Question about Yamaha YAS-70 Front Surround System Black Theater System
Possible Short When powered on the device cycles up and then turns off. Can not maintain on. Checked manual and tried standby with 30 second unplug as well as reseating all cables. No luck. Thanks.
    President:
  • 624 Answers
This is called the "protect mode" and it does this to keep the unit from more damage, meaning that the unit has some type of damage now and if it were to remain on it will cause more damage.
Most of the time this will happen because of a bad channel in the amp circuit. On more rare occasions it is the power supply causing it. The only way to fix this problem is to repair whatever damage has been done to it.
It will take the proper tools and some electronic troubleshooting skills to fix it. If you have a multimeter and soldering equipment I can help you with this and tell you the most common places to check for problems, but it will require some minimal skills on your part like being able to identify certain parts and be able to pay very close attention to details, and understanding certain electronic terms. If you would like to try this yourself let me know, otherwise, you should take it in to a service center and let a professional check it for you. You can get an estimate first before deciding if it is worth fixing.
Dave
Posted on Nov 09, 2008
Resetting computer on kdte204dss0 Kitchenaid
The most common reset for the dishwasher is:
1. First, unplug the dishwasher power cord or turn the circuit breaker off for 30 seconds.
2. Then, plug the dishwasher power cord into the wall outlet or turn the breaker back on and wait 30 seconds.
3. After that, press the Pause / Cancel / Stop button twice to clear the display.
4. Finally, start a short cycle, to check operation of the dishwasher, by selecting a cycle and pressing and holding the start button until the dishwasher starts.
Jul 28, 2016 | KitchenAid Dishwashers
Our machine is frozen not responding to panel buttons
You can try resetting your dishwasher.
Jul 28, 2016 | Dishwashers
Vizio vw37l hdtv20a standby light on but wont turn on
you either have a faulty power supply or faulty main board. Vizio power supplies on the older sets are pretty decent. It's usually the main boards that go. These older main boards tend to be pricey so it may be better to buy a new set.
Mar 27, 2013 | Vizio VW37L 37 in. LCD HDTV
Hi, i have a samsung 42" flat screen thats just over 3 years old. Last night we had a power cut and when power came back on the tv didnt. It has power going to it as light is on but all it does it...
Seems there is a short in the board caused by the instant power outage. So it is necessary to open the set to have a view. It seems possible there is a damage on the drivers on the power board to the lcd panel. You will need to trace by checking for short , check for components heating - since the power is tripping due to the short which makes it feedback it as a protection to cut off.
Remove power leads to suspected section to confirm as the power will build up. You will need some experience to work by tracing if not please do not tamper but get help.
Aug 25, 2011 | Samsung Televison & Video
I have a Sony KDS-R50XBR1 that has no picture. When I turn on the TV, the green Power/Standby LED light blinks for about 30 seconds, then turns red and blinks five times. The Power/Standby LED repeats...
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen A2 slightly.
Jan 19, 2011 | Sony KDSR50XBR1 50" Projection HDTV
Will not power up. Stays in standby mode.
these particular tvs are very sensitive to voltage changes spikes etc.first turn off main power switch wait at least 30 sec if standby come on wait another 30 then turn off main power again and unplug tv for 1 min then plug in turn on main switch wait 30 sec then turn on tv with remote resets system.then buy a ups and always wait at least 30 min after turning tv off to turn back on if not causes power failure and after each press of power button wait 30 seconds before trying again lmk good luck
Jan 08, 2010 | Hitachi 42HDS69 42 in. Plasma Television
TV switched itself off. Standby light flashing on and off once then five rapid flashes. Tv would come on but then turn off again after a few seconds.Standby light even stayed on when tv switched off at...
Subject
Unable to Power On or Off the set
Symptoms / Customer Description
The symptom may occur while the TV is ON or in Standby.
1) If the problem occurs while the TV is in Standby:
The TV will not turn on via the remote or power button located on the set however after AC reset (i.e. unplug the TV for at least 30 seconds from the AC source) the TV returns to normal operation.
2) If the problem occurs while the TV is in use:
You may lose the ability to power off the TV or switch the video inputs however channel changing, adjusting volume, or accessing the menu may still be possible. After AC reset (i.e. unplug the TV for at least 30 seconds from the AC source) the TV returns to normal operation.
Sony has designed the BRAVIA Televisions to be CUSTOMER Software Upgradeable and therefore Sony will not pay a service claim on any issue resolved by a software upgrade. If a customer requests an update please refer them to the following website: http://www.updatemytv.com. If the unit requires the update, you may enter the customer's information in the website and a USB device will be sent to their address.
If a customer does not have access to the web please have them call the Sony Call Center Support line: 1-866-210-6333
If a customer reports either symptom above request that they unplug the set from the AC wall outlet for at least 30 seconds and then plug the set back in. This will reset the TV and it should work fine for several months. If resetting the TV does not resolve the issue the customer has a different problem and a service call by a technician may be required
Jan 02, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Enters standby after being on for only a few seconds.
Sounds like either the volume is turned up too loud, or you have a short. Have you tried disconnecting all the speaker leads from the rear, and then powering it on? Usually if it turns on for a short time and then shuts off, it is throwing itself into protection mode.
Sep 07, 2009 | Yamaha RX-V363 Receiver
Receiver turns on and off in endless cycle
Its one of Three problems. The main b+ filter is defective, one of the standby power sources have a bad capacitor on the line, or theres a short in the main amp. section. Its probabvly going to cost you more then you would care to invest in a reciver thats around 5 to 6 years old. Its most likly time for you to upgrade to a suround sound dydtem with new fancy lights bells and whistles. Good Luck
Jul 29, 2006 | Onkyo TX-SV636 Receiver
Open Questions:
See all Yamaha YAS-70 Front Surround System Black Theater Questions
Yamaha YAS-70 Front Surround System Black Theater System Logo
159 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
