Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Green convergence squeezed top and bottom
My philips 60pp9202 has a problem with the green convergence. the picture looks like the green portion is being squeezed from the top and the bottom causing green shadowing humps on the top and bottom. the picture in the center of the screen is fine. the clock also jumps ahead by 25 minutes when the tv is turned on and needs to be reset each time. i don't know if these are related. tv repair man looked at it 2 months ago, contacted philips and says he doesn't know how to fix it. please help chris
Manually adjust the converge controls
Posted on Feb 20, 2007
I have a friend with a Philips 60PP9202 TV, and she describes her problem as: "The top/bottom corner of the picture is kinda waved and the color is blue/red (3D like)". Would anyone have an...
The tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all it resistors are dead too.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 15, 2010 | Philips 60PP9202 60" Rear Projection...
Bent Picture at top and bottom
You have bad convergence amps.The fluid may need to be changed if the picture had a hazey look to it before the convergence went bad.
Dec 13, 2008 | Philips 60PP9202 60" Rear Projection...
Phillips 60pp9202/17f projection convergence
what about blue? this is an indication that maybe one of the convergence ic have failed. generally you replace both. falure of the ic can also be sympton of other problems.. The oputput ic resistors. the covergence power fuses. but the first step is to replace the ics
Nov 03, 2008 | Philips 60PP9202 60" Rear Projection...
SPEED BUMP OR BOWING
Your convergence chips and convergence resistors are going bad. When they fail the screen colors will look distorted/3d looking. Another symptom is one or more colors can't be converged using the convergence menu. You can purchase the parts over the internet. Just make sure you get Sanyo brand convergence chips and the correct flame proof resistors. You can also check the site www.TvRepairKits.com for a kits.  Just make sure you replace both of the convergence chips and all of the convergence resistors.
Aug 25, 2008 | Philips 60PP9202 60" Rear Projection...
Tv convergence
You will need to have a qualified technician replace the convergence IC's and possibly 2 resistors
If you are somewhat experienced with properly unsoldering the old parts without damaging the pc board you can replace the IC's yourself.
Most Philips CRT Projection televisions use 2 generic number STK392-120. These are mounted on a large aluminum heat sink
and soldered to the bottom of the pc board
There are sometimes 2 or more resistors that may be burned most often these are 6.8 ohm 1 watt
These parts can be found at www.tritonicsinc.com be sure to get the "original Sanyo" or the Philips brand, do not use the cheaper versions that come from China
good luck
Supertek
tvservice1@sbcglobal.net
Mar 09, 2008 | Philips 60PP9202 60" Rear Projection...
Picture problem
Convergence overhaul needed =====
1)Pull chassis
2)Replace Stk392-110 IC's x 2
3)reset alignment
  Usually a 400.00 repair at a tv shop......T.
Oct 18, 2007 | Philips 60PP9202 60" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
114 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
