeah I had the same problem...there is one screw you can get to when you take the batteries out and then I had to use a screwdriver and jam it in the side to get it to come apart. There is a metal casing for the Gyro part that came off and was messing it all up...soooo I just left the metal casing off(because it was glued on it won't stay on now) and it works fine!!!
Nov 06, 2008 | Gyration (GYR3101CKUS) Remote Control
Televison & Video Logo
234 people viewed this question
Top Gyration Televison & Video Experts
Are you a Gyration Televison and Video Expert? Answer questions, earn points and help others
