Question about Bose Lifestyle 12 System
Changing out my monitor speakers to bose cube speakers
Will it be easy for me to change out my monitor speakers for the bose cube speakers. In back of my monitors speakers are four wires to different terminals. Will this change out be simple or complex.
Wilton Decuir
  • Anonymous Mar 18, 2014
    Wires will not terminate into connection
  • 34 Answers
You probably can do it as long as the speakers there now are 8 ohm speakers and you must use the bose bass module with the cubes because the crossover is built into the bass module for the cubes to work. If you just wire up the cubes you will mess the cubes up and they want sound right at all. The cubes are no good without their bass module in other words. Hope this helps.
Posted on Nov 10, 2008
How do I put the springs (that hold the speaker wire in place) back into a bose v20 lifestyle 2 cube speaker?
These tiny mechanisms aren't easy in the least to repair. They were never intended to be repaired. Remove the front grill and remove the driver (Speaker) to get at the mechanism inside the enclosure. An ink pen spring will probably work fine for a replacement. If this fails and you still want to have use of the speaker you'll have to drill a hole in the back of the enclosure and connect to the terminals from the inside of the cube enclosure.
Mar 01, 2015 | Bose Audio Players & Recorders
How to put together a double cube bose speaker
The Bose speakers with the cubes and bass module are all interconnected with a proprietary cable available from Bose, if lost you get a replacement by called 1-800-444-BOSE.
When you connect the speakers all wires run from the receiver to the base module first, then out to each of the speakers. All terminals on the bass module are labeled.
The Bose cubes are all identical and can be used in the front or back positions.
Try to keep them at ear level or aimed at the listening position for best sound.
May 17, 2011 | Bose Acoustimass 15 System
Want to connect non-bose speakers to a bose lifestyle system
this is possible, however not a very good idea.
Bose speakers are designed a little different than other brand speakers, the Equalizer built into the bose system will probably not sound amazing when you hook up your other speakers. Are you looking for more bass? cleaner highs?
if you want more bass, you could try doubling up your subs, if you want cleaner highs you could buy Bose Jewel Cube Speakers (purchased from a Bose Built-Invisible Dealer
Jul 28, 2009 | Bose Lifestyle 38 System
Bose 'Double' Cube Speaker Came Apart
Carefully unsnap the speaker cover you may want to use a jewelers screwdriver or a small flat tip to assist with getting it off. Once its off unscrew the 4 screws completely and then carefully wiggle the speaker from he cube. Once the speaker is out of the way reach in the cube and reset the plastic coupling so its flush with the inside top of the cube. With both cubes on there sides and the rubber washer and swivel ring in place press the bottom cube, with your finger(s) inside the cube on the plastic couping, up into th top cube until you here or feel it snap into place. Once it snaps into place, adjust the insulation in the speaker then wiggle the speaker back into the cube and carefully put the screws back in. Once this is accomplished snap the speaker coverback on and that's it. It takes ten minutes once you get the speaker cover off.
Jun 08, 2009 | Bose Lifestyle 12 System
Replacement speaker (upper) for Bose double Cube.
try a music specialty store or radio shack if you want to only replace the small speakers inside the cubes. If you want to replace the whole cube, there are others out there. Look on ebay and or amazon I think the brand is JA Audio. A knock off of the bose cubes that can be used as stand alone speakers without the module.
Jan 05, 2009 | Bose Acoustimass 15 System
Front bose speakers and bass module stopped puttimg put sound
If you're saying you hooked the Bose speakers directly to the Yamaha's amp instead of the prescribed way through their own bass module - they're cooked.
Dec 23, 2008 | Bose Lifestyle 12 System
Bose Cube Speakers separated
I had the same problem with a Bose separated double-cube Acoustimass speaker/array but was able to fix it as follows:
small, thin, flat-head screwdriver
large pliers
1. Disconnect the speaker wires from the cube.
2. Remove the grille from the top speaker cube. It just pops off.
3. Insert a small, thin, flat-head screwdriver around the perimeter of the speaker. You will have to pry lightly to break the glue’s seal.
4. Using a set of pliers (large, plumber-sized) wiggle the speaker until it comes free. You might need to grip it top to bottom and then left to right. The speaker will come free of the case.
5. Remove the white insulation to get a clear view of the dislodged brace/connector.
6. Stack the top and bottom cubes. Make sure that the rubber seal between the cubes is seated properly and that the black and white cables are not pinched.
7. Using the C-clamp, compress the brace/connector until it seats on one side. Loosen the C-clamp and compress the opposite side. The brace/connector should snap into place. Be sure the make sure that you do not pinch the speak wires that are running through the center of the brace/connector.
8. Test the articulation. It should be the same as your other speakers.
9. Replace the white insulation in the back of the speaker case.
10. Press the speaker into the case’s face. If you wish, you can apply your preference of glue to the edge of the speaker prior to pressing it into the case.
11. Snap the grille onto the speaker.
12. Connect the speaker wires to the cube and you are done.
You should be good to go.
Aug 29, 2007 | Bose Lifestyle 12 System
Bose Lifestyle 12 System Logo
423 people viewed this question
Top Bose Audio Players & Recorders Experts
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
